Hard Wired Heated Wet Okoles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wildtrt, Feb 10, 2011.
  1. Feb 10, 2011 at 10:12 PM
    wildtrt
    wildtrt [OP] Active Member
    TXPRO
    I just installed my Wet Okoles w heaters. I had them hard wired so I didn't have to deal with plugging and unplugging them into my power outlets because it seems like I always have too much stuff I need to plug in at once.
    They ran them to the one empty aux switch on the very bottom of the center stack between the AUX in and ATRAC switches. They put in a small double toggle switch, a switch for each seat. It looks pretty good where it is you don't even notice it as it's pretty low on the stack as everyone knows but I'm anal and hate anything even remotely half assed. So my first question is does anyone know where I can get a switch with twin actuators hopefully illuminated that will fit that accessory blank on the center stack?
    Here is my other thought, even when you flip the switch on for the heaters you have to activate the switch that came with the Okole's and select one of the 3 levels of heat otherwise no heat. So why cant I bag the toggles in the stack and just get the heaters directly wired in and use the 3 level switch that came with them?
    Anybody have any experience with this?
  2. Feb 10, 2011 at 10:22 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    do u have pics?
  3. Feb 10, 2011 at 10:23 PM
    AlaskaTacoma
    AlaskaTacoma Well-Known Member
    Shane
    Tempe
    TRD The Good Stuff
    6000K HIDs w/Fogs Smoked Tail lights Window Tint Dual Exhaust Sockmonkey Decal's Billet Grille Wet Okole Seat Covers Tacomaworld.com Sticker :) Painted Engine Cover Ultragauge WeatherTech Floor Mats
  4. Feb 11, 2011 at 11:17 AM
    utahskierdave
    utahskierdave Well-Known Member
    salt lake
    08 tacoma dbl cab
    I would also be curious as to how you installed the elements....between the WO's and the seat? Under the original seat fabric?
  5. Feb 11, 2011 at 11:22 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    You can get heated Wet Okoles?!?! This could be good!
  6. Feb 11, 2011 at 11:42 AM
    Silver06Taco
    Silver06Taco Well-Known Member
    WA state
    Silver 06 DC TRD Sport
    Didn't know that either. Their site shows it as an added $65 per seat.
  7. Feb 11, 2011 at 2:00 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Sorry I don't have an answer, but I have questions
    I got Wet Okoles with seat heaters, Nov '10.
    Came with Single Pole (On/Off) Switch on Plug (that plugs into the lighter).
    Was there a option to get the 3 position switch?
    Is it inline (in the cord) or in the plug?
    Were they ordered to hardwire or plug in?
    The heaters slip into pockets, sewed into the underside of the seat covers.
    Both seat and back
  8. Feb 11, 2011 at 2:23 PM
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
  9. Feb 11, 2011 at 5:26 PM
    Cape Codder
    Jack
    Thanks for the PM and answer.
    Might I suggest you post your answers in the thread the question was asked in.
    That way everyone gets the answer and you won't have to answer it multiple times.
    Yeah, Mine's just an On/Off in the plug
    I'll take a look at Wet Okole's site.
    Don't remember the 3 level being available in Nov. '10.
    When did You order yours?
  10. Mar 14, 2011 at 1:30 PM
    chacotaco
    chacotaco Well-Known Member
    Travis
    Albuquerque & Palo Alto
    2011 SSM TRD SPORT DCLB
    Black Snugtop XtraVision Sleep Deck.
    I just ordered min, and would like to know this too, as I am shopping for switches.
