Hard time reading oil dipstick
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JARStacoma, Nov 3, 2017.
  1. Aug 15, 2024 at 4:10 PM
    #101
    RomeoGolf
    RomeoGolf Member
    Rick
    2013 Tacoma Double Cab 4wd with Leer Cap
    Bilstein B8 5100's and Add-A-Leaf
    I am lucky enough to have a garage I can change my oil in, which I do because I'm cheap! I can do oil, oil filter, air filter, and cabin air filter for about $85. And then I also wallow around underneath, greasing it, and getting grease everywhere. Irritating that the dealer would underfill it- I would just want it filled to Toyota spec, not their eyeball...
  2. Aug 15, 2024 at 4:55 PM
    #102
    wfo479
    wfo479 Well-Known Member
    NE Ohio
    2020 TRD Pro
    Blasted the tip in my spark plug cleaning blaster. Shizam i can see the dang eral mark now
  3. Aug 15, 2024 at 5:12 PM
    #103
    cooldad
    cooldad Well-Known Member
    JimBob
    2021 red TRD Sport
    My owner's manual specifies ~6.1qt. My biggest gripes are removing the skid plate and the use of a cartridge oil filter. What is this, the 1940s?
  4. Aug 16, 2024 at 4:54 AM
    #104
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    I don't mind the cartridge filter at all.
    The drain plug is a nice addition for shade tree mechanics working without a lift.
    A bag of cheap cat litter is an absolute must for absorbing drip spots.
    I had to send our 2016 RAV back to our local shop to have them break loose the cartridge.
    They had Godzilla with an impact gun working there the last time, and mine was installed so tight my electric impact gun would not remove it.
    The shop fired Godzilla, comped me to a filter and torqued it back to 18 ft-lbs as it should be.
    I prefill my cartridge when the new filter is in place.
    This avoids a temporary dry-run while the cartridge fills with fresh oil on the first start.
    I also appreciate the vertical filter orientation, as it does not drain down like side mounts or upside down mounts do.
    I tried using the plastic tubing method to read my dipstick level.
    This is nearly as problematic as the bare unsanded stick.
    Plus it leaves me with an oil covered tube that I have to manage.
    Next, I will try the paper towel method shown above.
  5. Aug 16, 2024 at 5:06 AM
    #105
    RomeoGolf
    RomeoGolf Member
    Rick
    Some people are hypnotized by the ugga-dugga!! I found that taking the dipstick out for a while really worked for me. It allowed the oil in the dipstick tube to drain down, and since I sanded the dipstick I got the first actual clear reading I have ever had with this truck (since 2018)! Also, on my 2013 Tacoma, the oil filter is on the top of the motor, and easily accessible. That is a small miracle in itself...
  6. Aug 16, 2024 at 7:21 AM
    #106
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    I don't know where the hell the dipstick is cause I don't change the oil myself.
