Hard brake line
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cl251, Oct 24, 2023.
  1. Oct 24, 2023 at 11:55 AM
    cl251
    cl251 [OP] Well-Known Member
    New jersey
    2010 Silver Tacoma TRD Sport
    3in Bilstein lift w ucas 17x9 Falcon Wheels and 35s Viper cut Stereo upgrade Lighting
    Any idea why my hard brake line that runs to the caliper keeps blowing up. I have replaced each side atleast 5 times and every couple of weeks I end up with no brakes and fluid everywhere because that hard line gives out
  2. Oct 24, 2023 at 11:58 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Is it flexing at either end? It shouldn't be.. One end is the caliper and it is likely tight or you would have bigger problems. The other end is that bracket on the knuckle, if it's loose ot could flex the line around.. where is it breaking? At the fittings? In the middle?
  3. Oct 24, 2023 at 12:00 PM
    cl251
    New jersey
    Every time I fixed it I find a broken piece inside where the line threads into the caliper
  4. Oct 24, 2023 at 12:03 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Are you possibly overtightening it? Those little fittings only need 9-10 lb/ft
  5. Oct 24, 2023 at 12:04 PM
    cl251
    New jersey
    I don’t think so because they work fine for a bit then all of a sudden one day they decide to give out. I’m always very cautious with them bc they always give me issues
  6. Oct 24, 2023 at 12:06 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If the piece you're digging out of the caliper is the flare piece of the line then it really sounds like too much torque
  7. Oct 24, 2023 at 12:07 PM
    cl251
    New jersey
    I’ll try to be easier when I replace this one later. I will update/send pictures when I get this broken one off
  8. Oct 24, 2023 at 12:10 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Get your hands on a torque wrench and practice what 10 lb/ft feels like, or 120 in/lbs on a smaller torque wrench.. it's not much
    If you have some crows feet sockets you can torque the lines exactly to spec
  9. Nov 10, 2023 at 4:29 PM
    RockoTheTaco
    RockoTheTaco New Member
    '13 tacoma 2.7l 4x4 5sp
    Any chance you know the length of this hard line off the top of your head? Need to replace mine and want to make sure I get enough length for both sides but not 100ft lol
  10. Nov 10, 2023 at 4:42 PM
    cl251
    New jersey
    I believe 12in I replace it with the autozone part number PAX-312
    RockoTheTaco[QUOTED] likes this.
  11. Nov 10, 2023 at 5:53 PM
    RockoTheTaco
    Thanks cl251. Appreciate it
