Harbor Freight Trailer Build/Idea
Discussion in 'Other Builds' started by DoccoM85, Sep 11, 2014.
  1. Feb 20, 2015 at 12:08 PM
    #41
    PatriotOfAmerica
    PatriotOfAmerica Well-Known Member
    Reed
    Good Ole' Kentucky
    03 Jade Mica DC TRD 4x4
    33'' kanati mud hogz arb front bumper are camper shell 42'' cree light bar color match fender flares
    im ready to see some progress pics!!! :popcorn:
  2. Feb 21, 2015 at 8:08 PM
    #42
    DoccoM85
    DoccoM85 [OP] Well-Known Member
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    Coming right up! It was sunny and 50+ degress today, couldnt pass up trying to finish the trailer!
  3. Feb 21, 2015 at 8:30 PM
    #43
    DoccoM85
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    So i planned on bolting down the e-track at 5-hole intervals. Im a dummy and didnt measure it out right so every other drilled hole ended up too close to a cross support beam to screw a nut onto a bolt............
    ..... So i bolted down every 10, and used a little problem solving with #8 washers and rivets to plug the rest. Im pretty confident in its strength.
    I cut out strips from a diamond-patterned rubber mat with adhesive backing to stick to the posts to cushion the metal-on-metal contact with the aluminum ramps/sidewall.
    Here is a sidewall mounted up, i just passed a bolt through and used an aluminum bar as a bracket, the bar is just from Home Depot, cut with an angle grinder. You can see it bend into dimple a little, i might switch to a slightly thicker bar.
    Next up was attaching the front and back cargo nets. Simply used a d-ring bracket with a few washers to add space since i could not find em large enough to fit the Safari Strap ring. The excess strap for adjusting up top will be secured with outdoor rated velcro loops.
    Adding the Yakima rack system. Stock bolts that came in the #7 kit were too short, i opted to change the hardware from allen-head to hex-head while i was at it.....
    ..... To fit the new bolts i had to widen the top portion of the landing pad, so i used a 5/8ths wood-bit to accomplish this, i learned the hard way not to try and hold it firmly on a flat surface with one hand and drilling with the other the hard way, the clamp worked much better.
    Teaser pic nearing completion, just popped in the e-track rings to see how they work, i like the system, pretty versatile! You can see the back Yakima bar mounted up.
    Naveronski likes this.
  4. Feb 21, 2015 at 8:32 PM
    #44
    DoccoM85
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    I mocked up the Tool box, and while it looked good on the first build-up sans paint, with the flat black/OD green it looked quite out of place (and too big). So i went another route, ill post the final picture of the entire trailer when i mount the last bits, hopefully tommorow!
  5. Feb 21, 2015 at 8:36 PM
    #45
    Boogyman
    Boogyman Well-Known Member
    Phoenix
    Corpus Christi, TX
    2022 Lunar Rock Trail Edition
  6. Feb 22, 2015 at 12:58 PM
    #46
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    Here's some comparables:
    $1800/585 lbs/1500 lb capacity
    http://www.northerntool.com/shop/tools/product_200329599_200329599
    $2700/585 lbs/1500 lb capacity capped model
    http://www.northerntool.com/shop/tools/product_200633734_200633734
    $3150/700 lbs/1500 lb capacity tent model
    http://www.northerntool.com/shop/tools/product_200588488_200588488
    #46
  7. Feb 22, 2015 at 1:14 PM
    #47
    Augie
    Augie Well-Known Member
    Poway, Ca
    06 DCLB 4x4 (sold)
    Sold
    sub'd...I don't know that I'll ever be able to afford one of these but I enjoy reading the ideas and seeing the workmanship people like yourself Op, put into these builds.
  8. Feb 22, 2015 at 3:26 PM
    #48
    PatriotOfAmerica
    Reed
    Good Ole' Kentucky
    looking sweet brother
  9. Feb 22, 2015 at 5:07 PM
    #49
    DoccoM85
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
  10. Feb 22, 2015 at 5:08 PM
    #50
    DoccoM85
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    Thanks Augie, i appreciate the kind words!
