Hard tonneau cover
Discussion in 'Tonneau Covers, Caps and Shells' started by RI-FL, Dec 10, 2020.
  1. Dec 10, 2020 at 6:26 PM
    RI-FL
    RI-FL [OP] Member
    Just purchased a 2021 Tacoma, I would like to get the factory hard tonneau cover or an aftermarket that’s close without breaking the bank. I read factory is not available as an add on. If this is true what’s is close to factory in an aftermarket cover.
    Sulley16 likes this.
  2. Dec 11, 2020 at 2:19 PM
    G-man68
    G-man68 Member
    2020 TRD Sport DCLB
    Extang Encore, Katzkin Leather
    You can buy the factory tonneau cover. I bought the Extang Encore because it has cab side access, retains the stock cargo rails, and can be removed without tools. Very happy with it.
    mrhoneydo likes this.
  3. Dec 11, 2020 at 6:20 PM
    Sulley16
    Sulley16 Well-Known Member
    Carlos
    Seattle, WA
    2016 BBP Tacoma DCSB TRD OR 4x4
    Stock
    Where do you live. I'm looking to sell mine off a 2016. It's the stock cover, so slightly used. Only defect, is on driver side. One of the foldable creases, they have these filler pieces that is a piece of plastic that holds in place the exterior stripping for just the crease gap. So not fully water sealed, but then again it never was even from day one. Seems like an easy DIY, just always new I would sell once I got Bed Bars. Hit with a DM if you want to work something out. I'm in Seattle WA. Can send pics of what the damage piece is as well. Other than that, it's solid as the day I bought the truck.
  4. Dec 16, 2020 at 6:06 AM
    RI-FL
    RI-FL [OP] Member
    I do not think that will fit my 2021.
  5. Dec 19, 2020 at 6:07 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
  6. Dec 19, 2020 at 6:12 PM
    RI-FL
    RI-FL [OP] Member
    CusterFan likes this.
  7. Dec 19, 2020 at 6:15 PM
    DamGuide
    DamGuide Well-Known Member
    Nooga, TN
    2020 TRD Offroad
    2016-2021 is the same tonneau, you need to swap bed rail covers. 2016 might be that faded black green color by now though. The OEM cover fades if not kept up.
    You can only buy the OEM used in the USA. If you live in Canada, you can buy a full kit though. It’s really annoying.
  8. Dec 21, 2020 at 12:04 AM
    Sulley16
    Carlos
    Seattle, WA
    Stock
    :crapstorm:
    Not if you live in Seattle. The rain has kept it looking like the day I bought it. I haven't seen any around here that look as you explained.
  9. Dec 21, 2020 at 6:53 AM
    DamGuide
    Nooga, TN
    2020 TRD Offroad
    Probably mostly due to sun damage, I keep black restored on mine and it stays new looking, here is a pic of one I found through Google real quick that hasn’t been taken care of and has some damage to it. I’m not sure why they chose this plastic, if you damage it, you can see it is very greenish hue internally.
  10. Dec 21, 2020 at 6:58 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I would take that off and throw it in the nearest dumpster.
    Kahpo and hfjeff like this.
  11. Dec 21, 2020 at 7:01 AM
    CusterFan
  12. Dec 23, 2020 at 6:09 PM
    CSVT
    CSVT Well-Known Member
    Ohio
    2021 TRD Pro
    what ballpark are you trying to keep in?
  13. Dec 25, 2020 at 7:48 AM
    Jkline101
    Jkline101 Well-Known Member
    Josh
    Houston, TX
    2020 Black Tacoma TRD Sport 4x4 DC
    SEMA TRD Pro wheels, Falken Wildpeak AT3 tires, Bakflip MX4 Tonneau, 3D Maxpider Kagu floor mats, TRD Pro skid plate
  14. Dec 25, 2020 at 8:03 AM
    Tacodude2020
    Tacodude2020 Well-Known Member
    2021 TRD Off Road
    CSVT likes this.
  15. Dec 28, 2020 at 11:19 AM
    OurFirstTaco
    OurFirstTaco New Member
    2020 Tacoma Double Cab Black
    I also got the Extang Encore for the features mentioned above and because the front flip panel's lock can be matched to your traditional type ignition/tailgate key. Also works with a bed extender and you get to keep the use of your bed rails and tiedowns.
    Although the bed rails are lowered a bit as part of the install.
    Barsoom likes this.
  16. Dec 28, 2020 at 11:21 AM
    cartter469
    cartter469 Professional Idiot
    Cartter
    Reno NV
    '17 4x4 DCSB OR
    Sliders; Skids; Diodes; 33" Falkens; Elka 2.5's; Icon Rxt
    Buy a used backflip mx4.
  17. Dec 28, 2020 at 11:35 AM
    dz333
    dz333 Member
    '21 Pro Lunar Rock
    Prinsu Cab rack, Bak Revolver X4, Redline Tuning Quicklift Plus, Garmin Dashcam 66W
    I went with a Bak Revolver X4, lest I add a bed rack at some point.
  18. Dec 28, 2020 at 11:36 AM
    Ricertruc
    Ricertruc Well-Known Member
    17 OR4B4 06 Prerunner
    ADS CO Icon UCA AAL SCS Rims KO2s Fox 2.0 CO
    Thats what I did for $500. At $1000 it seems steep but it is the best looking cover IMO. I also installed an OEM actuator for the tailgate lock so I don't need to ever use the dinky key again to access the bed.
  19. Dec 28, 2020 at 11:48 AM
    OurFirstTaco
    Do you have any more info on the actuator?
  20. Dec 28, 2020 at 12:32 PM
    Ricertruc
