Hard shifting?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Warcat, May 14, 2021.
  1. May 14, 2021 at 7:21 PM
    Warcat
    Warcat [OP] Member
    Jose
    2021 Toyota Tacoma TRD Sport 4WD
    I have a 2021 TRD Sport
    It’s brand new and manual transmission
    My question is I have noticed she’s a bit hard when shifting through gears she’s a bit rough
    Is that normal?
  2. May 14, 2021 at 7:28 PM
    ridereno
    ridereno Well-Known Member
    Tom
    Reno, NV
    2017 Tacoma DCLB 4X4 TRD-Off Road
    Brand new would say not many......
  3. May 14, 2021 at 7:29 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Easy does it on the stick until you have the muscle memory.
    Similarly for the taco as well.
    Skydvrr likes this.
  4. May 14, 2021 at 8:10 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Take some time getting used to the manual on these trucks . Sometimes I get a smooth shift other times wtf moment . You need to take your time with shifts .
  5. May 15, 2021 at 5:04 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    The transmission will get smoother with both miles and experience with it. It is and will always be a truck transmission not a GTI.
    That said, I have always taken some small pride in my smoothness (not speed) with my manuals -- this one takes more concentration to be smooth with than any other I have had and still provides WTH moments on occasion.
    I believe the electronic throttle is a contributing factor. With old style mechanical systems (cable throttle) you can get a sense of timing, just like dancing with a regular partner. With the electronic throttle the computer is always thinking and reacting -- just enough variables to throw off your timing that little bit.
    All the above said, it is a very nice, enjoyable shifting transmission for a truck, quirky on occasion yes, but nice.
  6. May 15, 2021 at 5:42 AM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    Depends what you mean by hard, rough... but probably normal.
    I had to keep rpms higher than I would have with older trucks. During normal acceleration try shifting 1->2 at 3000rpm-ish, and make it quick. 2->3 at least 2500rpm. After that, just keep rpm above 1500rpm for cruising. See if that smooths it out.
    If it seems worse when cold, dump the stock gear oil and put in Motorcraft XT-M5-QS. Great gear oil, improves shift feel and definitely improves cold weather performance, also meets required specs.
    Good luck.
    EDIT- My 6MT was a 2018.
  7. May 15, 2021 at 6:08 AM
    joshuajayg
    joshuajayg Well-Known Member
    Moab
    2020 TRD Off-Road MT
    I noticed I would get a clunk occasionally when shifting when it was new. Its gone now at 30,000. Maybe break-in, maybe technique. I have driven manuals since I started driving. These trucks also have an accumulator and orifice in the clutch hydraulic fluid path to slow down the clutch action. Some people remove it. That might help you.
    Warcat[OP] likes this.
  8. May 15, 2021 at 7:18 AM
    Warcat
    Warcat [OP] Member
    Jose
    I get the same clunk sound and sometimes the shifter rebounds when going down from 2nd to 1st but apparently it’s normal until break in
    It’s my first brand new manual vehicle I have always had used manuals
  9. May 15, 2021 at 7:33 AM
    TacoTime10
    TacoTime10 Well-Known Member
    New Hampshire
    2010 ACLB 4x4 SR5 2.7L 5MT
    2021 TRD OR wheels and tires, bed stiffeners, fog lights
    My 2nd gen is rough too. Swapping the gear oil for Redline MT-90 seemed to smooth it out a bit, especially shifting into reverse.
  10. May 15, 2021 at 8:59 AM
    BajaBornTaco
    BajaBornTaco Well-Known Member
    Sold: '19 TRD OR - It will always be in my heart.
    So, 1 -> 2 at 3k rpm: What happens if you shift at lower RPMs? Does the gear grind? Does the engine bog down?
    Then you wish "Good luck" to the OP :oops:, plus you went form a manual '18 to an auto '21 :( I'm searching for a manual-transmission Tacoma, but this thread is now giving me second thoughts. Do you miss your manual tranny at all?
  11. May 15, 2021 at 9:18 AM
    joshuajayg
    Moab
    Rebound? You mean it just won't drop into gear? 1st is fairly low compared to 2nd. Maybe your speed is too high. Maybe slow down your shifts a little. When I try to shift quickly, I miss gears. I like the transmission fine and either it or I got a little better after the first month.
  12. May 15, 2021 at 9:40 AM
    Dank Donkeh Luvver
    Dank Donkeh Luvver Well-Known Member
    Eric
    Maryland
    2020 TRD OR White 6MT
    OVTune/Coyoza, Eibach Pro Lift, Mobtown Sliders/Skid, Softopper, Martin Offroad Rack
    stvhwrd likes this.
  13. May 15, 2021 at 10:57 AM
    DTaco18
    It's all about timing. You can shift 1->2 and 2->3 at any rpm you want, but if you're slow on the stick, the rpm can fall below where they need to be for the next gear and it will feel like a "rough" shift. Shifting at higher rpms gives more time to make the shift and get the clutch back out in time to match the rpm needed for the next gear.
    Good luck was for him to get it figured out. I'm sure the truck is fine.
    My 18 MT was a mid-life crisis truck... Had a 1st gen MT, and thought I need a 3rd gen. After knee surgery and lots of short trips I realized that it's just easier to have an AT around. Had an opportunity to sell the MT to Carvana last year for over MSRP, so I had to do it...
    I say get what you want.
    Tacomas hold their value well, so you're not out a lot if you decide to change things up.
  14. May 15, 2021 at 1:22 PM
    BajaBornTaco
    Ah ok, sounds good. And you have a point, I can always trade in for an A/T if the manual does not work for me.
  15. May 15, 2021 at 1:56 PM
    garander
    garander Well-Known Member
    2019 trd sport dcsb mt
    I got 33k miles on my 19 sport . We have to learn the truck .
    Every manual vehicle setup is a little different , trucks more so .
    It wont take long . You too will join the long list of satisfied taco owner .
    Love my manual taco , I'm proud to be part of that small percentage of
    People still able and willing to drive a manual transmission vehicle .
    The 4.30 gearing of the manual optimizes the 3.5 liter motor .
    In no time at all you’ll be singing the praises of the manual taco ,
    Just like the majority of us , or you could trade for an auto and
    Join the mee too crowd lamenting the woes of the auto transmission ,
    Then you can start saving your hard earned money for special tunes and
    Regearing . The manual taco will never drive like a European sedan .
    Its a truck , a very capable truck , more so as a manual truck .
    stvhwrd and TacoTime10 like this.
