Hard to turn in 4H
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 81Taco, Jan 22, 2017.
  1. Jan 23, 2017 at 11:45 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The weak link is the drive chain in the transfer case. Each time you put it in a bind it stretches some. Eventually it will become loose enough to slip on the gears. Don't operate in 4X4 unless you need it. Folks have been driving on snow for over 100 years now with 2wd vehicles. You only need 4X4 in rare situations to get out of a bad spot. It isn't meant to be used continuously even on snow.
    https://images.search.yahoo.com/sea...-decisions-np271-chain-drive.jpg&action=click
    At various times I've been here, on the Wrangler forum and the F-150 forum. At first I just thought that Wrangler owners were idiots. But I've seen enough of these posts now that I will NEVER purchase another used 4X4.
    TRDMountaineer likes this.
  2. Jan 23, 2017 at 12:15 PM
    81Taco
    81Taco [OP] Well-Known Member
    Bend Overegon
    2015 DCSB, SC
    Thanks all. I know "if it don't fit, don't force it". For those of you who are worried, i appreciate that. I'm not wrenching my wheel to cram it in tight spaces continuously. I'm saying that while in 4h now, the wheel feels stiffer to turn now then at the beginning of winter. I'm not familiar enough with truck transmissions to know if it was the result of a transmissuon oil of some sort that needed change(transfer, differential....).
    The driving conditions in my town have sucked for the last month. 3' of snow melting very slowly. I got stuck in a taco bell drive through the other day, but the roads were ok....as an example.
  3. Jan 23, 2017 at 12:42 PM
    Doug2000
    Doug2000 Well-Known Member
    London, Ontario, Canada
    2017 Tundra 5.7L
    Where do you live, add location to your profile.
    I live in Canada, we have no snow, it really really sucks.
  4. Jan 23, 2017 at 12:43 PM
    81Taco
    Bend Overegon
    2015 DCSB, SC
    Bend Oregon.
    OffroadToy and DustStorm4x4 like this.
  5. Jan 23, 2017 at 3:55 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Well...that explains the snow conditions. I think it's going to be July before I can get the boat up to Paulina this year. Hell... probably be close to that before i can get it out of the garage! :annoyed:
    81Taco[QUOTED][OP] likes this.
  6. Jan 23, 2017 at 4:01 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Time for FJ case swap
