Hard starting solved
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jetboater, Aug 26, 2022.
  1. Aug 26, 2022 at 1:47 PM
    Jetboater
    Jetboater [OP] New Member
    2016 TRD off road.
    King shocks , 235/85-16 tires
    2016 3.5. For 4 years starting was intermittent, dealer no success finding the issue. It would crank and crank, let off start button and push again would usually start. When did start while revving the engine could feel a dead cylinder for a few revs then it would clear up. After a day at dealership they said we think fuel pump. No codes ever triggered. Truck did not start for them a couple times but they couldn’t figure it out.
    I did not change fuel pump, 4 years I would’ve thought the fuel pump would have quit. I felt an injector was leaking, flooding cylinder and losing fuel pressure.
    so I ordered 6 fuel injectors from Motorman injection, refurbished. Awesome company if you need injectors.
    I replaced all 6 , changed spark plugs while I had the plenum off, and trucks been starting ever since. Mileage has improved also by about 3 mpg. Thought I would share in case anyone else is experiencing the hard start.
  2. Aug 26, 2022 at 1:53 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Welcome to the forum. Great first post:thumbsup:
  3. Aug 26, 2022 at 2:00 PM
    Spacecoast
    Spacecoast Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
    I don't think one bad injector would cause a starting issue, nor do I think all six injectors would go bad. Perhaps a fuel pressure issue. I understand that you have resolved the starting issue, but I don't think a proper diagnosis was performed, thus it's questionable as to what the problem is/was. I'm surprised you didn't get trouble codes, especially if one cylinder was not firing.
    This guy has excellent videos on how to diagnosis an issue.
    https://www.youtube.com/watch?v=C6K37uQkbL4
    https://www.youtube.com/watch?v=3KyXvdWkgOA
    Chew, vivid02 and shakerhood like this.
  4. Aug 26, 2022 at 2:10 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Did you buy this truck new? How many miles on the truck?
  5. Aug 26, 2022 at 2:17 PM
    jdjones
    jdjones Well-Known Member
    2022 TRD Off-Road DCSB
    Nice to see that you solved your problem. Cheers!
  6. Aug 26, 2022 at 2:19 PM
    saint277
    saint277 Vigilo Confido
    Did you change the DI injectors or the port injectors?
  7. Aug 26, 2022 at 2:32 PM
    Jetboater
    2016 TRD off road.
    I bought the truck brand new, it has 128,000 miles on it. It has spent a lot of time off road, hunting mostly.
    I changed the low pressure injectors, did all 6 as I had no way to identify which one was the culprit. Besides if you take it that far apart mights well change all 6.
  8. Aug 26, 2022 at 3:03 PM
    vivid02
    vivid02 Buy a Tesla…..I need the gas.
    Edwin
    SoCal
    2021 Tacoma TRD Off Road 4x4 DCSB
    OEM+
    :thumbsup:
    It is working now and that’s all that matters!!
  9. Aug 26, 2022 at 3:13 PM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    Do you still have the old injectors? If so, can you measure the resistance of each one and see if one, or more, is not like the others?
    Spacecoast, shakerhood and Chew like this.
  10. Aug 28, 2022 at 5:31 AM
    Spacecoast
    2022 White SR5 2.7L
    And if you still have the removed spark plugs it would be interesting in seeing a photo. Usually there is an indication if a cylinder had been running poorly.
  11. Aug 28, 2022 at 4:02 PM
    Jetboater
    2016 TRD off road.
    So I ohmed each injector , 13.5 average with one being 14.1. Thanks for giving me the idea. As for the old spark plugs I was hoping one would be different to identify the cylinder , but they all looked the same. truck has started every time now which tells me I’ve corrected the issue. I had changed the crankshaft sensor last year as I noticed a recall on some Toyotas so thought maybe they missed mine, also one shop told me my voltage was low on battery and that was my issue but turned out not true. I did run my leaking injector theory by the techs but they just shrugged their shoulders. They couldn’t even tell me which fuel circuit starts the truck. So I took a 149.00 chance my theory was correct.
    bulalo likes this.
  12. Aug 28, 2022 at 4:27 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Great job OP. Thanks for updating.
