Harbor Freight Trailer Build/Idea
Discussion in 'Other Builds' started by DoccoM85, Sep 11, 2014.
  1. Feb 18, 2015 at 5:33 AM
    murderedtaco23
    murderedtaco23 Well-Known Member
    Jesse
    Campton NH
    09 dbl cab trd sport
    OME 3 inch lift all the way around, 285 75 16s, fog light any time, HID, Rock sliders, 30 inch bumbper LED, LED pod ditch lights
    Thanks for sharing, I am running duratracs on my truck, so I feel your pain with the price tag. 250$ for welding is a great deal. If you were to buy a decent welder and DIY you would be spending over 250 on just a welder. never mind the time and other things you need. I weld myself but that is a great deal. overall this this is awesome. Definitely in my 10 year plan
  2. Feb 18, 2015 at 11:36 AM
    logcabinwc
    logcabinwc Well-Known Member
    Micah
    SF East Bay
    08 4d 4x4 White V6 TRD
    Old Man Emu 885s with Nitrocharged 90000, Bilstein 5100 in the back with AllPro 3 spring progressive AAL, 16 inch Baja Black 6-spoke alloy wheels, Flow Master exhaust, bed lights, Pioneer HD radio, Uniden CB Radio, K&N Air filter, BAMF Sliders w/kickout, Relentless Aluminum IFS Skid, 24 LED light bar, custom/homebuilt expedition style bed rack and basket combo, and Body Armor rear plate bumper.
    I appreciate the cost list!
    Welding in the center spine I could do myself, save some cash
    And I would probably go with plywood floor, then I wouldnt feel bad about beating it up because it is easily replaced.
    But I like this a lot. I figured I would probably use one of the harbor freight trailers as a starting point too so its nice to see someone has done it
  3. Feb 18, 2015 at 8:43 PM
    DoccoM85
    DoccoM85 [OP] Well-Known Member
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    Well, have not found it, but im going to keep looking, in the mean time im going to call Skagit Steel to figure it out, cause now it will bother me, hehehe
  4. Feb 18, 2015 at 8:49 PM
    DoccoM85
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    Absolutely right, as much as id love to have a welder in my tool arsenal that i know how to use, i do not have nearly enough jobs in my forseeable future to justify even a basic setup :)
    And thanks again, its great to see that the project at near finish is appreciated!
  5. Feb 18, 2015 at 8:51 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
  6. Feb 19, 2015 at 6:50 AM
    Tacodriver08
    Tacodriver08 To have faith, is to trust yourself to the water
    Texas
    05 X-Cab 4x4
    Too many to list
    Thanks Corey! Haha man I spent a ton of time in that forum before I started building my trailer, pretty good information there, that's where I found the plans for the $50 3-axis hitch I built. I have some plain old blazer trailer lights for mine now but we shall see how long they last.
  7. Feb 19, 2015 at 7:29 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Thank you so much for all the info. I too have a trailer project that I am going to do this spring. I have a quick question, what size tire did you end up using and how did you determine what size fender was needed to cover them? My tire size is 215/70/16 (I think)
  8. Feb 19, 2015 at 1:13 PM
    DoccoM85
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    No problem, and you just reminded me about the axis hitch, I remember seeing it, I need to revisit that idea :cool:
  9. Feb 19, 2015 at 1:24 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    If it is too mch of a hassle, forget about it, bud. I will go to some metal shops and ask around, while I am shopping around. Thanks for the effort.
  10. Feb 19, 2015 at 1:30 PM
    DoccoM85
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    No problem rob! Off the top of my head I believe they are 235/75/15, ill confirm for you once I get home and check.
    As for the fenders, to make a long detailed story short, I made my rim/tire choices based on knowing what would easily clear the frame. I did NOT however think about the overall distance from the frame to the end of the tire tread which should at the very least be covered. So the shopping/searching began when I measured that out (13") and finally landed upon a trailer company in California that made steel fenders for cheap with that width. As for length and height, I simply mocked them up to the frame and marked off how much to trim off the bottom of the fender (they were long, at least 6" came off each end) that allowed them to be flush with the bottom rail and avoid the worst case scenario of the leafs snapping/axle hitting the frame but still avoid jamming into the fender. That was still a little long winded, hopefully that makes sense :eek:
  11. Feb 19, 2015 at 1:37 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You sir, have inspired me. I am going home this weekend (at college right now) and I am going to purchase one of these trailers and store it until summer (when I have access to a welder). I think I am going with your basic idea with one addition, I have a set of Jeep YJ front leafs that I got for $20 that I'll use for suspension with the eventual addition of shocks.
  12. Feb 19, 2015 at 1:41 PM
    !TacoTaco!
    !TacoTaco! TACO LOVER!
    Felix
    PSL, FL
    09 Prerunner TRD SR5 Sport
    Removed coal filter, Also installed AFE air filter. Roof rack with custom diamond plate air diverter.
  13. Feb 19, 2015 at 2:09 PM
    DoccoM85
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    5052-H32 1/4" Aluminum Plate
    Had them e-mail me the receipt ;)
    Not quite as tough as the 6061, but I think it will fair just fine given the frame cross support intervals, im also thinking of Rhino-Lining the top to add a non-skid, scratch resistant surface as well!
  14. Feb 19, 2015 at 7:57 PM
    DoccoM85
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    Confirmed 235/75/15 :)
    mach1man001 likes this.
  15. Feb 19, 2015 at 8:07 PM
    #35
    DoccoM85
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    Right on Zane! Its a blast from the start, like i said even the planning can be exciting, knowing it is stored away might get you cranking on ideas ;)
    Good call on the leafs, i do wish i had opted for an upgrade in that area, HF's are small and im sure provide a rough ride. It sounds like you have a great option, but for anyone else Dinoot does have a kit available using 29" "Premium trailer leafs", but the kit is a "tad" more than $20
  16. Feb 19, 2015 at 8:50 PM
    #36
    PatriotOfAmerica
    PatriotOfAmerica Well-Known Member
    Reed
    Good Ole' Kentucky
    03 Jade Mica DC TRD 4x4
    33'' kanati mud hogz arb front bumper are camper shell 42'' cree light bar color match fender flares
    super cool! sub'd! gosh you just got my wallet all worried now
  17. Feb 20, 2015 at 7:54 AM
    #37
    Tacodriver08
    Texas
    05 X-Cab 4x4
    Too many to list
    I was a little skeptical at first, but after I started building it I started to see how good of a design it really is. I added a little extra reinforcement in some places just to give me extra peace of mind.
  18. Feb 20, 2015 at 8:02 AM
    #38
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    I'm excited to see the finished product
  19. Feb 20, 2015 at 8:22 AM
    #39
    Nightstr
    Nightstr Well-Known Member
    Felipe
    Sacramento CA
    05 prerunner sr5
    BLHM BLWM 3" TOUGH COUNTRY LIFT TRD SEAT COVERS THULE RACK M/T KM2 265/65/16
    This is Great! i was just looking at some trailers last nigh on Craigs but i would much rather build my own. :D
  20. Feb 20, 2015 at 10:32 AM
    #40
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
