Hard Starting 2011?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rhody76, Mar 12, 2012.
  1. Mar 12, 2012 at 8:12 PM
    Rhody76
    Rhody76 [OP] Well-Known Member
    Rhode Island
    2011 SR5 DCLB 4x4
    Rear leaf TSB, Bilstein 5100s set at 1.75",1" blocks, UWS low profile toolbox in black, husky liners, tint, LED interior and reverse lights, yellow fogs
    So I had to crank it about three times this afternoon before it turned over. It had been sitting all day and it was really warm around here today for this time of year (about 70 degrees).
    I remember this happening once or twice before but can't remember what the weather was like
    Anone else had this problem with a newer tacoma or know why this might happen? Only 13K miles on it
  2. Mar 12, 2012 at 8:18 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  3. Mar 13, 2012 at 10:34 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Its common. Some people find if you turn key on for a second or two (Dont start truck ...just turn key until dash lights up) it lets the fuel pump energize and it will sometimes start better.You might give this a try and see if it helps at all.
