hard to start when cold
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dcoursler, Jan 1, 2015.
  1. Jan 1, 2015 at 10:47 AM
    dcoursler
    dcoursler [OP] They call me Tater Salad
    Derrick
    Alabaster, AL
    2012 TRD Off Road
    Currie Rock Jock High Pinion 60, JD Fab EVERYTHING, Fox shocks, Radflo Shocks, Archive Garage all the other things, spinny thing on top of the motor
    I have a '12 v6 double cab base package. nothing done to the motor or intake or air filter even yet. but when it is really cold sometimes it will randomly be hard to start. just wondering if this is common or maybe im just paranoid the truck only has 35k on it
  2. Jan 1, 2015 at 10:52 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    battery may not have enough cca
  3. Jan 1, 2015 at 10:56 AM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    My Tacoma cranks harder than almost any modern truck I can think of when started in the cold. That being said it always fires relatively quickly and once it does there's no hesitation so I think it's just a characteristic of the motor.
    As already said, a higher CCA battery might help you feel better but as long as the motor is catching in the first couple of seconds I wouldn't worry about it. Consider installing and plugging in a block heater and running synthetic oil as well. All of those things lead to easier cold starts.
  4. Jan 1, 2015 at 10:56 AM
    DanceswithWolves
    DanceswithWolves palabra a tu madre
    Jerry
    Roosevelt UT
    13 DCSB OR
    Switch to synth oil and get a battery with better suited cca
  5. Jan 1, 2015 at 11:01 AM
    cyakker
    cyakker Well-Known Member
    SD (at least we're not Mars)
    2015 AC, TRD-OR, V6
    Curious as to what your definition is of "really cold" in Alabama. That might help diagnose. Mine was a little slow to start last couple of days at around -15F, where "slow" means 2-3 seconds instead of instant.
  6. Jan 1, 2015 at 11:44 AM
    kegman
    kegman Well-Known Member
    Ron
    Regina sask canada
    tacoma trd 4x4 2007
    i think we need more info to help you better.For example when you turn the ignition on does the engine really turnover slowly or does it turn over fast but just doesnt fire quickly?If it turns over slowly you should get a load test done on your battery.Really cold to me would be -35 F.If it turns over fast but just doesnt fire quickly it is not the battery.
  7. Jan 1, 2015 at 5:39 PM
    gearcruncher
    Canadain bumper technician
    Just did the spark plugs on mine at 100,000 km or 60,000 miles . The spark plugs were original and the gap had worn to .60,000 from the factory specified .40,000 gap .
    The throttle body and mass air flow sensor were very dirty .
    The factory 2010 battery was completely shot when load tested .
    Had the hard start while cold ....same issue as OP .
    Truck now starts at -50 below , better on fuel and runs much smoother .
    With this said , these 3 easy fixes are a good place to start
  8. Jan 1, 2015 at 5:51 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    35k? I think the plugs are to be replaced at 30k for the V6.
  9. Jan 1, 2015 at 5:53 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Welcome to T.W
  10. Jan 1, 2015 at 5:56 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    OP is slightly overdue for new spark plugs if they weren't done at 30K miles, so if cranking speed is OK and delayed starting is the issue, then I'd suggest starting there with a MAF cleaning too.
  11. Jan 1, 2015 at 6:14 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Since the OP is from AL, I'd suggest, as above, plus air filter. I heard of many late model Toyotas with battery dying at 3 + years as well. Sounds like time for some needed maintenance anyway ...
  12. Jan 8, 2015 at 4:39 PM
    dcoursler
    Derrick
    Alabaster, AL
    2012 TRD Off Road
    thanks for all the responses sorry for the delay in response I have been out of town traveling for a while for work. the battery is in fine shape got tested and is good to go and is putting out enough CCA's for the truck. the only way I can describe the starting issue is that it takes merely a second longer than normal to fire. and this may very well be a characteristic of the V6 but I wanted to ask around to make sure... I will do the maintenance soon as I get time.
  13. Jan 8, 2015 at 4:49 PM
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Was about 12 this am. Firs time truck ever been in that cold and parked outside. Took about 1.5 seconds of cranking to start.
    Mine is a 14 with 10k miles. It was a hard start this morning. I'm also in Alabama.
  14. Jan 8, 2015 at 6:23 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    12F ?
    Damn you guys have heatwave there.
    -6F here (and that's not windchill) and truck fired right up. But for winter driving I always switch to 87.
  15. Jan 8, 2015 at 6:37 PM
    jmaack
    Justin
    Helena Alabama
    Yes 12 F
    Heat wave.
    I always hear its different kind of cold. I keep seeing guys posting neg temps. I don't want to find d out. Ha
