Hard start/weak start.
Discussion in '4 Cylinder' started by 2.7taco, Jul 25, 2016.
  1. Jul 25, 2016 at 8:37 PM
    2.7taco
    2.7taco [OP] Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Okay guys and gals looks like an interesting challenge here. My 05 2.7 has a hard/weak starting condition no matter the temp. The battery voltage and amperage is good and the fuel system has the URD high flow replacement. Already been in the tank to check and swap out the submersible fuel hose as per URD's suggestion and no dice. The fuel filter is fairly new maybe a few months old and the fuel pressure regulator and fuel rail relief is new. The plugs are only 2 months old and the truck turns over great but when it starts it seems as if the RPM is too low.
    I'm thinking starter solenoid contacts need replacing but I'm unsure if that would be the only thing that could cause it.
    Any suggestions?
  2. Jul 25, 2016 at 8:40 PM
    2.7taco
    Texas
    No codes on the truck.
  3. Jul 25, 2016 at 9:05 PM
    2.7taco
    Texas
    A little more information. On idle even when hot the exhaust smells a bit rich. Coil pack issues perhaps?
  4. Jul 26, 2016 at 10:32 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Check the plugs are tight. Could be a vacuum leak if it's running rich but I could be wrong. Good luck! [​IMG]
  5. Jul 26, 2016 at 10:45 AM
    2.7taco
    Texas
    Vacuum is good steady 21 inches. Spark plugs are torqued and sealing.
  6. Jul 26, 2016 at 10:47 AM
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    I like your pic. How true!
  7. Jul 26, 2016 at 12:56 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Years ago on a carbureted truck I had it seemed it was the EGR system caused that problem but again I could be wrong
    2.7taco[OP] likes this.
  8. Aug 1, 2016 at 6:14 AM
    2.7taco
    Texas
    I don't think the 2TR-FE has an EGR system. It does have an air injection system.
    Thinking the valve or pump may be lazy.
    I did rebuild the starter solenoid last night so I'm good to go in that department. Battery is definitely strong. Down to my last few things to cross out before I have to let it go to a dealership for further diagnostics.
    Next step swap out fuel filter (URD fuel pump mod) it could be a bad filter.
    Then add a check valve before and later after the fuel filter. As air could be entering the system via fuel fittings or bad check-valve on the fuel pump.
    I'm hoping it's not the pump because I've been in the tank more times than I care to remember. Need a new tank nut and seal ring for the fuel pump module if I go back in there.
  9. Aug 3, 2016 at 6:15 AM
    2.7taco
    Texas
    New fuel filter and quick connect fitting installed and when I left home yesterday morning it fired off better than it has been. Would not doubt the truck needs new coil packs as the truck was flooded gasoline vapor from the tail pipe.
    I think the air injection valve is acting up because when it normally opens during a cold starts it causes the truck to rev sky high and it doesn't do that any more.
  10. Aug 7, 2016 at 4:13 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I do too but it's not quite true. Keg Legs is no woman in my opinion. It's a creature.
  11. Aug 8, 2016 at 4:41 AM
    2.7taco
    Texas
  12. Aug 8, 2016 at 4:47 AM
    2.7taco
    Texas
    Well narrowed it down to fuel system bleed down. Thanks to Toyota for the added bump behind the standard 5/16 SAE fuel quick connect fitting and the extra length they use (compared to Chrysler and Ford) it was a pain to find fittings that would work. I honestly hate non-standard parts. This morning was the first strong start hopefully it stays that way.
