Hard slam when accelerating?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MXscott14, Sep 16, 2012.
  1. Sep 18, 2012 at 10:43 AM
    BamaToy1997
    Bill
    Navarre, FL
    lmao. Actually there IS a piston return spring. Several to be exact. They are normally called "accumulator springs" and are used to supply cushioning pressure to the accumulators.
  2. Sep 18, 2012 at 10:48 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
  3. Sep 18, 2012 at 10:56 AM
    TROKITA
    TROKITA Well-Known Member
    Arty
    Utah, the valley
    98 tacoma TRD supercharged
    Supercharged, Custom sunroof, 6 inch lift, wheel spacers, over the rail tire carrier
    ok if your truck hits really hard when you put it in reverse or drive and if it does the hit when you accelerate, check your U-joints. i had the same problem with my truck, and i thought it was the tranny, but found out later it was just the u-joint closes to the rear axle, changed it and it fixed the problem :)
