Hard wired radar detector to rearview mirror today
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tactical Tacoma, Feb 16, 2010.
  1. Feb 16, 2010 at 10:35 PM
    Tactical Tacoma
    Tactical Tacoma [OP] Well-Known Member
    Seth
    McKinney, TX
    '12 MGM DCSB Sport 4WD
    ARB air compressor, ARB rear air locker, sPOD switch panel in sunglass holder, OME Front & rear shocks, 885x coils, Dakar leaf springs, Icon tubular UCA's, Flowmaster 40 Series Exhaust, aFe Pro Dry, TRD Sport wheels powder coated anthracite, FJ TRD center caps, Thule roof rack, 886 fog lights for reverse light mod, CSjumper LED DTRL's, Nokya Yellow fogs, plastidipped lower valence, Weathertechs, Wet Okoles. And MANY MORE MODS, READ BUILD!
    I took lowcel's advice and did this today. Here's a quick little write up
    1. Open Sunglass holder and locate the only screw there
    2. Remove the screw
    3. Remove the Maplight/Compass/Sunglass Holder assembly by pulling on front of assembly (closest to windshield)
    4. Locate the wire at the front of headliner and undo tape holding it in place and pull it through so you have better access to the wires
    5. Splice your positive into the green wire and your neg/ground into the white/black wire (I recommend wire taps), then tuck your wires away
    6. Put your Map light/Compass/Sunglass holder assembly back in and mount it with the screw you removed in step 2. As you can se in the pic below I also ran my radar wire underneath that black plastic wire cover for the rearview mirror
  2. Feb 16, 2010 at 10:40 PM
    LoHoNas
    LoHoNas Well-Known Member
    Jeff
    Lake Jackson TX.
    09 4x4 DC TRDSPORT MGM
    Debadged, Fog light mod,Grillcraft, Icons,TC UCA's, OME dakar leaf pack,Procomp 7089,BFG KM2 285/70/17 JVC NAV
    Nice work! I was just in there my self and added the switch for the rear view cam mod:woot:
  3. Feb 16, 2010 at 10:43 PM
    Tactical Tacoma
    Seth
    McKinney, TX
    Yeah I was gonna do that today also but ran out of day light, and didnt feel like making the drive to Radio Shack. Gonna pick up a switch tomorrow at Radio Shack on way home after classes.
  4. Feb 16, 2010 at 10:53 PM
    LoHoNas
    Jeff
    Lake Jackson TX.
    I planned on putting the switch inside the sunglass holder but couldn't find a spot I liked. I just ended up putting it in the little piece of trim next to the mirror. It did make it a lot easier to wire up after I had the overhead trim down and pulled the connector out in the open. It works good when you are towing something...gives a nice view.
  5. Feb 16, 2010 at 10:54 PM
    Tactical Tacoma
    Seth
    McKinney, TX
    Yeah thats mainly why I want to do that mod
  6. Feb 16, 2010 at 11:04 PM
    LoHoNas
    Jeff
    Lake Jackson TX.
    I wanted to get to the inverter mod to but had that same daylight problem. My next big project is a bed bar with LED fog lights wired to a 12v outlet in the bed. I got the lights in today guess its a start.
  7. Feb 16, 2010 at 11:06 PM
    LoHoNas
    Jeff
    Lake Jackson TX.
    Dam!! I guess I need a fuzz buster now. That install is nice:thumbsup:
  8. Feb 16, 2010 at 11:43 PM
    Tactical Tacoma
    Seth
    McKinney, TX
  9. Feb 17, 2010 at 4:53 AM
    PreRunner
    PreRunner Well-Known Member
    why is it mounted there, with suction cups no less :facepalm:
    what you need is a visor clip. but instead of clipping to visor, clip to headliner. this will bring it up behind the tint out of the way, and pick up signals better. will also be invisable from outside. and no ghastly suction cups. if i have time ill post pics later.
  10. Feb 17, 2010 at 10:36 AM
    Tactical Tacoma
    Seth
    McKinney, TX
    I like my radars to have good line of site both front and rear so it gets better reception. Over the last 13 years I have had just about every top model from every radar company (Beltronics, Vector, Cobra, Rock Mountain, Valentine 1, Passport, etc). I have found that I like the Escort/Passport the best and also the Valentine 1. I have also mounted them all in different places and usually the dead center of the window is best, ugliest but best reception. Read THIS
  11. Jan 31, 2011 at 5:32 AM
    ronny97
    ronny97 Taco Madre
    Ronny
    Dickinson, TX
    White TRD Sport
    Do you loose the power to the rear view miror?
  12. Jan 31, 2011 at 5:38 AM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    Good idea and looks cool...
    Wish I could afford to use my passport, but the tickets were getting expensive.
