hard to restart after stall
Discussion in '4 Cylinder' started by emacpgh, Nov 21, 2009.
  1. Nov 21, 2009 at 2:18 AM
    emacpgh
    emacpgh [OP] Well-Known Member
    eric
    pittsburgh
    silver streak mica sr5 sport
    Aries stainless steel bull bar , afe pro dry s filter , secondary air filter removal, scangauge II
    i stalled my manual trans truck twice in the last month(going into first gear at a stop light) both times it was difficult to restart. i had to crank it three times before it would turn over. both times it was while the truck was not yet warmed up ( couple of mins. after originally starting it), also both times in was raining. not sure if these two conditions are just a coincidence or not. anyone know what this could be? 7 month old truck. well maintained. chris4x4? you always know the answer to this kind of stuff. lol. i am currently working 7 days a week 12 hrs a day on night shift so im not sure when i will be back on to review any feedback. thans guys.
  2. Nov 21, 2009 at 4:20 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    Mine did the same thing when I stalled it. Just take a second while turni g the truck off wait then clutch In and start it seems if you don't hurry up and do it just take a few more seconds it will fire up quicker.
  3. Nov 22, 2009 at 11:33 AM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    well when you stall you have a lot of unburned fuel and when its cold it tries to add more fuel, compounding the rich fuel condition. It will make the truck much harder to start. nothing abnormal there. The plugs were just wet.
  4. Nov 22, 2009 at 11:40 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    ^^ What he said ^^
  5. Nov 22, 2009 at 11:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    X3. To add: If in this situeation again, before starting, push the accelerator to the floor and hold it there, then start the engine. Holding the accelerator peddle to the floor tells the ECU to keep the injectors "Off", thus not adding any fuel until the engine is started.
  6. Nov 22, 2009 at 11:45 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    also after you stall your fuel pump and injectors continue to pump for a split second until the truck ecu figured out you stalled. the difference when you turn the key off is the electricity is cut to pump and injectors. when you stall they are still running
  7. Nov 22, 2009 at 11:49 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes, but they only spray fuel if a piston is at the correct part of its cycle.
  8. Nov 22, 2009 at 11:56 AM
    Yoytoda
    Roland
    completely stock
    But that would be the first piston that tries to fire on restart so you have to crank to the next cylinder. People with new vehicles tend to panic when it doesnt fire on the first cylinder up. Hard starting problems arent what they used to be. Now if you have to hold the key for more than 2 seconds OMG theres something wrong with my truck. Half the public wouldnt know what to do if they had to pump the pedal to get the accelerator pump going and god forbid if it stalled after starting. :rolleyes:
  9. Nov 22, 2009 at 11:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Agreed.
