Hard Braking with a 2012 DBL Cab 4WD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Monster1, May 13, 2013.
  1. May 13, 2013 at 8:30 PM
    Monster1
    Monster1 [OP] Well-Known Member
    San Antonio, Texas
    2012 Texas Edition DC Tacoma 4WD
    Weathertech digitals front and rear, TRD exhaust, Coverking dash mat, Oem Tacoma bedmat, Better Built tool box, bed extender, Toytec 1 1/2" AAL, Bilsteins front and rears, fronts set at .85, K&N filter, aluminum skid plate, EGR vent shades, locking tailgate handle, TRD emblems, Cal Trend seat covers front and back.
    Yea, I was wondering if I could get some sort of replies on this issue. I had to brake really hard today so as not to hit this car who suddenly decided to make a U turn unexpectly right in front of me. When I braked my front end seemed to rotate clockwise slightly and I felt a slight clunk at the same time, but once I started back on the road again everything seemed to be ok, like nothing had ever happened. Does this sound normal or is there an underlying problem, I only have approximately 5000 miles on it so far. Thanks for listening and for any and all replies.
  2. May 13, 2013 at 9:22 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What does that mean? Your front end rotated clockwise? That makes no sense to me. The closest I can get would be that maybe it pulled to the right side?
  3. May 13, 2013 at 9:28 PM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    If the front end rotated clockwise what did the back end do? :p
  4. May 14, 2013 at 12:54 PM
    Monster1
    San Antonio, Texas
    The tires locked up and I felt a twisting foward while the tires were still locked, the rear was normal.
  5. May 14, 2013 at 4:19 PM
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
    if it breaks good still, drives fine, and nothing looks off then your proly fine
  6. May 14, 2013 at 4:23 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Sounds like abs/vsc stuff. If concerned take it to the dealer to be sure.
  7. May 14, 2013 at 5:05 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Shouldn't have locked up.
  8. May 14, 2013 at 5:59 PM
    Monster1
    San Antonio, Texas
    Thanks to everyone's replies, appreciate it.
  9. May 14, 2013 at 7:08 PM
    DevL
    DevL Well-Known Member
    Did the truck beep at you?
  10. May 14, 2013 at 8:03 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Vsc will lock up a wheel depending on the hard braking characteristics and during avoidance maneuvers. Which Is why I don't like the vsc system.
  11. May 15, 2013 at 4:09 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    One of the hardest issue we had with accident investigation was lack of skid marks with car/trucks with ABS.
  12. May 15, 2013 at 7:44 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Check out some really annoying things with vsc;)
  13. May 15, 2013 at 7:52 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Op a similar thing happened to me about a week ago. Under an emergency stop the truck pulled to the right and the rears locked up. I thought I was going around. I figured the front springs are so soft that it nose drives hard and the rear being light was the cause. I have had no issues since.