  11. Feb 22, 2015 at 5:26 PM
    #51
    DoccoM85
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    Almost done! I am still looking for a better option with the front storage box, i left my options open by loctiting the bolts to the frame so they act like studs. I can run just the tongue plate, attach rings for securing something, or when i find the box i want i can just bolt it on! The bottom nuts act as a perfect spacer since the center spine is slightly higher than the side a-frame rails anways, win/win =)
    Still need to secure the loose straps
    Ill post up a final pic when its all said and done with the lights on and what not =D
  12. Feb 22, 2015 at 5:30 PM
    #52
    PatriotOfAmerica
    Reed
    Good Ole' Kentucky
  13. Feb 22, 2015 at 5:33 PM
    #53
    DoccoM85
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    Thanks Reed!
  14. Feb 22, 2015 at 5:47 PM
    #54
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
    Great job.
  15. Feb 22, 2015 at 6:46 PM
    #55
    Overkill07
    Overkill07 Tacoitis
    Warren
    Texas
    14 TRD O/R DC MGM
    A few audio upgrades, tinted windows, remote start because it f'n hot in Texas! 6in Fabtech DB lift, 17x9 Fuel Trophy wheels, 315/70/17 Duratracs,BAMF 80in sliders w/kickout, Prinsu cab rack w/30in Heretic light bar, custom bedside decals, custom hi-lift jack brackets, US Offroad front bumper w/winch, bed rack with RTT, CB, Short wave base station, Ultra gauge, color matched grille surround, an ungodly amount of recover gear, ARB fridge, hood struts, RotoPax, traction pads.
    Definitely an inspiration for another build/project of mine. My wife is gonna hate me, lol :rolleyes:
  16. Feb 22, 2015 at 7:31 PM
    #56
    NorthCountryTRD
    NorthCountryTRD Well-Known Member
    Patrick
    New Hampshire
    2015 Tacoma TRD Off Road V6 Manual
    Current Mods: - Locking Lug Nuts - Weather Tech floor Liners - N-Fab light bar - 32” Led Light bar - TRD skid plate - Leer Cap (Pyrite Mica) - Rigid TSM-22 Tow Strap Shackle Mount - Rigid Orange Shackle - @ACEkraut License plate bracket - Flashwolves LED reverse bulbs - TRD Stainless Cat Back - AFE Pro Dry S drop in filter - Glove box organizer - Center Console organizer - Bed Stiffeners - Color match grille - Custom Car Grills Perf SS Mesh flat black - Thule Cap roof rails - TRD PRO Suspension - Wheelers 2" Add a Leaf - HS 1/4 inch strut spacers - SCS Ray 10's in Brushed Copper - Cooper Maxx St's 275's - Under hood Led Light Kit Future Mods (as of right now): - 20inch LED Bar (Caliraised,Rigid, Baja) - 32inch LED Bar (Caliraised,Rigid,Baja) - LED Pods Side Projecting (Caliraised, Rigid) - Toyota Bed Matt - Quick fist Axe and Shovel mounts in Truck Bed - Cap mounted Awning - 100% No Drill Bolt on sliders - Wet Oak Seat covers (All black with TRD in them) - VooDoo Bed Bars/Basket that works under a cap
    Looks bad ass man. Great job i have been thinking of building something like this as well since i do alot of hiking and camping
  17. Feb 24, 2015 at 5:20 PM
    #57
    TheKid
    TheKid Well-Known Member
    Bay Area, Ca
    2011 Tacoma
    Awesome build man. :thumbsup:
  18. Feb 25, 2015 at 12:25 AM
    #58
    PatriotOfAmerica
    Reed
    Good Ole' Kentucky
  19. Mar 8, 2015 at 4:23 PM
    #59
    DoccoM85
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    I do not have a Garage unfortunately, so i made a little modification to the fence in front of my carport to fit the Trailer. As you can see the tongue goes a little past the fence, so accomodations were made =D
    Removed panel, screwed in new brackets, so panel slides into place
    I cut a small panel out to fit the remaining part of the tongue that sticks out
    On the backside i installed four Window Bolts to hold the panel in place when the trailer is not parked there.
  20. Mar 8, 2015 at 4:27 PM
    #60
    DoccoM85
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    Only consideration that im thinking about in regards to the fence is whether or not to shave the top of the small panel.
    It's either flush clean look when trailer is out and uneven on the bottom like it is when its parked.....
    Or flush clean look when trailer is parked and 3" gap when its out.....
    Think as of right now id rather the clean look when its out, seeing as that means im likely gone and would prefer not to leave any hints about the panel modification.
