Hard wiring a arb portable?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by micah323, Jan 27, 2021.
  1. Jan 27, 2021 at 10:15 AM
    micah323
    micah323 [OP] Well-Known Member
    I am in need of a air compressor. I am not sure if I want on board or portable. Does anyone know if the portable arb package can be mounted on board if I decide to go that route?
    Other option is to buy a cheap viair to hold me over for a while then put it in the wife’s Prius when I decide on one for my truck
  2. Jan 27, 2021 at 10:46 AM
    ardrummer292
    ardrummer292 500k or bust
    Austin
    ESVA
    2015 DCLB V6 A/T 4x4, 2011 Camry LE
    Overbuilt daily driver
    I'm fairly certain the only complications you'd run into are modifying the portable's wiring and finding a spot to mount the small air tank included in the portable's case. Everything else should be identical to the hard-mounted version.
    whatstcp likes this.
  3. Jan 27, 2021 at 10:54 AM
    micah323
    I’m looking at the single that doesn’t come with tank, so it would just be the wiring
  4. Jan 27, 2021 at 10:56 AM
    ardrummer292
    Austin
    ESVA
    I would assume that to be the case, yes. I don't even have my ARB compressor in hand yet, so take my input with a grain of salt.
  5. Jan 27, 2021 at 11:22 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    It’s 2 wires for the electrical. But does it have a way to mount it or would you need to cobble that together. Hard wired/mounted is often used for lockers or other uses besides just air fills which require permanent connections. See if it has feet that are drilled or if you’ll need to strap it in with plumbers tape or band clamps.
  6. Jan 27, 2021 at 1:25 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    So the 'portable' ARB I am pretty sure is just a single ARB CKMA12 packaged into a pretty container. You can just remove the compressor and do what ever you want with it. Just check what actual compressor is included in the portable unit.
    ARB sells the wiring package for the compressor, so you can buy it separate. With the switch and all.
    I just replaced one of the CKMA12's on my CKMTA12 setup, one of the compressors had a common failure of the bold holding the piston in snapping. Of course it is out of warranty. Easy fix though.
    I simply bought a CKMA12 and replaced the failed one.
    Now I have a spare to setup as a portable unit for taking in the wife's CRV on long trips.
