HARD TO START WHEN COLD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mardoqueo galindo, Oct 21, 2012.
  1. Oct 21, 2012 at 9:08 AM
    mardoqueo galindo
    mardoqueo galindo [OP] Well-Known Member
    marcos
    socal
    08 preruner
    toyota 20" wheels,borla double tip exaust,running boards,K&N air filter.
    hello guys,i need some help with my tacoma DB 2008 V6,44,000 mls when is cold is hard to start,i have to try 3 to 4 times ,when warm no problems at the first try brooom,please any help,i been follow all maintenance schedules,new spark plugs,new K&N filter,every 5000 ml change oil Mobile 1 syntetic whit om filter,gasoline the one in the midle(98 0ctane) i guess
  2. Oct 21, 2012 at 9:13 AM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    Test your battery.
  3. Nov 1, 2012 at 6:58 PM
    mardoqueo galindo
    marcos
    socal
    08 preruner
    thank you mister montana,batery is okay but i'm thancksfull for the time you tuck to try to help me out
  4. Nov 2, 2012 at 11:38 AM
    98tacoma27
    Ben
    Not Beech Creek
    Had any electrical work done? Stereo, alarm, or remote start installed?
  5. Nov 2, 2012 at 12:08 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    your battery could be fine but the cold cranking amps can still be weak or at least thats what I was told can happen with batteries
  6. Nov 2, 2012 at 12:10 PM
    mmorri64
    mmorri64 New Member
    Michael
    Ontario
    2011 V6 4X4 SR5
    Fuel pump....turn your key to the on position and wait a few seconds(5-10) to allow fuel pump to activate
  7. Nov 2, 2012 at 12:52 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Is the engine turning over at a normal speed when cold?
    Just to absolutely eliminate the battery and starter I would have the battery load tested and check voltage drop across the starter cables.
  8. Nov 2, 2012 at 1:01 PM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    Are you running the OEM battery? Find a battery with cold cranking AMPs.
  9. Nov 2, 2012 at 1:13 PM
    jtgroce
    jtgroce Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
    This ^^
  10. Nov 2, 2012 at 3:50 PM
    Gincoma
    Salt Lake City UT
    obviously something is wrong if you have to go that route, but could eliminate possibilites
  11. Nov 3, 2012 at 11:29 AM
    jtgroce
    jtgroce Got R Did
    It does seem to help at times
  12. Nov 7, 2012 at 5:04 PM
    mardoqueo galindo
    marcos
    socal
    08 preruner
    thank you all guys for the answers,i havent' done nothing to the truck,but the battery is not the OM,so im going to double check on that and im going to follow all the advaices THANKS.
  13. Nov 7, 2012 at 8:28 PM
    Gincoma
    Salt Lake City UT
    It may but no one should have to get in there truck and wait for the fuel pump its definitely not normal...
  14. Nov 7, 2012 at 8:31 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Are you kidding me? How could something be wrong if you have to do this? You can't start a truck without fuel.... you wait for fuel pump to prime, then start. Go try starting your lawn mower without pushing the little pump button.... see how long it takes you to start it. The only reason it works 9 times out of 10 is the fact that it can provide enough fuel fast enough. On a cold morning when the pump motor is cold, it might be weaker than normal.
    OP, just give your truck a sec in the morning before you crank it over. Every vehicle has a fuel pump that has to prime the system before it can start. When you immediately turn the key over you're not allowing it much time to prime the engine.... every car has to do this.
  15. Nov 7, 2012 at 8:35 PM
    Dilsky
    Dilsky There go my nipples again!
    Shawn
    Edmonton AB
    07 TRD Sport
    2.5" Fox Extendable Coilovers, LR UCAs, Agri-Cover Larado soft top, Pop'n Lock, 48" Hi-Lift Jack, 20" Incubus Offroad rims
    ^^^This. I just had to replace mine. Lasted me 124,000 kms, but once the weather dropped it started to fail me non-stop. Took it in and had it tested under load, it was only putting out 240 cold cranking amps (rated at 7xx?) After popping in a new one, boom no more problems.
  16. Nov 7, 2012 at 8:40 PM
    Gincoma
    Salt Lake City UT
    First off I never heard of a new vehicle where you have to wait for the fuel pump....regardless what you say its not normal for a new vehicle and second were not driving $30,000 lawn mowers....I get what your saying but I never wait for my fuel pump..only thing I do is let it sit for a minute to get the juices flowing before I take off in cold weather
  17. Nov 7, 2012 at 8:45 PM
    brian
    Elizabeth City, NC
    Since we don't agree on this, I'm going to try and find a reference that says that you SHOULD wait for fuel pump, and lets see if you can find a reference that says we don't have to. I get the same issue every once in awhile since I have the same bad habits. Its always solved by slowing down. I run into people doing this bad habit ALOT, and I've yet to hear anyone say it didn't fix their issues. Fuel pump needs to build pressure....
  18. Nov 7, 2012 at 8:49 PM
    Gincoma
    Salt Lake City UT
    also the fuel system keeps pressure in the lines even after you shut it of. As soon as you start your truck the fuels ready to go that's also why you have a system check a few hours after the vehicle is shut off to moniter pressure. I know first hand when I installed my Supercharger and I changed out the injectors and took off the fuel rails fuel squirted every where due to the pressure in the lines.The fuel doesn't go back like a lawn mower thus why you have to prime before you start a lawn mower
  19. Nov 7, 2012 at 8:52 PM
    Gincoma
    Salt Lake City UT
    As I stated above there's fuel pressure in the lines even after shut off. No need to wait if you have to wait there's a problem
  20. Nov 7, 2012 at 8:53 PM
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    Battery problems.
    1st clean battery terminals and out side of battery.
    2nd charge battery
    If ok that was your problem.
    If not take to dealer to get free battery check.
    This time of the year when it gets colder is when a weak battery will fail.
    You might have a weak cell that works fine when temps warm but not so well.
