Hard Topper pros/cons
Discussion in '3rd Gen. Tacomas (2016-2023)' started by phdog, Mar 1, 2018.
  1. Mar 2, 2018 at 3:52 AM
    GR8APE
    GR8APE Well-Known Member
    You're right about older and rounder and for that reason I keep in the bed a 3 foot long piece of pvc pipe with a small hook attached to the end to help me retrieve things i can't reach. I call it my groper stick.
  2. Mar 2, 2018 at 3:54 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I absolutely love my cap, and will always have it. Having the dry, locking storage is unbeatable. I will say if you get one, get at least on windoor. That's where the window on the side doubles as a door, and lifts up allowing you to reach in from the side. Makes life a lot easier.
  3. Mar 2, 2018 at 4:33 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    You're also cleaning the rear hatch window a lot in the wintertime. It's a habit you'll pick up evey time you gas up.
    famof5taco likes this.
  4. Mar 2, 2018 at 5:32 AM
    MECtacoOR
    MECtacoOR Well-Known Member
    Michigan
    2017 Magnetic Gray OR DCSB
    Line-x from the factory, ARE offers it on all there products now.
    SteelerJim[QUOTED] likes this.
  5. Mar 2, 2018 at 5:59 AM
    silasvirus82
    silasvirus82 Well-Known Member
    NC
    3rd Gen Off-Road DCLB
    Hobie Fishing Edition
    Thoughts on the Airlift? I have OBA already, plus a cap, plus a little extra stuff in the back. This might be a great solution for me.
  6. Mar 2, 2018 at 6:37 AM
    cctk2
    cctk2 GLACIERBIRD
    Chip
    NorCal and Alaska
    '68 FJ40, '16 TRD AC OR A/T WHITE
    Accessories: SnugTop Rebel canopy AVS Window Rain Deflectors TACOMA 6' Bed Mat Weathertech Mud Guards (4) Scanguage (re-installed from the '02) Tekonsha Voyager Brake controller (Chalet A frame pop-up.) Vinyl letter insets for tailgate. Garmin CS60 GPS mounting. Other misc décor in the form of decals.
    those who went with a hard top:
    1. What sort of impact do you see in gas mileage.....
    1A) No impact on mileage. What degradation there would be due to weight, is offset by aerodynamic improvement.
    2) If you need to haul branches to recycle or anything larger than the internal space, how much of a hassle to remove it? Do you do it often or only if you really can't avoid it?
    1) If you remove....
    2A) I NEVER remove it.
    3) What do you primarily use it for?
    3A) Why do I have/want/need?
    Dog, (no dogs in the cab), security for contents, looks, personal preference, etc, etc, etc...
    4) AAL?
    4A) No. Since the shell basically leveled the truck, I beefed up the rear with Sumosprings.
    Reason? To support the 300lb tongue weight of my A-Frame Chalet, and camping gear.
    My satisfaction with this mod/accessory? 99%!
    Note: I had Firestone airbags for the same purpose on my '02 SR5, but these Sumos have done EVERY bit as good as the airbags without the install/maintanence hassles.
    5) Cost? Accessories?
    5A) $1900-$2100... Can't remember.
    Slide front window and both sides, Dog screens, carpet interior lining, interior 12v lighting.
    Satisfaction with this Snugtpp Rebel?
    100%
    Would I buy again? Yes. Would I prefer a different make/model? Probably not, unless someone proved a better reason.20180207_162652.jpg 20180228_080533.jpg
    Oh, I forgot, the front window also hinges down. A MUST to clean the windows. Rear of truck/front of shell glass).
  7. Mar 2, 2018 at 7:33 AM
    Toyota09
    Toyota09 Well-Known Member
    2016 Tacoma TRD Off-Road Inferno
    My truck came with a century when I purchased it. First time I have owned a truck with a cap and LOVE IT. The dog is safer traveling, my stuff is locked up. Sits level with it on, but I plan on adding a RTT to the top so I know with that I will be upgrading the suspension. Mine does not leak but I do notice dust inside after being on the trial.. gonna seal up my tailgate with some weather stripping and see if that helps. I LOVE my cap. My gas mileage is still stellar. Wish I had a cap on my previous trucks - there is no reason not to own a truck with a cap, its the best of both worlds and if you need the bed you just pull it off in 20 mins with two people. IMG_5098.jpg
  8. Mar 2, 2018 at 7:59 AM
    GR8APE
    I have a Leer 100 and although I didn't do any before and after measurements my truck doesn't seem any lower in the rear.
    SteelerJim likes this.
  9. Mar 2, 2018 at 8:01 AM
    themouth
    themouth Member
    Long Island, New York
    2006 SR5
    A.R.E shell. Rigid light bar on Nfab mount.
    I've had a topper on both my trucks (92 pickup and 2006 SR5 DCLB) and plan to get one on my 2018 OR DCLB that should be in any day now. My 06 has an ARE CX model. I don't notice any difference in the gas mileage, and it didn't cause the truck to sag that I noticed. I've never had to remove the topper, as I always seem to get what I need into the bed with the topper in place. I mainly use my truck to haul around my fishing/cycling/kayaking/canoeing/outdoor gear. I need to keep the gear dry and secure. I installed a roof rack on top for the canoe, kayaks, and the longer fishing poles. The only downside I've found has already been mentioned: Difficulty getting to the gear closer to the cab of the truck. My new cap will have windoors on both sides. Crawling into the truck gets to be a pain.
