Harbor Freight tools thread.
Discussion in 'Off-Topic Discussion' started by Markcal, Nov 24, 2016.
  1. Nov 7, 2017 at 12:36 PM
    #1961
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Disassemble it, pressure wash, and take it somewhere to be blasted. For a single project that's going to be your best bet IMO.
    Your compressor wont keep up with a blaster which will just frustrate you. I have a Quincy QT-54 and it runs a ton when blasting.
    As for media its pretty much how abrasive they are. Sand is pretty abrasive and good for thick rust. Glass is sort of a medium grit compared to soda and sand. Soda blasting isn't very aggressive but good cause it doesn't hit the metal as hard. That's a very basic explanation though.
    Bulldogs129[QUOTED] and koditten like this.
  2. Nov 7, 2017 at 1:32 PM
    #1962
    EnonEye
    EnonEye Well-Known Member
    David
    O-H-I-O
    Silver '06 DCSB TRDPreRunner Off-Road/ Tow package
    thinking of buying their mini chainsaw with the extension handle. anyone use one of these? time trim overhead branches next spring
  3. Nov 7, 2017 at 1:53 PM
    #1963
    Ricky B
    Ricky B Well-Known Member
    Arkansas
    1998 XCAB
    I am a big harbor freight fan. My father-n-law is a retired mechanic and has a lot of snap on and Mac tools that he has acquired over the years. I like going into that place with him because he knows what you can get by with and what you need to spend a little more money on. I have a eclectic 3/8 drill and 1/2 drive electric impact that I have used for a long time. I have good luck on the 4" angle grinder but I have noticed it giving me a few problems the last time I used it. I have purchased a lot of their tool kits to keep in each veh and my rhino and camper to have at least something to work with. I have purchased probably about 15 crescent wrenches their and a lot of pliers and throw in the free tape measure they run a lot of times. I try and keep a crescent wrench in both tractors and every veh that I own. I have a Christmas list going from their and on it I have a creeper, axle nut kit and a ball joint puller.
    Bulldogs129 likes this.
  4. Nov 7, 2017 at 1:55 PM
    #1964
    Lifeofbrian
    Lifeofbrian Longing for the far East
    Brian
    Westminster, CO
    2010 TUNDRA 5.7 Rock Warrior
    Stuff
    I have one of their autodarkening masks, it works great for me. I dunno how people weld without one.
    EatSleepTacos[QUOTED] likes this.
  5. Nov 7, 2017 at 1:57 PM
    #1965
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I need to pick one up. I ended up getting a fixed shade one, but I don't think it's dark enough. I may as well get an auto darkening one.
  6. Nov 7, 2017 at 3:06 PM
    #1966
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    Anyone have experience with the HF version of the Hi-Jack?
    Are they as good as the real thing?
  7. Nov 7, 2017 at 3:10 PM
    #1967
    shieldze1025
    shieldze1025 Well-Known Member
    North Shore Oahu, HI
    2012 TRD Sport 4x4
    I have no personal experience but they're popular here by all the lawncare companies. I get by with a manual extended trimmer but def have a mini chainsaw on the list once it gets bad enough
  8. Nov 7, 2017 at 3:15 PM
    #1968
    Bulldogs129
    Bulldogs129 Don't find fault, find a remedy
    Malcolm
    Mississippi
    2018 TRD, OR, 4wd, Dblcab, 3.5l, & 2002 Tacoma 4wd, SR5, TRD, 3.4L, auto
    I've had one for 10 years, lift a big tractor, diesel zero turn, pull fence post...It's always worked
  9. Nov 7, 2017 at 3:16 PM
    #1969
    Tactical_Panda
    Tim
    Fredericksburg, VA
    Will it work with accessories designed for the real Hi-Jack?
  10. Nov 7, 2017 at 3:18 PM
    #1970
    Bulldogs129
    Malcolm
    Mississippi
    I'm not sure, see if you can compare the dimensions of both jacks.
  11. Nov 7, 2017 at 3:19 PM
    #1971
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Do it and post your review
  12. Nov 7, 2017 at 3:21 PM
    #1972
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    No
  13. Nov 7, 2017 at 3:23 PM
    #1973
    Tactical_Panda
    Tim
    Fredericksburg, VA
    Thanks.
  14. Nov 7, 2017 at 3:24 PM
    #1974
    Bulldogs129
    Malcolm
    Mississippi
  15. Nov 7, 2017 at 4:59 PM
    #1975
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    How about some details?
    There are some pretty good "McGyvers" on this site.
    I love my HF hi lift, but had no idea that the accessories don't work.
    More info, please.
  16. Nov 7, 2017 at 5:01 PM
    #1976
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Rakso likes this.
  17. Nov 7, 2017 at 5:04 PM
    #1977
    koditten
    Kirk
    Central Michigan
    I never even knew about hi lift accessories or this site. I had the HF Jack long before.
  18. Nov 7, 2017 at 6:18 PM
    #1978
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    They'e not the same size. I'm sure YOU can make the accessories work for the HF. I do own a HF one, don't forget they change the models thus the actual size, shape of some items.
  19. Nov 7, 2017 at 6:19 PM
    #1979
    koditten
    Kirk
    Central Michigan
    No problem. I don't see that as a deal killer.
  20. Nov 7, 2017 at 6:23 PM
    #1980
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    This is the one I have from HF. Like 5 years old.
