Hard time reading oil dipstick
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JARStacoma, Nov 3, 2017.
  1. Nov 24, 2022 at 2:04 PM
    #81
    TacosOnly
    TacosOnly Member
    What you're doing worked for me. Just make sure you take your reading carefully..
  2. Nov 24, 2022 at 2:12 PM
    #82
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    Are you sure there's even oil in it?
  3. Nov 24, 2022 at 2:25 PM
    #83
    tylermoney
    tylermoney Member
    2013 TRD Sport 4x4
    No modifications yet. Bone stock... well, I do have the K02 all terrain tires. I will be looking into some suspension upgrades in the near future and depending on how much off-roading I get to do, probably some skid plate protection.
    There is definitely some oil in it for sure. I did not release 5.5 qts worth. But maybe 2-2.5 at the most if I had to guess. Just a weird issue I wasn't expecting to have to think about.
  4. Jan 6, 2023 at 2:00 PM
    #84
    tacos4u
    tacos4u Active Member
    I just pull it and wrap paper towel around it then I can lay dipstick beside it and know the reading. Usually do it cold or warm not hot.
    Bosshoag and davidstacoma like this.
  5. Jan 6, 2023 at 5:32 PM
    #85
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    New tacos do eat oil. GDI + PCV leakage on inclines can add up.
  6. Jan 2, 2024 at 4:26 PM
    #86
    Bosshoag
    Bosshoag Well-Known Member
    Mr. Doogan
    Virginia Beach, VA
    '20 4X4 TRD Off Road MT
    I'm here for knowledge folks, please feel free to inform me. Expedition Essentials Track Mount Weather Tech floor liners and window vents K&N air filter Summit Dakars in Matte Bronze -25 offset King suspension from Filthy Motorsports MESO customs white/red interior lights and MESO customs gasshole
    I’ve read a few TacomaWorld threads in full on this topic and now I have “THE ANSWER!” For an accurate reading, run your truck for a bit to get it to operating temperature (when temps increase stuff expands so nice always been told to check oil on a warm engine.) Pull the dip stick, wipe it off, and let it sit for 5 minutes or so to let the oil drain down to the pan and out of the dip stick tube. Grab your stick, get it started in the tube, then before you get too deep, thrust it all the way in until it’s fully inserted, and pull it out immediately. With the end pointed down, quickly set it down on a blue shop rag paper-towel, and rotate it once so you can see the wet oil mark on the rag compared to the oil level markings of the stick right next to each other.
    If anyone is interested, I’m willing to take some pictures or something to assist with this. It can be frustrating. I also made cross hatched etching on the tip of my stick which wasn’t totally necessary after using the method above.
    davidstacoma and bulalo like this.
  7. Jan 2, 2024 at 4:45 PM
    #87
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    Seems like a lot of work when all you have to do is sand the bottom 4-5" of the dipstick with coarse sandpaper. Then you can read oil level even with new oil.
    musicisevil likes this.
  8. Jan 3, 2024 at 10:40 AM
    #88
    a4shawn
    a4shawn Member
    Well this was a timely thread for me. Two days ago I taught my 17yo to change his oil for the first time. We put what I thought was 6.2Q in and was astonished to see that it look like I significantly overfilled it when I checked the oil. This morning, I drained about 3/4 quart out the pan checked the oil a while later and it still read overfull! Time to google. This thread was very helpful. I wound up sanding the dipstick and doing the 'quick thrust paper towel' method (well that sounds interesting) outlined by Bosshoag. Those methods combined let me fill/check/fill/check until I was comfortable. Turns out I had to put in about as much as I took out. Hope this helps someone - it's crazy that the dipstick is so hard to read.
    Bosshoag likes this.
  9. Jan 3, 2024 at 12:36 PM
    #89
    C0ma
    C0ma Well-Known Member
    FYI to anyone, and I don't know if this has been discussed, but my 2GR-FKS does not like 6.1 quarts. Putting that much in exceeds the top mark of the dipstick. Therefore, 5.5 qts works just fine for me.
  10. Jan 4, 2024 at 12:42 PM
    #90
    Bosshoag
    Mr. Doogan
    Virginia Beach, VA
    I can’t take credit. My post was just a compilation of great ideas from other members across various threads about difficulties reading the dipstick that worked out for me, which is why I reposted over a few threads to answer the question on all of them in case someone clicked the wrong thread… Glad it worked for you!!! Great feeling to have confidence in your oil level.