    Also, I sometimes sleep in the bed for overnight fishing trips. There's room enough for two back there, and it doesn't feel claustrophobic. That's a big plus as well. Good luck!
    GR8APE likes this.
  10. Mar 2, 2018 at 10:04 AM
    phdog
    phdog [OP] Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    So I tried to build an ARE topper on their site and I like the option of the windoors but one of the images shows a windoor with a screen but it didn't seem to be an option when actually building it.
    Can you have a screen in a windoor with ARE or any other brand? Definitely want the screens for cross breeze/venting for the dogs but also like the side access (that side access is one thing I really like about the Softopper).
    Not off topic. This is my current situation. I have the Softopper and the factory tonneau. Tonneau on all the time except the 1% when I put the Softopper on for camping.
    I'd love to be able to toss stuff in the back that is bigger than the bed height without opening the back and I'm not going to put the Softopper on just taking the dogs with me. While it's only 10 mins or so it's just not something I want to take on and off all the time.
  11. Mar 2, 2018 at 10:11 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    They do exist, but I want to say you can't get them for a short bed cap. I could very well be wrong, but in another cap thread, someone was having issues with that. Can't remember the brand. Your best bet is to call them, or a couple dealers (not all dealers are the smartest).
  12. Mar 2, 2018 at 11:14 AM
    themouth
    themouth Member
    2006 SR5
    If I remember correctly, when you get the windoors that have sections, the middle section has a screen. I think they call it a pet screen or something to that effect. The regular windoors do not have screens.
  13. Mar 2, 2018 at 11:22 AM
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    No mpg impact for me, either.
    I did drop about 1/2 to 3/4" in the rear, but now I have airbags for hauling/towing ... solved that issue. That's the only con I can think of, everybody else has the pros covered.
    DignTRDoffRoadnbama likes this.
  14. Mar 3, 2018 at 2:59 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    I got a quote on an ARE CX. Is this reasonable or should I shop around?
    $1690 CX base
    $180 x 2 vented windoor
    $110 front fold down slider window
    $200 dome + switch + 2 LED strips
    $200 track for future rack
    Free headliner
    $2560 installed + tax
    They said if I ever wanted a rack it would void the warranty unless I had the factory track installed.
    I was hoping less than $2K. Seems pricey. I could save $125 and just get the dome light and switch and add lights later. Still pricey.
  15. Mar 3, 2018 at 3:22 PM
    #35
    kmev
    kmev Well-Known Member
    2001, 2017 Tacoma SR5
    That's basically what I paid in November for the exact same thing (minus vents on the Windoors.
  16. Mar 3, 2018 at 3:39 PM
    #36
    SteelerJim
    SteelerJim Well-Known Member
    Jim
    Southern Illinois
    2022 SR DBLCAB 4x4
    ARE Overland Topper, WeatherTech Mudflaps
    Check on a Ranch brand topper. My local dealers sell ARE, Leer, SnugTop, and a couple others. But the Ranch looked just as well made and was about $4-500 less with similar options.
  17. Mar 3, 2018 at 3:50 PM
    #37
    VTSR516
    VTSR516 Well-Known Member
    Vermont
    2016 SR5
    NEW: LT265 75 R16 General Grabber AT2's Hood and window deflectors ARE cab high color matched CX series cap weathertech floor mats Rough country 30" 15,000 lumen light bar in front grill
  18. Mar 4, 2018 at 3:32 AM
    #38
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
    It's the Southern Style Off-road Slimline Hybrid bumper.
  19. Mar 4, 2018 at 4:23 AM
    #39
    kayaktaco
    kayaktaco Active Member
    2017 Tacoma TRD Off-Road Blazin' Blue
    I have a ARE V-Series, Yakima bars and sliding rails, carpeted interior with sliding window and screens.
    1. Haven’t noticed any impact on fuel but full disclosure I had the truck for less then a week before getting the topper.
    2. Will likely never take mine off, may loosen it and slide it forward to clean windows when doing a full detail on the truck.
    3. N/A
    4. My wife and I are sea kayaking coaches so the truck is primarily used just for that, this is not daily driven as I have a company vehicle I drive daily or when I don’t want to put miles on the truck. Having lockable storage that keeps our thousands of dollars worth of gear dry and safe is awesome. Also not having to ride with wet and smelly gear is perfect.
    5. If anything this leveled the truck out. If I start towing often might look at adding a leaf.
    6. Alright so I have a small secret, look for what a dealer calls a factory second. This means two things, the cap was damaged upon delivery or rejected by the customer who ordered it. Mine was rejected by the guy who ordered it. Came in as a short bed and he had a long bed. My dealer holds the warranty not ARE, so it doesn’t have the lifetime warranty but let’s be real here it’s a big piece of fiberglass, so if you don’t abuse it what could really happen. I paid $1200 brand new and installed! 57FA4541-5643-4A16-AF3F-823DAC55DA3C.jpg
    doublethebass and sdmieth1 like this.
  20. Mar 4, 2018 at 9:46 AM
    #40
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Thanks for the tip. Seems there is a local dealer so I'll see how prices compare.
