Hard to get into 1st
Discussion in '1st Gen. Tacomas (1995-2004)' started by Max-4_Yota, Mar 3, 2010.
  1. Mar 3, 2010 at 2:29 PM
    Max-4_Yota
    Max-4_Yota [OP] The Welfare Cadilac
    Michael
    South Carolina
    3rd gen Tacoma
    Chicken lights, chrome and smoke tunes.
    I've got a 2004 V6, 5spd and on a cold day it is hard to get it to go into 1st gear and if im rolling slow and try to put it into 1st sometimes it will grind, it only lasts about 5mins though and after that it will shift fine. does anyone know about this or have a similar problem?
  2. Mar 3, 2010 at 2:31 PM
    Reepur
    Reepur Well-Known Member
    Brevard, NC
    '10 RC Black 4x4 2.7L
    265/75/16 BFG KM2 's on XD Hoss's 2.5" lift/4xBillies, OME 885's, Firestone Ride-Rites Desert Specialties UCA Volant CAI Grillcraft Grill Kobalt Slim Line Box Weathertech mats and Ventvisors. DTRL mod. 4 Lo -Trac Mod. Int. Wiper Mod. rcbs204 4x4 LEDS URD Short Shifter Plate Front bumper with Smittybilt XRC8000 winch Body Armor rear bumper with swing out tire carrier. ATO Front Skid Ultragauge BHLM
    I have the same issue on my '10 4 cyl 5 spd. It does not do it all the time, but enough to be annoying. I do not have an answer to this.
  3. Mar 3, 2010 at 2:33 PM
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    I found that the Redline MT-90 gear oil in the tranny helps a lot!!
  4. Mar 3, 2010 at 2:35 PM
    Reepur
    Brevard, NC
    I will go all synthetic when the next oil change is due.
  5. Mar 3, 2010 at 3:58 PM
    Apple X C0re
    Apple X C0re Atomic Punk
    Josh
    Franklin, NC
    01 Tacoma SR5 4x4
    De-badged, MetalMiller grille emblem, brush guard, K&N Intake, Thrush tube, Black euro tail lights, Various scratches, Cobra 29LTD CB with custom echo board, 10" sony subwoofer with MTX amp, Black low-profile tool box, 5% tint all around.
    I give mine time to warm up, usually the fluids are just cold.. and if its still not shifting when rolling slow, hit the clutch and rev up a little before you shift down. :thumbsup:
  6. Mar 3, 2010 at 4:00 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Mine does it too minus the grinding. Just stop all the way before putting it in 1st.
  7. Mar 3, 2010 at 4:05 PM
    scocar
    scocar Patron of the Farts
    x2 on the Redline MT90. I just put some in, and it is a lot smoother in the lower gears.
  8. Mar 3, 2010 at 4:08 PM
    Vectorit
    Vectorit Well-Known Member
    Southern California
    TRD SR5
    King coil overs, Total Chaos uppers, Snugtop
    Whenever I experience trouble going into 1st or into reverse, I just throw it into second gear. Then to the gear I want to go into, just don't force it.
    Pretty typical of manuals to do this.
  9. Mar 3, 2010 at 5:17 PM
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
    how hard is it to change and where do i buy the oil???
  10. Mar 3, 2010 at 5:26 PM
    ToyoFF1274
    ToyoFF1274 Well-Known Member
    Will
    Georgia
    2008 Silver AC Sport 4wd 6spd
    FLM Pioneer Head, Sirus Radio, 10" Kicker solobaric L7 w/ Bass Inferno amp, Injen CAI Magnaflow Exhaust, Weathertechs, TRD Seat covers, 20% tint 3" toytec lift 885 coils aal Bilstien 5100s 285/70/17 Cooper ST tires
    Its hard to get in gear only because the transmission is simply cold, thus the gear dope is cold which makes it thicker. To ease your problems you must finesse the transmission and synchronize it. You can do this by jiggling the shifter in neutral or putting it in another gear and then going to 1st. If this doesn't work, you can hold the shifter in 1st with easy pressure and slowly let out on the clutch until it falls into 1st gear.
