Hard wire Escort Radar detector
Discussion in 'New Members' started by Intruder, Mar 8, 2016.
  1. Mar 8, 2016 at 11:12 AM
    Intruder
    Intruder [OP] New Member
    Is the cig fuse the start on/off fuse to hard wire?
  2. Mar 17, 2016 at 3:22 PM
    Z-MAN
    Z-MAN Well-Known Member
    2016 TRD Off Road 4X4
    BFG KO2 265/75/16 Bilstein 5100 Shocks Katzkin Leather
    Hard wire Escort Radar detector?????
    Looking to do the same ?
    Can I add a fuse to the open spot under dash?
  3. Mar 17, 2016 at 3:25 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Are you looking for a switched 12v source?
  4. Mar 17, 2016 at 5:09 PM
    Z-MAN
    Yes for a radar. Was looking to add a fuse under dash.
  5. Mar 17, 2016 at 6:03 PM
    Intruder
    Best to use the Ignition CB. It will ensure your Escort is on/off with your key
  6. Mar 18, 2016 at 4:57 AM
    Z-MAN
    Is that a fuse slot? There is one open slot in the fuse box under dash?
  7. Mar 18, 2016 at 9:30 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    For the radar detector you could use "T-tap" connectors hooked to the cigarette lighter.
  8. Mar 18, 2016 at 1:08 PM
    Z-MAN
    Thanks. I was trying to just add a circuit in the fuse box. I did it with a few past vehicles and it was really easy. However, the new Tacoma fuses are low profile under dash.
  9. Mar 18, 2016 at 1:12 PM
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    Years ago when I hard wired a radar detector in another vehicle I used an add-a-circuit fuse plug that goes in place of one of the fuses and has its own spot for a fuse.
    http://www.amazon.com/Shipping-Circ...31874&sr=8-10&keywords=Add-a-circuit+Fuse+TAP
    They sell them at auto parts stores which is where I bought mine.
    I just found a fuse slot that was switched with the ignition and plugged it in. Sometimes you can find an unused fuse slot that goes to an accessory you don't have and pop it into that one.
  10. Mar 18, 2016 at 1:45 PM
    Z-MAN
    Thank you this is what I was looking for.
