Hard Vibration/Shaking while Turning Slowly...
Discussion in '1st Gen. Tacomas (1995-2004)' started by crazyasu45, May 26, 2010.
  1. May 26, 2010 at 12:31 PM
    crazyasu45
    crazyasu45 [OP] Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    So I just got a 4 wheel alignment done on my taco because of excessive toe in and extreme outside tire wear...Now when I crank the wheel and turn slowly in to a parking stall or reverse my truck shakes or vibrates :eek: hard...It doesn't do this while driving straight at all...any suggestions...Thx :cool:
  2. May 26, 2010 at 1:11 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    check for rubbing?
  3. May 26, 2010 at 1:52 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Do you have a locker? Or is 4WD engaged?
    Just sayin.....from your description, it almost sounds like one of those is possible. Almost as if something is binding....
    mechanicjon likes this.
  4. May 26, 2010 at 4:12 PM
    mytattootears
    mytattootears Well-Known Member
    ramon
    martinez, CA
    darkness
    Fabtech 6” lift (Hybrid). 63” Chevy springs. All Pro bumpers front/rear. And stuff
    mine does some shaking too, between 10 to 25 mph. then goes away. not sure why.
  5. May 26, 2010 at 4:19 PM
    dbronzo
    dbronzo Protected by Armor Tech Offroad
    Dennis
    Fayetteville, NC
    08 TRD Sport 4x4 w/ some Mods
    King Coilovers, LR UCA's, All Pro Sliders, ATO Full Skids, Pioneer AVH-P4300, 4.56 Gears, Front and Rear ARB Air Lockers, ATO Full Wrap High Clearance Bumper w/ Tire Carrier, ATO Hybrid Bumper, Smittybuilt XRC 8, Lightforce 240 Blitz, Rock Lights
    I had that happening on my wifes suburban and it turned out that my kid had flipped the 4x4 switch.
  6. May 26, 2010 at 4:21 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Yes...I have an E-Locker...and No...4x4 is not engaged...
  7. May 26, 2010 at 4:26 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    Yes...It could possibly be some rubbing issues...but I thought I have more than enough clearance with my lift :confused: maybe because my tires are pointed straight now and not toed in haha and I have a wider stance...I'll check it out...
  8. May 26, 2010 at 4:27 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    when my 4x4 or E-locker is engaged there is a big green light on my instrument panel I can't miss :D
  9. May 26, 2010 at 4:28 PM
    crazyasu45
    Canada
    3" SUSPENSION LIFT
    it's not shaking while cruising :p
  10. May 26, 2010 at 8:00 PM
    mytattootears
    ramon
    martinez, CA
    darkness
    no its all good, its just those few 15mph it take to get up to 30,
  11. Jun 26, 2010 at 12:46 PM
    Triple D
    Triple D Well-Known Member
    Florida
    07 4x4 Double Cab Sport Pack.
    My 4x4 Taco does the same thing during tight turns at low speeds (less than 10 mph) right after startup. Then it goes away basically after I've backed up and turned out of the driveway. I have the stock 17" wheels and stuff that 2007 sport package combo comes with. For what it's worth, the truck is definitely in 2wd when this happens but it's almost as though it's like turning with 4wheel low on.....any ideas?
  12. Jun 26, 2010 at 1:14 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    has your truck been in 4WD lately? i know they are e-lockers but sometimes this happens to my truck where the light goes off but the front is still locked. try backing up 10 to 20 feet to make sure....always make sure :)
  13. Jun 26, 2010 at 1:35 PM
    calledin
    calledin Well-Known Member
    Mark
    Knoxville, TN
    2008 DC Sport SR5 4x4
    mine does the same thing. it didnt start until the tires got 1/2 wore. I thought it might be the rear locking as you turn sharp? Is this something I need to have checked out?
  14. Jun 30, 2010 at 6:05 PM
    Triple D
    Florida
    Well I did switch mine in and out of 4WD to see if possible locking was going on but I did NOT put it in reverse. This "shaky" feeling seems to be sorta common on newer Tacomas. Anybody with a PreRunner experience this or is it only 4WD trucks?
  15. Jul 1, 2010 at 11:18 AM
    Sirlight
    Sirlight 1337 h4x0r
    Orange County, CA
    2004 PreRunner Xtra Cab
    STOCK
    I dont have any shaking or anything on my 04 Pre-runner. Just my tire rubs very slightly at full lock on the fender liner. You sure you're not rubbing on any suspension components at full lock ?
  16. Jul 4, 2010 at 10:01 AM
    rlf
    rlf New Member
    TX
    07 PreRunner SR5
    None
    My '07 2WD Prerunner has the same vibration. Really noticable when
    backing up and turning slowly. Also when turning to the right but
    not so much to the left.
  17. Jul 4, 2010 at 11:17 AM
    rlf
    rlf New Member
    TX
    07 PreRunner SR5
    None
    I think it's the rear differential. I have a limited slip differential. I had my son go forward and backward with the wheel cut to the left. I could hear it
    vibrating. Off to Allen Car Care tomorrow!
  18. Jul 5, 2010 at 7:06 AM
    rlf
    rlf New Member
    TX
    07 PreRunner SR5
    None
    Took my 07 Taco to the dealership. Diagnosis: Lack of friction modifier. Strange because I had just put in Mobil 1 LS. They replaced it with
    the Toyota brand ($6.25/qt) and Toyota LS2 @ $13.04. If you would have told me that I would have a problem with Mobil 1, I would have said you were nuts! Go figure!
  19. Oct 5, 2010 at 3:06 PM
    Triple D
    Florida
    Finally took my Taco in today for Toyota to check on the vibration/shaking feel at low speeds in tight turns. They said they duplicated it only 1 time while driving the truck and doing tight turns but feel it is the rear slip needing more fluid and additive. Talked to some friends who are mechanics and they said that seemed logical. Told Toyota to go ahead and perform the work. Will post results soon
  20. Oct 6, 2010 at 6:15 AM
    calledin
    Mark
    Knoxville, TN
    Is the rear slip the same as rear axles and housing? Mine is doing this some. I thought it was the tires? Please let us know if this helps the problem.
