Hard to shift 5 speed
Discussion in '1st Gen. Tacomas (1995-2004)' started by 16 Bore, Sep 8, 2023.
  1. Sep 8, 2023 at 4:04 AM
    16 Bore
    16 Bore [OP] Well-Known Member
    ‘02 Ext Cab 2.7 4X4 5sp
    I washed it once or twice
    My old girl has 288k, sometimes just getting into 1st gear is a chore. Have to drop into 2nd and get a little movement sometimes before I can get it into 1st.
    Any thoughts on what I’m dealing with here?
  2. Sep 8, 2023 at 5:10 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Has it always been like this or just started?
    It might be that G59 Transmission I never had one of them.
    It just might be getting tired a combination of worn parts.
    At 250,000 I shift my R150F into first now and then.
  3. Sep 8, 2023 at 5:40 AM
    16 Bore
    Past several years I’d say.
    drewskie likes this.
  4. Sep 8, 2023 at 6:02 AM
    Bivouac
    It kinda comes down to live with it.
    Or a very expensive rebuild a bearing kit might help might need even more parts .
    You can try those gear oils people say improves things.
    Good Luck no matter what course you follow.
  5. Sep 8, 2023 at 6:19 AM
    rglsr
    rglsr Well-Known Member
    California
    So you only have issues with 1st gear? I would start with checking free play at the clutch pedal first. Then check the clutch pedal return spring, if you have the torsion type it may be the culprit. If you have the linear type that's probably OK. Then move onto the clutch master/slave cylinders, before you dive into $$$ clutch/trans work....
    rocknbil likes this.
  6. Sep 8, 2023 at 7:24 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    I'd look here, less expensive and clutch not fully disengaging could be the culprit. In a stupid lapse of reason my clutch fluid had gotten low (with no visible leaks) and it started acting up like this.
  7. Sep 8, 2023 at 7:43 AM
    Bivouac
    Being only first Gear To me says Transmission .
    After a few years a minor hydraulic issue most likely might have gotten slightly worse.
    The fact you can pull it back into second then get first to me rules out clutch hydraulics to me.
    Any problems into reverse when your stopped?
  8. Sep 8, 2023 at 10:19 AM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Mines the same way. Sometimes have to drop it into 2nd then back to first. I’ve never had a manual transmission that just always slid right into first at a dead stop. Either needed to release clutch a bit to give things a spin, or do the 2nd gear thing. Imo it’s normal.
    Bivouac likes this.
  9. Sep 8, 2023 at 4:12 PM
    PeteSATX
    PeteSATX Well-Known Member
    2003, Tacoma, V6, 4X4 MT, SR5, TRD
    None, Original Owner, 130k miles
    I would check the plastic shifter bushing under the shifter. They are known for disintegrating.
    Peter in SA
    scocar, Dalandser and drewskie like this.
  10. Sep 8, 2023 at 4:18 PM
    Bivouac
    :thumbsup::thumbsup::thumbsup::amen:
  11. Sep 8, 2023 at 6:41 PM
    Chungas
    Chungas Help! My Ferret has lost its stank!
    Waylon
    Bushwood CC
    Cocain 2003 3.4 4x4
    Since new, my first gear has always said FU if the ambient temperature has been below ~70°.
  12. Sep 8, 2023 at 6:50 PM
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    This. I can almost guarantee that's the problem, and it's like a $10 fix.
    scocar likes this.
  13. Sep 8, 2023 at 7:17 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  14. Sep 9, 2023 at 10:09 PM
    Taco_Love
    Taco_Love Well-Known Member
    99 reg cab 4x4
    This may not be your problem, but I had a similar issue. Really had to muscle it in to get into first, other gears were fine, eventually all the gears I ended up needing to muscle in. When the truck was off I could row through all the gears just fine. Eventually decided to replace the clutch (what a hassle), now it shifts through the gears like butter. When we took off the old clutch we noticed that two of the fingers were bent forward just a little which I think was causing it.
  15. Sep 9, 2023 at 11:13 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yeah I’d start with the easiest thing first like replacing the shifter bushing, then moving towards something you’d have to do anyway even if you were replacing the transmission like looking at the clutch. I actually had a similar situation but it turned out to be the previous owner improperly installed a short shifter and the end of the shifter was ever so slightly rubbing metal on metal on the surface below it in the transmission. I didn’t find that out until I removed the transmission and swapped another one in. With what I know now I would have taken a slower approach to diagnosing this issue haha.
  16. Sep 9, 2023 at 11:15 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    make sure you are using gl-4 MTF. had this issue using GL-5 fluid.
    1 Limited Toyota likes this.
  17. Sep 10, 2023 at 8:03 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Fluid changes are often waaay neglected
    Does it also grind?
  18. Sep 10, 2023 at 8:06 AM
    1 Limited Toyota
    California
    08 XRunner
    Pretty opionated statement
    cryptolime likes this.
  19. Sep 10, 2023 at 8:10 AM
    Tuluk
    Tuluk Well-Known Member
    1999 trd manual 4x4 ext cab
    Mine does the same. I’ve done The shifter bushing change , the fluid change, running the redline M/T. I saw no real change in the issue. Almost always have to dip into second and blip the throttle to slide it into first, otherwise it’s a hard no. I was under the impression that this was normal for these transmissions .
  20. Sep 10, 2023 at 8:19 AM
    Glamisman
    Glamisman Well-Known Member
    You are going to have to determine if the clutch disk is dragging and turning the input shaft slightly. A stethoscope on the case where the bell housing meets the case is where the input shaft bearing resides and thats shat you are listening for… difficult due to all of the other noises. I have had a few 5 speeds out and apart and everything looks OK, the synchros are sharp, the gears look good, in other words, no problems found. Re install and it is still difficult to get into gear. Take it back out and replace the entire 1-2 gear set assembly, synchros etc and problem solved. It isnt a single component failure it is the assembly as a unit was sloppy. I know this isn't the answer you were looking for but as suggested above, you. Just might have to live with it.
    How many times a day does this happen… you are rolling up to the red light and just as you get there it changes… crap, I cant get it into first and second is just too tall to pull away… crap crap crap.
