Hard starting
Discussion in '1st Gen. Tacomas (1995-2004)' started by SpeedoJosh, Aug 5, 2013.
  1. Aug 5, 2013 at 10:28 PM
    SpeedoJosh
    SpeedoJosh [OP] Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    So I've been having a hard start issue with the taco. First start in the morning it fires right up in a second. Could turn it off , and it'll fire right back up. But, if I drive around for a little bit, park, then come back later it takes a little bit for it to fire. Turns and turns, then usually has a weak, stumble start. Drives fine once started, just hesitant to start.
    Any ideas?
    98 Tacoma. 2.7 manual.
  2. Aug 6, 2013 at 10:01 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Use some Seafoam. How old are the plugs, and wires(insulators for coil-on-plug)? Check the temp sensors for proper operation. They should change fluidly from cold to hot. If they are reading incorrectly, but still within range, they will not throw a code. It would make for hard starts and bad fuel mileage.
  3. Aug 6, 2013 at 10:46 AM
    SpeedoJosh
    Florida
    Plugs and wires are new within the last 5k or so.
    Seafoam the tank, or seafoam the engine?
  4. Aug 6, 2013 at 12:42 PM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Clean the MAF, that tends to help others w/ similar problems. I took off a hose on my Charcoal canister once and it was hard to start because all the pressure was released, maybe you have a pressure leak.
  5. Aug 6, 2013 at 4:08 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    I agree with these guys in this order:
    1) Seafoam (cheap and easy)
    2) MAF Cleaner (cheap and easy)
    3) Temp sensors.
    I had a temp sensor go bad in my beater-1986-Accord and it would start on the first crank, but if the car got warm, it wouldn't restart for hours. My sensor failed in such a way that the sensor was saying the engine was cold, which was true on the initial crank. On a hot restart, the sensor was still saying it was cold and was flooding the engine.
  6. Aug 6, 2013 at 7:41 PM
    SpeedoJosh
    Florida
    Right on. I know the MAF is clean. Cleaned it last oil change.
    For the sea foam, is that just the normal bottle in tank, or are you guys meaning adding it to the engine?
    Temp sensor, I'll have to bust out the haynes for that. Hard swap, or pretty quick?
  7. Aug 6, 2013 at 8:15 PM
    TacomaJPP
    East TN
    03 4WD TRD XTD Cab
    Seafoam should be used by sucking some in through a vacuum line into the intake (1/3 of a bottle is what I believe the instructions say) and the rest into the tank.
    Temp sensor is easy. I haven't checked on the actual locations on our trucks. I will check tomorrow. Basically, unplug electrical connector and screw it out. Nothing to it.
  8. Aug 7, 2013 at 11:35 PM
    Loggerhead
    Loggerhead Well-Known Member
    Seán
    Alaska
    2002 SR5 TRD 5spd 3.4 Xtra Cab
    If none of the above, perhaps it could be the fuel pump dying out ?
  9. Aug 8, 2013 at 8:27 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    On my '99 3RZ, from what I've read, the air intake temp sensor is built in to the MAF sensor.
    And there are 2 coolant sensors. The one for the ECM is at the back (bitch to get at), and the one for the gauge is where the upper rad hose attaches to the block.
  10. Aug 8, 2013 at 8:38 AM
    SpeedoJosh
    Florida
    I feared that, but wonder why it works without issue first crank, then acts up when warm.
  11. Aug 9, 2013 at 10:00 PM
    Bahamayellow
    Bahamayellow Well-Known Member
    2002 tacoma sr5
    Hello mine has the same problem from time to time. Starts fine like it should most of the time then stumbles like an old car, but still starts. Lol I have a 2002 tacoma and its been doing it for 8 to 9 years now. It's a 3.4 with 100k miles. I use bg44k and that seems to help. Mine just happens once in awhile and hasn't thrown any codes so far.
