Hard Shift after start up in morning
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBell07, Nov 19, 2022.
  1. Nov 19, 2022 at 8:41 AM
    TacoBell07
    TacoBell07 [OP] Well-Known Member
    Four door 2wd Taco
    Recently had to replace some of the rubber lines that connect to the trans cooler/radiator dfid not loose that much fluid (less than 10 oz).
    When engine is cold and I start it up shift into 4th or drive it is fine but when i let off the brake it feels almost like a hard shift.
    Wondering if this is because trans fluid is so cold but seems like the clunk or hard jerk would happen when you shift into a drive gear not when you release the brake pedal....
  2. Nov 19, 2022 at 9:31 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Maybe the transmission fluid was a little low before you replaced the lines?
    If so, 10 oz could be “a lot”.
    Normally, on these trucks. When the fluid is cold, it will shift hard into gear.
    The worst of which is 4th going into 5th (OD).
    Hard shifts on deceleration can be a sign of low fluid. I’d check the fluid level.
  3. Nov 19, 2022 at 4:08 PM
    Pnwadventure
    Pnwadventure Well-Known Member
    Kirkland wa
    2006 white access
    Cold fluid high idle
    TacoBell07[OP] likes this.
