Harbor Freight Trailer Build/Idea
Discussion in 'Other Builds' started by DoccoM85, Sep 11, 2014.
  1. Mar 8, 2015 at 4:39 PM
    #61
    DoccoM85
    DoccoM85 [OP] Well-Known Member
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    Ended up going with a Contico storage box for the front, pretty tough it seems, has a latch and is lockable. Used a strip of metal to act as a bracket on the inside and bolted it in, used some sealant to ensure water doesnt find its way through the bottom.
  2. Mar 8, 2015 at 5:04 PM
    #62
    DoccoM85
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    Took it for a spin and it towed great =) Could barely tell it was back there!
    sipaez likes this.
  3. Mar 8, 2015 at 6:34 PM
    #63
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    trailer has turned out nice.
  4. Mar 8, 2015 at 7:00 PM
    #64
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    Ate those HF trailer only rated for 50mph?
  5. Mar 8, 2015 at 7:05 PM
    #65
    DoccoM85
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    I believe that limitation is attributed to the tire size, 12" has a 55MPH warning on them, smaller tires will prematurely wear out bearings in no time at higher speeds due to RPM. The RPM also plays into tire construction and how much centrifigal force it can handle.
  6. Mar 8, 2015 at 7:17 PM
    #66
    stphnman20
    stphnman20 Well-Known Member
    SCV
    2016 T4R
    Really nice job. HF sale a day sale going on now but I didn't see the prices on those trailers.
  7. Mar 8, 2015 at 8:53 PM
    #67
    PatriotOfAmerica
    PatriotOfAmerica Well-Known Member
    Reed
    Good Ole' Kentucky
    03 Jade Mica DC TRD 4x4
    33'' kanati mud hogz arb front bumper are camper shell 42'' cree light bar color match fender flares
    Awesome stuff man! Turned out great!
  8. Mar 8, 2015 at 9:52 PM
    #68
    DoccoM85
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    Thanks Guys! Appreciate the words =D
    And from the website, it looks like it is on sale for $369, armed with your trusty 20% off and in WA 8% tax, it comes out to around $320!
  9. Mar 9, 2015 at 6:18 PM
    #69
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    pretty neat!
  10. Mar 9, 2015 at 6:19 PM
    #70
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    what size tires are those?
  11. Mar 9, 2015 at 6:54 PM
    #71
    DoccoM85
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    235/75/15 Kind Sir!
  12. Mar 10, 2015 at 7:14 PM
    #72
    LBCdan
    LBCdan TACO --> TUNDRA
    Dan
    Long Beach , CA
    2018 Tundra CM 4x4
    Toytec Coilovers, TotalChaos UCA, Icon w/ Resi, Toytec Lift Shackle, Methods w/ 285/75/18 Tires.
    Awesome build! I am wanting to build one of these up now. I want a camping trailer to mount a RTT to and this would be a great alternative to purchasing something for the bed (already have a tonneau cover) or an already built trailer. Great job!
  13. Mar 10, 2015 at 7:38 PM
    #73
    DoccoM85
    Corey
    Whidbey Island, WA
    01 Reg Cab 4X4
    Thanks Dan! The whole process was quite a bit of fun =D Like i mentioned before, its really what you make of it, imagination is the limit. The RTT idea would be sweet, if i were to go that route i would add two stabilizer jacks to the front of the frame.
    Pretty awesome how well received this project has been. Thank you everyone, makes it that much sweeter when its done =D. In hindsight, knowing there is some interest in this kind of build, i would have documented and taken far more pictures.
  14. Mar 11, 2015 at 6:01 AM
    #74
    ThirdCoast
    ThirdCoast Well-Known Member
    Houston
    2011 DC TRD TX
    pretty damn bad ass man, great job.
  15. Mar 11, 2015 at 6:24 AM
    #75
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Great build Corey. very clean. Aside from the very weak a-frame neck on the trailer, the HF heavy duty is a great platform to start with. I bought one about 7 years ago to cart stuff back and forth to college. about 4-5 years ago, I decided to make it an off road gear hauler, and it's been great ever since. about do for an overhaul, but the new suspension has been great, frame has held up, and the size is perfect.
    still a little bit of the harbor freight red lingering on the cross members ;)
    the overhaul of it will include chopping the height of the enclosure in half, and adding a roof top tent to it, so i'll be following your build closely, to take away any tricks you learn.
    Keep up the great work :popcorn:
  16. Mar 11, 2015 at 9:54 AM
    #76
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    What did the suspension run you? Ballpark
  17. Mar 11, 2015 at 10:58 AM
    #77
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    well, it starts with the axle. I custom built the axle with hubs to match the bolt pattern on our trucks a while before I built the suspension, and just ran on the stock leaf springs for a while. the steel tube, spindles, and hubs for that were probably about $200. Suspension is pointless without the beefed up axle to match.
    the suspension was probably another $300 or so.
    -links: have to buy the tubing, rod ends, bungs, hardware, and mounting tabs
    -springs: i was having issues finding springs with the right in*lbs rating that were short enough, so i actually had to go with a lowering spring kit for an Acura, which included the adjustable spring seats.
    -shocks: just had to toy around with some cheap-o brand shocks t find ones that were the right length. i think the blue ones i have on now are from a chevy pickup. the heavy truck valving, but severe angle i placed them at gave me about the valving and length i needed
  18. Mar 11, 2015 at 1:32 PM
    #78
    logcabinwc
    logcabinwc Well-Known Member
    Micah
    SF East Bay
    08 4d 4x4 White V6 TRD
    Old Man Emu 885s with Nitrocharged 90000, Bilstein 5100 in the back with AllPro 3 spring progressive AAL, 16 inch Baja Black 6-spoke alloy wheels, Flow Master exhaust, bed lights, Pioneer HD radio, Uniden CB Radio, K&N Air filter, BAMF Sliders w/kickout, Relentless Aluminum IFS Skid, 24 LED light bar, custom/homebuilt expedition style bed rack and basket combo, and Body Armor rear plate bumper.
    I am completely ignorant when it comes to suspensions besides basic understanding of springs and shocks.. so I just spent 3 minutes staring at that trailer suspension...
    How does that even work? Are there any shocks that go in the springs to better secure the axle to the frame, or does it rely solely on the two blue chevy shocks and four other ball joint bars?
    Just seems like those angles would have really weird stresses, especially at high speed.
    If it works it works though!
  19. Mar 11, 2015 at 5:28 PM
    #79
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    it's a double triangulate 4-link setup. give it a google, and you'll be able to see all kinds of examples of it on off road vehicles (fast and slow). you need both "triangles" to keep the axle stationary in every direction except for it's (nearly) vertical travel. the 4 links only see tension and compression, never and bending forces.
    the blue shocks are what currently limit the axle's drop.
    maybe this is a better view
  20. Mar 11, 2015 at 5:47 PM
    #80
    V5ioV
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    Thanks for the info!
