hard time starting then shuts off changed fuel pump,( no sound from pump)2005 Toyota Tacoma 2nd gen
Discussion in 'New Members' started by roxy1, Nov 2, 2019.
  1. Nov 2, 2019 at 9:39 PM
    roxy1
    roxy1 [OP] New Member
    vrej
    I have a Toyota Tacoma 20052nd gen v6. When you start its a hard start then runs rough and shuts off. Have changed fuel pump, fuel pump relay, crank and cam sensor, ( the fuel pump does not make hum sound when ignition turned on), thanks
  2. Nov 2, 2019 at 10:13 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
  3. Nov 3, 2019 at 5:14 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard
    buckhuntin-tacoma likes this.
  4. Nov 3, 2019 at 6:17 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
  5. Nov 3, 2019 at 10:23 AM
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    Did you put a pressure gauge in there to verify you aren’t getting fuel pressure? Or just diagnosing via lack of sound?
    Any CEL?
    Able to run while spraying starting fluid into throttle body?
  6. Nov 5, 2019 at 4:58 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW! Throwing any codes? When is the last time you changed the spark plugs and cleaned the MAF?
  7. Nov 5, 2019 at 2:53 PM
    BIGorca4419
    BIGorca4419 Member
    Georgetown Texas
    2019 cement grey Tacoma LB TRD off road
    None yet
    So my step dad just went through what you just described on his 2005 2nd gen. He replaced the fuel pump with a aftermarket fuel pump. Worked for a day and the same issue persisted. Now on the second tow to the shop they concluded that the second fuel pump went out. They then installed a OEM Toyota fuel pump and it’s good as new. It seemed that they are sensitive to oem fuel pumps. Hope this helped.
