Hard start last night, brand new truck! WTF
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RV7Garage, Jan 21, 2012.
  1. Jan 21, 2012 at 7:55 AM
    RV7Garage
    RV7Garage [OP] R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    So I drove home from work, cleared the driveway of snow, and a few hours later the wife and I headed out for tacos. When I went to start the brand new truck... 2500 miles on her... she hesitated pretty bad! I had just filled up the tank on the way home, 93 octane premium (unneccessary I know, but I like it). It was like 16 degrees outside, but the engine was not cold-soaked. Things like that really make me question my choice of brands.
    Any ideas why the V6 would hiccup on start?
  2. Jan 21, 2012 at 7:57 AM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    I'm kind of lost, how long did it take to start?
    Mine cranks a few times before it starts but it does that everytime
  3. Jan 21, 2012 at 8:04 AM
    RV7Garage
    Paul
    Ill Annoy
    Sorry.
    It cranked, almost caught but failed, cranked some more and finally caught.
  4. Jan 21, 2012 at 8:07 AM
    Hunter500ky
    E-Town Ky
    06 Tacoma 4x4 SR5
    I'd mark it up as a hiccup, my truck has done it.
    Could be a vary of things, now if it does it again then I'd be like WTF
    Plus you said it was 16 degrees outside?
  5. Jan 21, 2012 at 8:11 AM
    RV7Garage
    Paul
    Ill Annoy
    Yeah, it was cold... but the engine wasn't cold-soaked. It had bee up to full temp a couple'a hours earlier, so the core was still warm.
    I'll keep an eye on it, but still... shit like that shouldn't happen with a brand new $35k vehicle.
  6. Jan 21, 2012 at 8:11 AM
    cc350
    cc350 Retired Member
    I found that if you try to bump start the V6 it tends to not start, then on 2nd attempt it cracks awhile before starting. Best to always crack on 1st turn till it starts.
  7. Jan 21, 2012 at 8:12 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    any chance you disconnected the battery for any reason. my truck does that every time i disconnect the battery.
    Maybe the truck wasnt cold yet so it didnt spray the extra fuel in the cylinders. (fuel injection version of choke) and the air fuel mixture wasnt perfect for the 16 degree air hitting the combustion chamber.
  8. Jan 21, 2012 at 8:17 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    For hard start:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/196372-difficulty-starting-2012-tacoma-2.html
  9. Jan 21, 2012 at 8:21 AM
    JKD
    JKD Well-Known Member
    I always drop to 87 octane for the winter. Seems to start and run easier.
    What does "hesitated pretty bad" mean? Like, you had to crank the engine over and over for four or five minutes before it finally started?
    It doesn't matter what you pay for a vehicle, a $8,000 Nissan Versa or a $140,000 Ferrari are all just mechanical and electronic machines. Things happen. If it starts to be a pattern, take it to a dealership.
    Buying a different brand of vehicle is not going to change the fact that sometimes things happen.
  10. Jan 21, 2012 at 8:26 AM
    FIRTH4X4
    FIRTH4X4 Well-Known Member
    Eric
    Wyoming
    98 Taco 2.7L 5spd
    Is this only an issue with the V6? I would be calling the dealer demanding an explanation. When we have problems like this on the new John Deere equipment the farmers are down our throat so quick. 150k$ tractor, you can't blame them.
  11. Jan 21, 2012 at 8:29 AM
    cintocrunch
    cintocrunch Special Substitute Guest Member
    MD
    2012 DCSB TRD Sport MGM 6MT
    Anytime fogs, Leer Tonneau
    I have only had one vehicle that started the same way every single time, my '96 Honda Accord LX. All others have intermittently had a long or hard start like you describe, including my '12 Tacoma with 2,800 miles on it.
  12. Jan 21, 2012 at 8:33 AM
    RV7Garage
    Paul
    Ill Annoy
    OK, fair enough!
    Maybe my expectations are too high :rolleyes:
  13. Jan 21, 2012 at 8:37 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Mine's done this a few times since I owned it. I chalk it up to a hiccup in the system. No pattern but a handful of times in the years I've owned it, it's stuttered on start or required a double turn of the key.
  14. Jan 21, 2012 at 8:37 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    Mine does this all the time, seems like some sort of a 2nd gen thing. All the time meaning once a week or so. Never very bad, just takes a second crank.
    It's always started for me tho.
  15. Jan 21, 2012 at 8:43 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Back in 2007 Toyota had a TSB (intermittent no start condition)... I had the reflash done on my truck within the first month after buying it and it's started up fine ever since. I don't know what their doing for the problem now days.
    edit:
    TSB... EG011-07 JUL 07 Engine Controls - Intermittent No Start Condition
  16. Jan 21, 2012 at 9:25 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    at least yours didnt make loud "riiirrrrRRRRR!!! sounds
    this thing makes all kinds of noises starting when its -45*C
    sometimes I still miss my 4.3 vortec
  17. Jan 21, 2012 at 9:44 AM
    muisejt
    muisejt Well-Known Member
    YMM
    08 TRD Sport DC LB
    Katzkin, Bi-xenon Morimoto Mini Stage III Kit (D2S), 4Runner Mirrors, Complete Stereo Upgrade with Backup Camera, Pop&Lock PL5400, Extang Solid Fold Tonneau, TRD OR Tow Hook, rcbs204 4x4 Illuminated Switch, Grillcraft, 10" Rigid light bar behind grill, relocated horns, Redline Tuning hood struts, 5100's with 883 and Wheeler 5 leaf, OME carrier barring drop kit, ECGS Bushing, MarionB2B front hubs
    mine took a couple seconds to fire up this morning but it was -25 °C (-13 °F) and I forgot to plug her in
  18. Jan 21, 2012 at 10:51 AM
    Night
    Night Well-Known Member
    Canada
    '11 TRD OR AC MagGrey
    Banks Monster Exhaust, aFe ProGuard 7, 3M Film, UnderCoating, alpine 920 headunit, alpine 6.5 components, 20% tint all around, JL Stealthbox, PDX-V9 Amp, Avid Lightbar, Avid Sliders, Full Metal JackRabbit Tonneau, TRD S/C
  19. Jan 21, 2012 at 10:57 AM
    kimo
    kimo Well-Known Member
    Knuckle Head
    Kauai
    09 Super White TRD Sport DCLB 4X4! 2017 Silver 4Runner!
    DITTO , same here
  20. Jan 21, 2012 at 11:00 AM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    This was common for me on my 05 4.0l Tacoma. It almost never started first crank. My 2.7L tacoma seems to always start first crank every time.
