Hard to steer. Diagnosing pump or rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mattmctree, Jan 18, 2025.
  1. Jan 18, 2025 at 2:36 AM
    mattmctree
    mattmctree [OP] Well-Known Member
    2009 black tacoma trd
    about 8 months ago my power steering pump started whinning and the resevoir was low. i found a steel line rusted and leaking and replaced it and just the other way steering has become alot harder. im guessing given that happened that the pump has finally failed but want to make sure its not the rack as well. is there a way to test both components to see which has failed. my money is on the pump but want to be sure.
    thanks
  2. Jan 18, 2025 at 4:32 AM
    JPT4x4ac
    JPT4x4ac Well-Known Member
    Jon
    Broadalbin , NY
    2012 Grn Tacoma AC 2.7 MT
    Try flushing the P.S. fluid first. There is a little screen in the reservoir that gets gummed up and makes the steering stiff
  3. Jan 18, 2025 at 4:41 AM
    mattmctree
    Ok. I will give that a try first. Does the screen just pop out after I've drained the reservoir?
  4. Jan 18, 2025 at 5:05 AM
    JPT4x4ac
    Jon
    Broadalbin , NY
    The screen will get cleaned when you flush the reservoir
  5. Jan 19, 2025 at 7:57 AM
    mattmctree
    Ok . How do I go about flushing the system of the old power steering fluid and putting in the new fluid.
    Thanks
  6. Jan 19, 2025 at 8:03 AM
    mattmctree
    I assume I woul drain the reservoir and remove the return line to the reservoir on the bottom frame cross member and add fluid unit while the engine is on until I see new fluid as the return?
  7. Jan 19, 2025 at 8:05 AM
    mattmctree
    Sorry typo I meant add fluid unit the reservoir is full
    while the engine is running
  8. Jan 19, 2025 at 8:15 AM
    rmspider16
    rmspider16 New Member
    If you review my first post on here...you'll see im a complete expert at flushing power steering fluid....(TLDR i totally botched it), but now i definitely know how to do it.
    best method to flush PS fluid completely.
    Step 1: Jack up truck so both front wheels are in the air.
    Step 2: Acquire rubber end cap to cover reservoir spout for return line.
    Step 3: Remove return line (upper rubber hose with clamp) to reservoir and cap off spout so reservoir doesn't leak fluid.
    Step 4: Place return line end into plastic bottle or something to catch fluid.
    Step 5: Turn truck to "on" position but DO NOT....and i repeat...DO NOT...turn on the truck.
    Step 6: (Easier with 2 people) Turn steering wheel slowly toward one side until it hits stop. The plastic bottle will slowly get filled with fluid.
    Step 7: Refill reservoir with new fluid to keep it topped off during this process. You don't want it to run dry.
    Step 8: Turn steering wheel to the opposite side until it hits stop limit.
    Keep doing the drain and fill until fluid is bright red and clean.
    Cheers.
    Marc70 likes this.
  9. Jan 19, 2025 at 8:24 AM
    mattmctree
    Okay sounds good. I wasn't sure if new fluid would pass through the system well enough without the engine running but then again I'd get high pressure with the pump running I suppose. I'll grab a few quarts and tackle it.
  10. Jan 19, 2025 at 8:25 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    If I may suggest changes to step 3 & 4.
    3 - remove rubber return line not from reservoir but rather from hard power steering line, either lift this above reservoiror or just clamp off/block off with a bolt used like a wine cork.
    4 - Attach long(about 2 foot long)hose to the above mentioned hard power steering line and run that in to an oil drain pan or bottle.
    Now one person can just turn the steering wheel back and forth and refilling the reservoir maybe every 4 or 5 turns from end to end. I over did it when I did my power steering fluid but I think I flushed about 2 new quarts through then reassembled the system and then topped off the fluid with engine running.
    Marc70 likes this.
  11. Jan 19, 2025 at 11:01 AM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
