Hard to start when cold
Discussion in 'Technical Chat' started by Tmanspd123, Apr 14, 2012.
  1. Apr 14, 2012 at 6:58 PM
    Tmanspd123
    Tmanspd123 [OP] Active Member
    Trey
    Louisiana
    95 Tacoma SR5 4x4
    I have a 95 Tacoma with the 3.0 V6 when it is cold it is hard start. I have to try 3 to 4 times until it starts and then it idles low until I press the gas the it is good. Once it is warm it starts up fine on first try. The engine runs good other than the trouble starting at first. It doesn't leak oil, gas, or coolant. Anyone know what I could try to fix the problem or any thing I can replace. Thanks in advance.
  2. Apr 15, 2012 at 7:05 AM
    Tmanspd123
    Trey
    Louisiana
    95 Tacoma SR5 4x4
    Im pretty sure it is a fuel problem but can't figure it out.
  3. Apr 15, 2012 at 7:50 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Since it is temp-related, I would look at the coolant temp sensor,
    and the air intake temp sensor, assuming you have those.
  4. Apr 15, 2012 at 1:27 PM
    Tmanspd123
    Trey
    Louisiana
    95 Tacoma SR5 4x4
    Thanks for the reply the sensor seem good. I did figure out if I turn the key to on and wait for 30 seconds it starts on the first try.
  5. Apr 15, 2012 at 1:34 PM
    Tacoma Mike
    Southern Maine
    #1 Clean the throttle body.
  6. Apr 15, 2012 at 7:10 PM
    Tmanspd123
    Trey
    Louisiana
    95 Tacoma SR5 4x4
    I will try that and update sounds like a great idea.
  7. Apr 16, 2012 at 7:40 AM
    tan4x4
    Rick
    Folsom, CA
    Having to wait 30 seconds, that could be from the fuel system losing pressure, and the pump taking that long to re-pressurize.
    I'm not an EFI expert, but there may be something like a check valve not working right, or the EVAP system bleeding the pressure off. These trucks should start up almost instantly. Even when cold shouldn't take more than 3 seconds.
  8. Apr 16, 2012 at 5:59 PM
    Tmanspd123
    Trey
    Louisiana
    95 Tacoma SR5 4x4
    I cleaned the throttle body this afternoon and It started on the first try with out waiting at all. It was a little sluggish at first assuming because of the cleaner built up but once I blew it out it was perfect. I shut it off and it started right back up. I'm going to try to start it in the morning (i have a company car so don't drive it everyday) and hope that it is finally fixed for good. Thanks for the advise and if there is any other tips you have for me I'd be glad to try them. Thanks again and I will update again tomorrow.
    Tan4x4 i was planning on having my buddy who's a mechanic check the fuel pressure this weekend because I was thinking the same thing and probably still will have him check it for me just in case. Thanks again I will update and hope cleaning the throttle body fixes it.
  9. Apr 16, 2012 at 6:06 PM
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    maybe try changing the fuel filter. my '88 had the 3.0 and did the same thing
  10. Apr 16, 2012 at 6:20 PM
    Tmanspd123
    Trey
    Louisiana
    95 Tacoma SR5 4x4
    I changed the fuel filter over the weekend. It was definitely time the gas that poured out of the filter was a rust or mud color. Thanks for the tip I think it may all be fixed for now.
  11. Apr 17, 2012 at 5:33 AM
    Tmanspd123
    Trey
    Louisiana
    95 Tacoma SR5 4x4
    I tried to start it again this morning and it did not start good Lin it's supposed to. It is better but not where I'd like it to be. Any other ideas would be greatly appreciated.
  12. Apr 17, 2012 at 7:01 AM
    jtgroce
    jtgroce Got R Did
    maybe try turning key to on for a 15-20 seconds before starting
  13. Apr 17, 2012 at 7:10 AM
    Tmanspd123
    Trey
    Louisiana
    95 Tacoma SR5 4x4
    That works but I want to try to fix that problem.
  14. Apr 17, 2012 at 7:20 AM
    jtgroce
    jtgroce Got R Did
    i understand man. i had my 3.0 rebuilt @ 203k miles but only b/c the front main seal blew and it was leaking oil. but even after that my truck still was hard to start in the cold lol
  15. Apr 17, 2012 at 5:37 PM
    Tacoma Mike
    Southern Maine
    It's possible you have more than one problem.
    like others have mentioned it could be fuel bleed down.
    Keeping the key on for 30 seconds does nothing. Beyond 2 seconds it needs to see inputs from the engine. this is in case of an accident so the pump won't spew 20 gallons of fuel onto a fire.You going to need to do a bleed down test with a fuel pressure gauge.
  16. Apr 17, 2012 at 6:24 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Tmanspd123,
    You mentioned that when you changed fuel filter that the fuel coming out was rusty and muddy in color. I would try the cheap things first, run a bottle of fuel treatment in a full tank of fuel.
  17. Apr 17, 2012 at 7:43 PM
    Tmanspd123
    Trey
    Louisiana
    95 Tacoma SR5 4x4
    I just put a bottle of seafoam in it this past weekend hoping that makes a difference. I plan on checking the fuel pressure hopefully this weekend. All the vacuum lines look good. Hoping I can figure it out soon. Other than this the truck is in great shape. I'm hoping it doesn't need new injectors.
  18. Apr 19, 2012 at 4:53 PM
    Tmanspd123
    Trey
    Louisiana
    95 Tacoma SR5 4x4
    Fuel pump?
  19. Apr 19, 2012 at 5:39 PM
    Tacoma Mike
    Southern Maine
    Without testing things your shooting blind and wasting money.
  20. Apr 19, 2012 at 6:55 PM
    Tmanspd123
    Trey
    Louisiana
    95 Tacoma SR5 4x4
    Good Point
