Hard Start. Any ideas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dbares, Jan 5, 2021.
  1. Jan 5, 2021 at 4:26 AM
    Dbares
    Dbares [OP] Member
    Quick question, 2009 Tacoma. Every so often in the past 2 years or so the truck does not turn over. Let sit and keep trying and eventually turns over. When it turns over it runs completely normal.
    first noticed in the summer months. Happened for the first time in the winter this morning.
    randomly disconnected and reconnected the battery and it started after two ignition turns (probably just got lucky).
    Almost like something is getting stuck? any ideas?
  2. Jan 5, 2021 at 4:53 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Is the engine cranking but not starting or not cranking at all?
  3. Jan 5, 2021 at 5:03 AM
    Dbares
    Dbares [OP] Member
    It is cranking, sounds completely normal. Just doesn’t turn over.
    Has happened maybe 15 times in the past 2 years or so.
  4. Jan 5, 2021 at 5:04 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Cranking but not turn over doesn't compute unless the starter isn't engaging the flywheel teeth.
  5. Jan 5, 2021 at 5:06 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You will have to see what your missing when it doesn't start (spark, injector pulse, fuel pressure, etc) and go from there,
  6. Jan 5, 2021 at 5:11 AM
    Clearwater Bill
    Billy
    Largo Florida
    That is turning over/cranking, not firing/starting.
  7. Jan 5, 2021 at 5:15 AM
    Dbares
    Dbares [OP] Member
    Yes correct.
    Was thinking starter or fuel pump but not sure where to start. It does have 208k.
    spark plugs replaced fairly recently.
  8. Jan 5, 2021 at 5:21 AM
    Dbares
    Dbares [OP] Member
    Or fuel injector....
  9. Jan 5, 2021 at 5:49 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Begin with cleaning/tightening battery terminals then check fuel pressure next.
    tak1313 and 12TRDTacoma like this.
  10. Jan 5, 2021 at 7:25 AM
    Dbares
    Dbares [OP] Member
    I did have a check engine light that was going on and off periodically when I was not driving the truck on a regular basis a couple months ago. Now that I drive daily I have not seen it go on. It was a knock sensor error. Not sure if this could be related?
    The more I read, the more I think it could be a clogged fuel injector. Any sure fire sign/symptoms?
  11. Jan 5, 2021 at 7:35 AM
    TimM83
    TimM83 Well-Known Member
    Tim
    Kansas City, Kansas
    09 Sport DCSB 4x4 6MT
    Cold Air Intake, LED Headlights, LED Tail Lights, 2" Spacer and AAL
    I am having/have had this exact same issue. Cranks but no start, I have narrowed it down to the chip in the key...... the anti-theft system allows the engine to crank but it will not allow it to start. It is irritatingly erratic but I just put up with it. I have had a new key cut and programmed but it may also be an issue with the tumbler
  12. Jan 5, 2021 at 10:01 AM
    Dbares
    Dbares [OP] Member
    that’s crazy. Next time it happens I’ll try my spare key.
    TnShooter likes this.
  13. Jan 5, 2021 at 11:44 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    Intermittent fuel pump? Next time it happens, bang on the fuel tank enough to jiggle the fuel pump (or listen for the fuel pump). I could be a "flat spot" in the fuel pump (the same way one could develop on the starter) - or even the relay could be intermittent. It could be so many things
