Hard to steer w/ 4wd engaged?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mx5nut, Jan 28, 2009.
  1. Jan 28, 2009 at 7:23 PM
    mx5nut
    mx5nut [OP] New Member
    Although I have been lurking on the board for a while, this is finally my first post. Mostly because I am a huge fan of using the search function before posting anything and have found most of my answers thus far.
    So, we had some icy winter weather in the area for the last few days and I had 4wd engaged while driving to work. When I got to work, I was driving really slow through the parking garage and it was almost impossible to turn the stearing wheel! I was trying to turn a corner around some cars and almost couldn't make it. It felt like something was binding and might break if I turned anymore.
    That reminded me of last week when I already had the 4wd engaged when I left the parking garage one day and experienced the same thing. I had to make sure the wheels were perfectly straight and then I drive forward a bit to disengage.
    Has anyone else experienced this? Could there be something wrong with my truck (09 DC sport 4x4)? I know folks mostly go slow when off-roading and turning, so this steering issue definitely doesn't seem right. If any of you can respond with some info, I would really appreciate it. Thanks in advance for your help!
  2. Jan 28, 2009 at 7:28 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    It makes it harder to turn in 4wd because of the front wheels being given power and turning. Also you were probably driving on pavement in 4wd which is bad for the 4wd system which will make it bind up and break it. And its normal to have to straighten up and drive formard to disengage 4wd. I doubt anything is wrong with your truck, your probably just new to driving 4wd I'm assuming.
    Edit: Welcome to TW :D
  3. Jan 28, 2009 at 7:28 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Never ever engage 4x4 on the pavement. Ever.
  4. Jan 28, 2009 at 7:29 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    unless there is snow, or its flooded!;)
  5. Jan 28, 2009 at 7:36 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    If I'm in 4WD because of snowy & slick roads & have to pull into say a parking lot, I take it out of 4hi to park. I wouldn't have it engaged in a parking garage. If its going up a driveway on incline, I make sure to swing wide, or prepare before making the any turns. Again, only if its slick. Mine does the same thing. What I find is in nasty weather I use 4WD only when I need it & as others have said not on pavement. Congrats on your new truck!
  6. Jan 28, 2009 at 7:37 PM
    kmok
    Kyle
    Columbus, Ohio
    x2
  7. Jan 28, 2009 at 7:37 PM
    SnoBoarder
    SnoBoarder Hardcore wheeler, try and keep up.... if you can.
    Lost
    85 4Runner - Built not Bought
    x100
  8. Jan 28, 2009 at 7:50 PM
    mx5nut
    Wow, thanks for the quick responses. I'm not totally new to 4wd, but it has been many years, so I am jogging my memory on some things. That was a good point to go ahead and disengage when getting ready to park. I hope I didn't do any damage this time, but I will definitely remember this in the future. Thanks again!
  9. Jan 28, 2009 at 9:13 PM
    M2M
    M2M Well-Known Member
    bilstiens, sport 08 w/o scoop, debadged
    Quote:
    x100
    __________________
    well if you drive to a real mountain, you might reconsider that !
  10. Jan 28, 2009 at 10:20 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    With the ADD system on the Tacoma's it's easy to switch between 4Hi and 2Hi. Now on dry pavement what you might be experiencing is the binding action of the 4wd.
    While driving around I only use 4wd when it is absolutely necessary. If on snow and ice I'll drive around in 4Hi until I get to a spot where 2wd will work.
  11. Jan 28, 2009 at 10:35 PM
    dougmays
    dougmays Well-Known Member
    Doug
    Gainesville, FL
    2007 SR5 Tacoma 4WD/Tow Pkg Black
    Westin Bull Bar, Firestone Destination AT 255/70/16
    i'm new to 4wd as well. when you say never engage on pavement ever...does that pertain to 4HI and 4Lo? or just 4lo? because the manual says you can drive up to like 62 mph in 4HI. not that i would ever do that, but it seems to me like 4hi on pavement is ok? please shed some light?