  11. Jan 5, 2024 at 11:19 PM
    #91
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    Take the dipstick out first before you drain the oil that way the tube has time to drain out after you fill it. Sanding helps too. 6 QTs total including pre filling the filter was spot on for my first change. I check it after the needle starts to move off cold.
    RomeoGolf likes this.
  12. Aug 11, 2024 at 6:27 PM
    #92
    RomeoGolf
    RomeoGolf Member
    Rick
    2013 Tacoma Double Cab 4wd with Leer Cap
    Bilstein B8 5100's and Add-A-Leaf
    Totally worked for me. Sanded it so there would be a horizontal scratch pattern, and left it to sit for several hours without the dipstick in. Worked like a charm.
  13. Aug 11, 2024 at 6:27 PM
    #93
    RomeoGolf
    RomeoGolf Member
    Rick
  14. Aug 11, 2024 at 6:49 PM
    #94
    RayInAalaska
    RayInAalaska Well-Known Member
    Alaska's interior (near Fairbanks)
    2023 Tacoma TRD Off Road, sort of green color
    over60 is correct.
    I haven't read the manual of my wife's Tacoma, but I am fully aware that the manual shows a certain amount of oil with filter replacement, and a different amount of oil without filter replacement. So if I am replacing the oil and filter I just add the proper amount of oil, run the engine until it warms to normal operating temperature, shut it down, then lift the dipstick about an inch or two and leave both the stick and the hood like that. The next step is to wait about 5-10 minutes to let the oil drain into the filter and pan, then wipe the oil from the stick and check the oil level. The truck has to be on a level surface, of course. Just don't close the hood and forget the dipstick lifted :fingerscrossed:
    I always doublecheck every component I touch when I change oil and filter (oil filler cap, oil filter cap or housing for tightness, oil drain bolt, dipstick, and so on), all before I drive the vehicle.
    By the way, my wife and I have four Toyota vehicles: Tundra 5.7L, Tacoma TRD Off Road, RAV4 V6, and Corolla. All are difficult to tell the exact oil level unless I do it as mentioned above. I have owned a 2009 Forester, and it was exactly the same. Check the oil level on the road or uneven ground, and you will never figure the correct oil level ;)
  15. Aug 11, 2024 at 7:14 PM
    #95
    RomeoGolf
    RomeoGolf Member
    Rick
    Happy to learn this- I usually change my oil around 4ish-k miles. My truck burns about 1/2 a quart over about 4k miles, and until I did the sanding and removing dipstick, I never once got a reading I was confident in. I have never changed my oil without changing the filter, but I have thought about changing the filter at 2.5k just because it is so easy to do on my 2013 Tacoma.
  16. Aug 11, 2024 at 7:19 PM
    #96
    Williston
    Williston Unknown Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    They all do it. Dunno about the other generations, but my 2014 does this. I check the oil after a change before I even start it. Even with a new (dry) oil filter and with 5 qts in it, reads high/above the top dot. Same after starting and running it FWIW.
    I gave up worrying about it 30,000 miles ago.
  17. Aug 11, 2024 at 7:42 PM
    #97
    RomeoGolf
    RomeoGolf Member
    Rick
    I was a bit alarmed when I'd drain it and get 5Q out, after putting 5.5Q in. Today, with the new "vodoo" at 2k since the last change, shows a bit high, above the top dot. Not sure if a 1/2Q low would even register... Have to get a real reading at my next change. More a matter of curiosity and happy to get a reading that isn't a foot long smear.
  18. Aug 15, 2024 at 1:58 PM
    #98
    manfred twd
    manfred twd Active Member
    mike
    2021 trd takoma
    I have my oil changed at the dealer. It costs me about $25 more but I don't have a good area to do it myself. I changed dealerships because the one I was using never filled it up and I had to add 1/2 quart every time. The new dealership fills it to the full mark.
    I guess 1/2 quart every oil change adds up for the dealership.
  19. Aug 15, 2024 at 3:05 PM
    #99
    cooldad
    cooldad Well-Known Member
    JimBob
    2021 red TRD Sport
    Mine has this annoying feature as well. I had just assumed that I had unknowingly developed an LSD addiction and was seeing things :duh:
  20. Aug 15, 2024 at 3:45 PM
    #100
    canuck guy
    Alberta
    23TRDOR
    A vehicle does not need to have oil all the way to the top of the dipstick. The dealership that filled it that way did nothing wrong. It's actually better than overfilled. 1/2 quart shy of totally full is just fine unless you're too picky.
