Hard "THUNK" when letting off accelerator
Discussion in '1st Gen. Tacomas (1995-2004)' started by NativeTXNsurfer, May 18, 2021.
  1. May 18, 2021 at 9:34 AM
    NativeTXNsurfer
    NativeTXNsurfer [OP] Member
    Dust
    1999 Tacoma Prerunner SR5 2WD
    None
    I love my truck but I'm getting a really hard "THUNK" when abruptly letting off the accelerator. Almost as if the engine is in a bind and then resetting. I'm leaning toward either bad engine mounts, or something transmission related (?clogged torque converter or front differential mounts?).
    Originally I thought it was the inherent binding "thunk" these 1st gens have when coming to a stop, and then letting off the brake pedal. But after the rear portion of the drive shaft literally fell off in transit a few months ago, and then having a completely new one installed with new U joints as well, I ruled that out as the culprit since that binding thunk at a stop and brake release went away.
    Now my main issue is the hard "THUNK" when letting off the accelerator. If I let off gingerly, it doesn't do it. Any suggestions or experience with this same issue?
  2. May 18, 2021 at 9:38 AM
    Madjik_Man
    Colorado Front Range
    If you search “axle wrap” and “slip yoke” here you might find that either one of these could be your issue.
    How many miles are on your rear leaf springs?
    2004Taco likes this.
  3. May 18, 2021 at 9:44 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Definitely not the front differential on a
    2wd.
    MalinoisDad likes this.
  4. May 18, 2021 at 9:51 AM
    johnny3
    johnny3 Well-Known Member
    01 Tacoma TRD
    probably worn-out rear leaf springs ( axel wrap) very common.
  5. May 18, 2021 at 10:04 AM
    NativeTXNsurfer
    Dust
    None
    Thanks for the replies. Truly appreciated \,,/:rockband:\,,/
    249,000 miles on the rear leafs (and slightly sagging now that I have a camper shell, even more-so when fully loaded with camping gear). I thought the same as far as the axle wrap is concerned. The slip-yoke is brand new as well. That was the part of the driveshaft that fell off in transit a few months ago, so I had it replaced including the U-joints front-to-back. I dropped the driveshaft, replaced the carrier bearing and tranny mount myself about two years earlier trying to remedy the thunk (didn't solve shit). I recently serviced the rear diff as well, and it's as clean as can be. No shavings whatsoever, and no leaks so it's not that either.
    Been scoping out the Old Man Emu leaf upgrade, but I've heard it rides like a go-cart afterward. One mech suggested airbag suspension for a better ride. Finances are extremely tight atm, so I'll likely go with the least expensive while still sticking to quality parts.
  6. May 18, 2021 at 10:05 AM
    eon_blue
    Azusa, CA
    I wouldn't rule out the rear driveshaft even if it was just replaced, could be a chance something wasn't torqued right or greased properly...just saying, it's worth looking into.
    It does kind of sound like axle wrap, I've never felt it on my manual trans 04, but I had a 1999 auto Prerunner that got axle wrap real bad. Except for me, it was a big THUNK when coming to a stop. Soon as I completely stopped it would feel like I got tapped from behind by another car.
    The way it was explained to me was that the stock leaf springs, esp when they get tired, tend to twist a little and release that tension when you come to a stop or let off the throttle, etc. You feel that thunk throughout the entire truck.
  7. May 18, 2021 at 10:09 AM
    NativeTXNsurfer
    Dust
    None
    Willing to bet it's axle-wrap. These leafs are definitely tired... Likely going to purchase a good upgrade set and see if that solves. If not, at least it won't have that fugly sagging ass afterwards.
  8. May 18, 2021 at 11:13 AM
    56killa
    56killa Well-Known Member
    2004 Double Cab TRD 4WD
    Im at 151k miles and I have narrowed the exact same problem down to axle wrap. Some helper springs removed the issue, but I didnt like the fitment of them so I am just looking to replace the entire leafs on each side. Some new shocks helped a little bit too but as others have mentioned its mostly likely axle wrap and some new springs will likely fix it.
  9. May 18, 2021 at 11:47 AM
    01Montaco
    01Montaco Well-Known Member
    Matthew
    Montana
    2001 Red Tacoma TRD SR5
    Had the same problem. Motor mounts looked fine when I took them out but the driver side one was split about halfway through the rubber when I torqued on it in the bench vice. Replaced the mounts with ones from @Bonzen mounts and my thud is completely gone
    Bonzen likes this.
  10. May 18, 2021 at 11:50 AM
    eon_blue
    Azusa, CA
    yeah since his is when letting off the accelerator that's the reason I am skeptical of it being axle wrap....for me, axle wrap happened when coming to a stop for the most part. Broken motor mounts would definitely cause a thunk when letting off the gas, I would imagine. Engine settles back into place more violently
    Bonzen likes this.
  11. May 18, 2021 at 11:51 AM
    eon_blue
    Azusa, CA
    With axle wrap, it was a very clear feeling of it happening from the rear, like getting lightly rear ended
  12. May 18, 2021 at 2:38 PM
    01Montaco
    Matthew
    Montana
    Agreed, when it was happening to me it was just a noise that sounded like it was coming from beneath me whenever I would let off the accelerator quickly or downshift without rev matching.
    It never had a feeling to it, i.e. Suspension unloading.
    The only other thing I noticed with it was a surging feeling if I was accelerating quickly and let off the clutch too fast shifting to 2nd.
    My best guess is that it was the motor flopping around a bit and not sending all the power down the drive line
  13. May 18, 2021 at 3:36 PM
    Strostkovy
    Strostkovy Well-Known Member
    Alex
    White 98 Tacoma
    My bed hits the cab when I'm hard on the throttle.
  14. May 18, 2021 at 3:39 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Go simple, check/lube U joints
  15. May 20, 2021 at 8:40 AM
    Bonzen
    Bonzen Solid Offroad motor & transmission mounts
    Lake Havasu City
    The Silver Bullet
    Everything.
    I'm currently working a big contract with a company that provides off road driver training to civilians and military. They have a dozen tacoma trucks 1st, 2nd, 3rd Gen as well as some 4runners - every single truck had bad motor mounts, and some had frame damage from the bad motor mounts. They didn't even know until they started heading "clunks" and then got under the trucks and inspected them. And same thing, they thought the mounts on some of the trucks looked ok until they removed them and noticed the rubber pucks were broke in half.
    They are replacing all of them with Solid Offroad mounts, even on the brand new 3rd Gens. Prevention is key! :thumbsup:
  16. May 21, 2021 at 7:59 AM
    moerose
    moerose Well-Known Member
    James
    98 sr5
    Lifted,33”2.7L turbo charged
    Check all your rubber mounts..trans engine etc
    Bonzen likes this.
  17. May 21, 2021 at 8:13 AM
    AmherstAndy
    AmherstAndy Well-Known Member
    Andy
    Masshole
    2003 2.7L 5 speed, 4x4 J shift, Xtracab
    Look under the hood with the engine running and rev it a few times...can you reproduce the thunk this way? Observe excessive engine movement?
    Bonzen likes this.
