Hard start
Discussion in 'New Members' started by Crackedupmike, Oct 12, 2023.
  1. Oct 12, 2023 at 6:22 AM
    Crackedupmike
    Crackedupmike [OP] New Member
    David
    2013 Tacoma double cab
    I have a 2013 double cab Tacoma. If my truck sits for more than 5 to 6 hours it will crank but not start. I have had an entire wire harness changed, battery replaced an alternator change and still have the problem. It has been at he Toyota dealership three times. I almost forgot a fuel pump changed 3x’s. Can somebody help me out?
    buckhuntin-tacoma likes this.
  2. Oct 12, 2023 at 7:53 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    So it cranks fine (as in the engine spins over with the starter) but it doesn't start but they replaced the alternator?o_O
    Do you have the 4.0L V6 or 2.7L I4
    Does it set any codes when it doesn't start?
    Does your security light next to the clock flash with the key on when it doesn't start?
    What do you do or what has been done to get it started when it doesn't start?
  3. Oct 13, 2023 at 2:58 AM
    Crackedupmike
    David
    4.0L V6/ there are no codes. There are no security lights. Then after continuous cranking it starts.
  4. Oct 13, 2023 at 5:11 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW! Hope you get it figured out.
  5. Oct 13, 2023 at 5:12 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    How do you get it to finally start?
  6. Oct 13, 2023 at 10:34 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I'd want to have a fuel pressure gauge on it when it acts up and see what fuel pressure is doing.
    Were the fuel pumps OEM?
    Does it run fine otherwise?