  11. Mar 3, 2010 at 5:26 PM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    If the V6 tranny is anything like my 2.7, its not hard at all to do. Just make sure you loosen the fill nut first to make sure you can get it filled back up before you open the bottom drain nut. I forget what size socket you need, maybe a 24mm?
  12. Mar 3, 2010 at 5:51 PM
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    try lucas possibly, and check the plastic bushing at the end of your shifter, they get old and dry rot and crack/fall apart.
  13. Mar 3, 2010 at 5:53 PM
    Max-4_Yota
    Michael
    South Carolina
    3rd gen Tacoma
    thanks for the input, does anyone know how much fluid goes in the tranny?
  14. Mar 3, 2010 at 7:23 PM
    Idrivetoys
    Yuma AZ
  15. Mar 3, 2010 at 7:49 PM
    "OldManTan"
    Buffalo, NY
    '16 Tundra DC
  16. Mar 3, 2010 at 8:31 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
  17. Mar 3, 2010 at 8:33 PM
    pittim
    Pennsyltucky
    Boujee Prius
    Step 3, picture 2.
  18. Mar 3, 2010 at 8:35 PM
    dwalden2
    dwalden2 HBTFD
    Derick
    Blue Ridge, Georgia
    '05 TRD Offroad V6 6 spd
    SCS Stealth 6 Wheels, 285/70/17 STT Pros, Demello Offroad front bumper, 20" LED Bar, LED Fogs, LED interior lights, Wet Okole Seat Covers, Body Armour Rear Bumper, Smittybilt 10K winch, 3" OME Lift
    My '05 6 spd does it if it's really cold. I just give it time to warm up and it's usually fine. If it does it I usually just roll forward (or backwards, depending on which way I'm facing) and then it'll shift fine.
  19. Mar 3, 2010 at 9:27 PM
    scocar
    Yup. The drain is on one side, the fill on the other. You need to get the aluminum crush washers to replace the ones that will come off. Torque to 27 ft lbs. 24mm socket. The plugs can be stuck on sometimes, so you may want a breaker bar. You can also hit the edes of the plugs with a wire brush and WD40 to help unstick 'em.
    It helps to have a little pump or a suction gun to get the oil in there. You can get one for a few bucks at any Autozone etc.
    The Redline MT 90: I got mine from a local place called Tognotti's for $9.99 per quart. Funny thing about the bottles, they have very narrow necks: the pump I mention doesn't fit too well, so I cut off the top part of the bottle's neck so the pump would fit/work better. Can you tell I just did this two weeks ago?
    While you're down there, just do the transfer, too. Same oil, same plugs same crush washers, same torque. If you don't have these tools, it is a wonderful excuse to buy them. You can use them on the differentials, too.
    And what the other guys said, yeah, sometimes I have trouble getting into reverse when dead still, you just monkey the shifter into 1st, 2nd, whatever, then try again. Standard manual tranny stuff, and this isn't a little sports car. Don't see any reason to try to shift into first when you are rolling.
  20. Mar 4, 2010 at 7:51 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    Just to show it doesn't seem to get any better 6 years later.......
    On my 2010 5 speed if I am going under 10-12 mph the truck lugs in 2nd. Even with blipping the trottle to keep RPMs up it still lugs hard which means I must attempt to shift to first even when going 9mph - very annoying. It does not like to go into 1st(even warmed up) untill almost stopped(which is normal to me) but this makes driving in the city hell. If the car infront slows down too much below 10, I must stop all the way and enter first.
    In most vehicles as long as you are rolling well you can start off in 2nd with no issue. Not the case with this truck. I figured the torque on the 4cyl would not have issues at these low speeds and decent RPMs.
    If the truck would start off in 2nd while rolling under 10 I would have no issue with the difficult 1st gear.
    O well.
