Hard starting with warm engine
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 48boot, Mar 7, 2017.
  1. Apr 11, 2017 at 10:22 PM
    Oldman808
    Oldman808 Well-Known Member
    Planet Earth
    2023 Taco TRD Sport
    Thanks I learn something everyday from all you great folks here , no wonder Costco gas lanes long . :hattip:@Herniator
    Herniator[QUOTED] likes this.
  2. Apr 11, 2017 at 10:22 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yea sometimes temp sensors can make them flood when hot..
  3. Apr 11, 2017 at 10:27 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If temp sensor shorts out it can make the fuel system think it's neg 40 degrees out. It will go full rich and flood the engine. The next time it happens get someone to crank it while you stand near the tailpipe and watch the exhaust when it finally starts. If you see a cloud of black smoke its getting flooded..
    Try cleaning the maf..
    Ask the dealer if there is any software updates available that address hard hot restart s..
    48boot[OP] likes this.
  4. Apr 11, 2017 at 10:49 PM
    48boot
    48boot [OP] Well-Known Member
    Minnesota
    2016 Grey Tacoma TRD OR Access cab 4x4
    Yeah, could be. I have to think the techs were looking at those things, but who knows? When I talked to the service writer, I mentioned the possibility of a bad sensor, and they did replace the CPS. The dealership has been in contact with the Tech Line looking for a solution. It doesn't seem like it should be this difficult...but what do I know, I'm not the expert.
  5. Apr 19, 2017 at 11:14 PM
    48boot
    Minnesota
    The fuel pump was not replaced, they decided to test the pump under several conditions instead. The pump tested ok. The next step is to replace a possible bad number 6 injector. They ordered an injector, will be bringing it back to them next week. Frustrating...
    shakerhood likes this.
  6. Apr 20, 2017 at 12:43 AM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    I'm not sold on the fancy gas idea. I used to think gas made a difference, but after seeing my friend's 4Runner go 450k miles, with a majority of that being from the cheapest ghetto no-name gas station, I lost that thought. Was further supported after seeing the shit fuel overseas that people would use and their vehicles are still running fine. I've always heard about top tier fuels, yet everytime I've seen someone recommend it, it never helps the problem.
    Maybe, there might be a long term benefit, but I'm skeptical whether it really matters.
    OP, my guess was fuel pump, but sounds like that is out. Following to hear the culprit.
  7. Apr 20, 2017 at 4:38 PM
    48boot
    Minnesota
    Checking the list of Top Tier "fancy" gas, I've used nothing but that in the truck, either 89 or 87 octane. It appears I'm the only one here with this persistent problem; it's like I won the lottery...
  8. Apr 20, 2017 at 4:54 PM
    BCSpazer
    BCSpazer Well-Known Member
    2020 Tundra TSS Off Road
    I'm late to the party and it's a shot in the dark, but I had the same problem with mine right from the start - I eventually figured out it was me not the truck. I was used to my previous truck that electronically controlled the starter run time which the Tacoma doesn't do, so I was "bumping" the starter thinking it would run on its own to start. Once I learned to go back to old school run the starter until it fires I haven't had the problem.
    -BC
    Edit: In addition the action of "bumping" the starter several times actually made the problem worse until the starter had to be run extra long to fire the engine.
  9. Apr 20, 2017 at 5:02 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yea forget about gas.. buy a cheap code puller that will show some data and watch the rpm pid.. If the crank sensor is faulty you will not see the crank signal show up for the first few seconds and then it will show up all of a sudden and the engine will start. If you have a crank signal or RPM signal same thing it will show from the very first second you start cranking
    opentang likes this.
  10. Apr 20, 2017 at 5:03 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Crank signal /RPM signal (same thing)
  11. Apr 20, 2017 at 5:06 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Short of taking it to the dealer or a repair shop and letting them diagnose it buying your own little code reader would be the smartest thing to do in my opinion. Leave it plugged in to the truck every time you start the truck watch the data and look for the missing ingredient when the problem happens. Crank signal ,mass air flow signal ,Etc
    And by crank signal I mean RPM or engine speed signal.
  12. Apr 20, 2017 at 5:11 PM
    Critical05
    Critical05 Well-Known Member
    2017 DCLB TRD OR
    Previous car which was direct injected, long cranks were an early sign of the high pressure fuel pump going out. Different animal but was/is a fairly common failure on a BMW n54 engine.
    Also, any one know if the 3.5 uses port or direct injection on start up?
  13. Apr 20, 2017 at 7:16 PM
    48boot
    Minnesota
    It's definitely the truck, not me. I haven't done anything different than before the problem surfaced with nearly 12,000 miles on the truck. Also, a Toyota tech and service writer duplicated the problem. It's just not supposed to turn over for many seconds without firing, something is wrong. And, it never does it on cold starts.
  14. Apr 20, 2017 at 7:26 PM
    BCSpazer
    No worries... like I said a long shot but I thought I'd throw it out there!
    -BC
    48boot[QUOTED][OP] likes this.
  15. Apr 20, 2017 at 7:34 PM
    #35
    48boot
    Minnesota
    Thanks, appreciate the input.
  16. Apr 20, 2017 at 9:53 PM
    #36
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I believe the 3.5 is direct injected. Hi pressure fuel delivery could be an issue..
  17. Apr 20, 2017 at 9:56 PM
    #37
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    OP could try adding some propane or starting fluid when long crank is happening and see if it responds/fires off when alternative fuel is added.
    It would require a helper at every hot re-start tho..
  18. Apr 20, 2017 at 11:10 PM
    #38
    48boot
    Minnesota
    Thanks, but I want Toyota to do their job, not me. Besides, the hard starts are unpredictable and it usually will fire on the second attempt. But it has taken as many as four attempts.
    SpeedoJosh likes this.
  19. Apr 21, 2017 at 7:27 AM
    #39
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I hear ya..
    The 4 attempt scenario is a good opportunity to add some fuel yourself and see what happens. The next time it no-starts 1 time, stop trying to start it, have a helper squirt some starting fluid in the air filter housing just as you start cranking it for the second time. If it fires off it is likely a fuel issue. You could even record some video and show it to the service writer or the tech
    Respectfully, this is something to try If You get tired of waiting for the dealer and you want some answers for yourself..
  20. Apr 28, 2017 at 6:40 PM
    #40
    48boot
    Minnesota
    Dealer replaced #6 fuel injector today. After several warm starts the problem seems to be gone. One of the starts was after a 2.5 hour shut down which has been the most problem prone time frame. The invoice has the description "poor starting hot soak". That was the first time they used that description. Hopefully this issue is now history, we'll see:fingerscrossed:. I am thinking of adding fuel injector cleaner to my gas.
    b_r_o, shakerhood and Riding Dirty like this.
