Hard starts when hot
Discussion in '1st Gen. Tacomas (1995-2004)' started by tortoise_taco, Nov 14, 2020.
  1. Nov 14, 2020 at 12:08 PM
    tortoise_taco
    tortoise_taco [OP] Well-Known Member
    battle born
    1996 2.7L 4x4 / 2013 SR5 V6 4x4
    the good ones
    When the engine is hot and my truck sits for 10-15 minutes, the engine will crank and crank but not start on the first attempt to restart it. This is accompanied by the smell of gas.
    It always starts up after a long crank or on the second or third attempt, but the issue is still concerning to me because I worry that it will get worse or put stress on other engine components.
    I already replaced the fuel pump (Denso), as well as the strainer, gasket, and fuel filter (Toyota). Things improved a little bit, but the same issue will still come up sometimes when the engine is very hot.
    I took it to a mechanic to diagnose the problem. They told me that the issue had to be with the new fuel pump I installed and encouraged me to buy a new one under Denso's warranty. They read low fuel pressure (10psi when spec is 38-43 or something like that) at the fuel filter, which is what they based their recommendation on.
    What I don't understand is how the new pump would be defective in exactly the same way as the old one. I would assume that if it was defective, it would have other issues but I haven't really experienced any other symptoms of a bad fuel pump. There does seem to be a louder whine coming from it than from the old one, I assumed that was just the newer unit working correctly.
    So, should I warranty out the one I installed and try again? Or is there something else that could be causing low fuel pressure and hard starts when hot that I'm missing? Injectors? MAF? Fuel lines clogged somewhere? Gas tank issue or something wrong with a different component of the fuel pump assembly?
  2. Nov 14, 2020 at 1:14 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Any check engine light?
    EVAP codes can cause flooding at hot starts. P0446 P0442
    Faulty fuel tank vapor pressure sensor or open Purge Selnoid
  3. Nov 14, 2020 at 2:09 PM
    tortoise_taco
    battle born
    the good ones
    No lights. Only recent one was a lean code that went away after cleaning the MAF.
  4. Nov 14, 2020 at 2:15 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Hard starts when hot is a common symptom of leaky fuel injectors. When the engine is shut off the injectors continue to leak fuel making it hard to start until the leaked fuel has evaporated. Meaning cold starts are usually normal, and the hot ones harder.
    Might also explain the smell of gas
  5. Nov 14, 2020 at 2:19 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Had this issue in my old GMC, which was one of the reasons I ultimately traded it in. Mine would often start and then the RPMs would jump several times before stalling and then it would have a hard start. Replaced the manifold, which was cracked, and that also replaced one of the cats. The issue got better, but never fully went away. I wasn't able to look into the fuel injectors though because of their location.
    tortoise_taco[OP] likes this.
  6. Nov 14, 2020 at 2:21 PM
    tortoise_taco
    battle born
    the good ones
    That makes a lot of sense.
    I'll look into injector replacements or rebuilding before I redo the fuel pump, I think I saw that Motorwest was supposed to be good
    RedWings44 likes this.
  7. Nov 14, 2020 at 7:59 PM
    Allex95
    Allex95 Well-Known Member
    allex
    96 Tacoma 4x4 2.7l 4 cylinder
    I recently had this issue with hard starting and actually my problem was the battery. I guess the other battery wasn’t giving enough to the coil to fire right away. I had good fuel pressure and smelled gas on start up. So it was getting gas but wasn’t getting spark. Mine started fine in the morning as well
  8. Jan 30, 2024 at 2:35 PM
    HoytBurrass
    HoytBurrass Member
    1997 Tacoma 2.4L 2WD manual trans
    Having a similar problem....did you ever get resolution? and if so what was cause?
  9. Jan 30, 2024 at 6:52 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Injectors for me rectified my Hot no Start
    But
    There is a plethora of easier fixes if you search
    I went through them
    Took chance on injectors
  10. Jan 30, 2024 at 7:09 PM
    HoytBurrass
    HoytBurrass Member
    Thanks for the update....My Taco is at 338K miles and we are working our way through issues....when it runs it runs great, but this starting thing is a nagging problem....I'm close to just deciding it is injectors....did you do the job yourself or pay a shop? and if you did it yourself how was it?
  11. Jan 31, 2024 at 3:19 PM
    ControlCar
    Steven
    Sugar Land TX
    Not too bad
    Lemme find my thread
    Now I come from the school….
    “If your in there….might as well do everything “
    I did
    But not my DD…..prepping mechanically for 16yr old
    thread will definitely help you with my trials and tribulations
  12. Jan 31, 2024 at 3:22 PM
    ControlCar
    Steven
    Sugar Land TX
  13. Jan 31, 2024 at 3:23 PM
    Bishop84
    Bishop84 Well-Known Member
    Sure fire way to test injectors is to remove the rail with them seated in the rail then turning in the key, you’ll be able to see if there’s any leak.
    a borescope in the cylinders works as well but you need one capable of side view.
    this sounds like evap purge issue or excessive carob to me personally
    ControlCar likes this.
  14. Jan 31, 2024 at 3:26 PM
    ControlCar
    Steven
    Sugar Land TX
  15. Jan 31, 2024 at 3:32 PM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    Mine was a fuel pump when I had the same issues
  16. Jan 31, 2024 at 5:30 PM
    Glamisman
    Glamisman Well-Known Member
    In order for the fuel pump to develop any pressure there has to be a restriction in the “system”. In a properly working system the fuel pressure relief valve and the injectors provide that restriction. If the injectors leak and the pressure relief is bad then inadequate pressure wont develop. The other rare issue is the fuel line from the pump to the metal outlet tubing inside the tank. It should be a fuel line rated to be submersed. I have seen this mostly on vehicle that sit for extended periods, the line just goes soft and then a tear develops and you dont notice it until you pull the fuel module out.