  12. Jan 28, 2009 at 10:47 PM
    awoit
    awoit Well-Known Member
    CA
    08 TRD, SR5
    i dont understand why you cant put it in 4WD while on pavement. I do it every month to grease everything, if you never use it theres more chance of a problem for when u need it like during a storm after u havent used ur 4WD in a long time
  13. Jan 28, 2009 at 11:00 PM
    Rammstein
    Rammstein Well-Known Member
    San Diego
    2007 4x4 SR5 TRD Off-Road
    K&N Intake System, TSB Rear Suspension, TRD Cat-Back Exhaust Avid Off-Road Light Bar Toyota After-Market Skid Plate
    I not sure about “Never ever engage 4x4 on the pavement. Ever.” In the manual it say once a month to drive a few miles in 4wd to keep everything greased. Also whenever I go skiing or up to the mountains and if there is any possibility of ice or snow I drive in 4hi and have never had any problems.
  14. Jan 29, 2009 at 3:48 AM
    cvillechopper
    cvillechopper Jackass to the masses
    Charlottesville, VA
    '24 DCSB TRD Off-Rd, Premium Package
    Console lock-box, Studly Driver
    The statement should be "Never ever TURN on pavement while in 4wd." Hi or Lo makes no difference. The problem is that the front wheels are forced to turn at the same rate when in 4wd. When you turn the front wheels turn at different rates (difference radius for each wheel) and you can stress or break the front drive train.
    I drive on pavement in 4wd periodically just to keep the parts moving but NEVER when I will need to turn. On a straight road you'll be fine. If you have to turn, don't do it unless it's slippery (allows one wheel to slip some and keep from breaking anything).
  15. Jan 29, 2009 at 4:26 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Aside from what everyone else has already said.......Whatever you do..... if you feel 'resistance' and/or the truck starts to buck or won't move - DON'T FORCE IT.
    If you need to make tighter turns while in 4WD, take the turns WIDE and/or coast through the turns (no gas).
    Now that the snow/ice is abundant in our area, it's not uncommon to have patchy areas of snow and patchy areas of asphalt. I leave my truck in 4WD. Through-out the day, I'll be proactive in deciding how to make my turns before I get to them just to save the stress on the drivetain. When or if I need to turn into a tight parking space, I'll put it into 2WD and make the turn or simply coast (no gas) through the turn.
    It's the CV joints that get the most stress from tight turns/torque.
  16. Jan 29, 2009 at 4:45 AM
    sammy
    sammy Well-Known Member
    Maryland
    '09 4X4 Reg. Cab, Debadged Barcelona Red
    seat belt chime inter. wipers debadged canvas top (Bestop)
    Great explanation. When driving on dry pavement there is no give for the turning front wheels. They are spinning at the same rate. Driving on snow or loose gravel will give and allows turning to be easier. I also engage 4hi about once a month on dry pavement, but it is always around the beltway where I don't have to make sharp turns.
  17. Jan 29, 2009 at 7:49 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Yup. Take a wider arc if you hit pavement, and you shouldn't have any bind issue. Mixed snow & open pavement roads are a part of life up here, not gonna flip switch 5 times a mile. No issues w/ 3,000 mi in 4hi.
  18. Feb 5, 2009 at 6:53 PM
    4x4abc
    4x4abc Member
    La Paz, Mexico
    several from '65 FJ40 to '02 G500
    competent
    about using 4WD on snow and ice - 4WD will only help you to get going without slipping tires and it ads some stability while cruising. Some. Don't expect too much.
    However, 4WD does not help to stop the car. Actually, with part time 4WD engaged your ABS will not work properly and you'll have less control than a 2WD.
    So, on your way downhill on snow or on your way approaching a red traffic light I would shift back into 2WD. Since I have the option I personally select full time 4WD for snow and ice - that system allows ABS to work as designed.
    http://4x4abc.com/4WD101/ABS_parttime.html
  19. Feb 5, 2009 at 7:26 PM
    4x4abc
    4x4abc Member
    La Paz, Mexico
    competent
    oops double post
  20. Feb 5, 2009 at 8:05 PM
    Janster
    Jandy
    Lancaster, PA
    Don't believe everything you read. That article doesn't make ANY sense!
    So perhaps someone can explain what it is that's confusing me?
    First off -the ABS system sensors are not on the drive shaft. They're on each wheel. Although the driveshafts are connected via the transfer case - the differentials are OPEN diffs and can spin at different rates. Each brake is controlled separately and can go off per single wheel if needed when they lock up.
    You don't need (shouldn't) switch back into 2wd when slowing down. Keep it in 4WD, let your foot off the gas and allow the 'engine braking' to slow you down and never use the brakes until you need to actually stop. Obviously, you should always give yourself plenty of room to slow down. Even better - if you downshift, the engine braking is even more effective.
