hard shift when stopping...
Discussion in '1st Gen. Tacomas (1995-2004)' started by MTgirl, Sep 29, 2009.
  1. Sep 29, 2009 at 9:40 PM
    MTgirl
    MTgirl [OP] too many frogs, not enough princes... Moderator
    Weesa
    Bob's secret mod lair
    Now: 12 T4R SR5 Then: 99 - 3.4L SR5 4WD
    Wheeler's/Alcan 5-pack leaf springs, Bilstein 5100's front and rear, OME 881's, de-badged, Jungle Fender Flares, Herculined bed, HomerTaco grille, Anzo headlights, clear corners, CVT Mt. Bachelor RTT, custom bed rack & CBI sliders
    My '99 Toy has developed a disturbing lurching right before coming to a complete stop - say at a traffic light. It feels similar to popping the clutch. Problem is its an automatic. It does the same thing hot or cold and in any gear. I had the transmission flushed at 30k and fluid is still clear and full and brakes are good. Everything is stock on the truck - V6, 3.4L, 4WD - and its only got 37,000 miles (no, not a typo!). My driving is roughly 60/40 split of off-road w/4WD and highway miles.
    No other complaints or problems.
    Can anyone shed some light on this? No one I've talked to can come up with a cause. I don't want to let this go if it could lead to something major (as in expensive) to fix.
  2. Sep 29, 2009 at 10:00 PM
    Tacoguy
    Tacoguy Well-Known Member
    Alex
    Chicago
    03 Tacoma PreRunner V6 3.4 TRD
    Bed Liner, Running Boards, Cargo Net, Deck Plate Mod, K&N Air Filter, NGK Iridium Spark Plugs
    I think what you might be feeling is axle wrap???
    I am not completely sure but it sounds like what is happening with mine. I also need to figure out how to fix the issue.
  3. Sep 29, 2009 at 10:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Sounds like axel wrap. Some people have greased up the slip joint on the drive shaft, and had that remady the issue, while others have added an AAL to fix it. The axel wrap tends to get worse as the springs sag with age, and loose their spring rate.
  4. Oct 1, 2009 at 5:50 AM
    dirtJMW
    dirtJMW Member
    joel
    VA
    2003 Tacoma V6 TRD
    I wonder if this is the same thing I have going on....only happens when starting off from a stop or stopping, but not every time....
    it's just a slight shift in the truck, but not a severe jerk....
    so, how can you confirm it's axle wrap???
  5. Oct 1, 2009 at 6:39 AM
    dirtJMW
    dirtJMW Member
    joel
    VA
    2003 Tacoma V6 TRD
    I'm gonna try lubing the zerks on the driveshaft slip joint and see if that takes care of it......
  6. Oct 3, 2009 at 7:00 AM
    MTgirl
    Weesa
    working on the drive shaft later today...hoping that solves it because i really dont want to lift the truck!
    i will report back soon as to any improvement.
  7. Oct 4, 2009 at 11:45 AM
    lve2xlr8_mph
    lve2xlr8_mph Silver Machine
    Tyler
    Middlsex, NC
    2004 Tacoma 3.4 V6 Limited
    Bilstein 3" lift 4" LED flood lights
    does it make the noise when u are stopping or when u release the brake, if it does it when u release the brake it would be the brakes releasing.
  8. Oct 5, 2009 at 7:14 AM
    dirtJMW
    dirtJMW Member
    joel
    VA
    2003 Tacoma V6 TRD
    injected lube in the slip yoke joint , and problem went away!
  9. Oct 22, 2009 at 9:37 PM
    MTgirl
    Weesa
    i've put about 800 miles on since working on the driveshaft and the lurching seems to have gone away. (yeah!) just glad it wasnt something expensive. i can still feel it rise and settle when stopping/starting so i can see what you mean by saying the leaf springs are aging - i guess thats the down side of driving a non-trd offroad most of the time. it doesnt bother me at all but i will probably look into changing them out soon in hopes of getting a smoother ride.
