Hardened gear oil on bed mat
Discussion in 'Detailing' started by Hook78, Aug 1, 2021.
  1. Aug 1, 2021 at 5:37 AM
    Hook78
    Hook78 [OP] Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    Did my diff and transfer case oil changes several weeks ago, put my enclosed collection pan in the bed, and promptly forgot about it for about a week. Lucky me, discovered that the pan was leaking at the pour spout because someone lovely in assembly doubled up on the o-ring in the cap.
    Recently washed the truck, including drill brushing the bed mat with soap and water, and there are a couple spots of hardened, sticky gear oil that wouldn’t budge.
    Any thoughts on how to remove it without harsh chemicals that will f up the bed mat?
  2. Aug 1, 2021 at 5:42 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    not sure what drill brushing is
    i know several mechanics that work on 18 wheelers in fleet shops
    regular gasoline will usually work
    if not just low sulfur diesel fuel will work used on that thick fifth wheel grease
    does NOt take a lot with either actually just a few ounces
    the diesel fuel is my go to in the shop
    BassAckwards likes this.
  3. Aug 1, 2021 at 5:43 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Reference pics. Yes, I know, total first world problem. But these stains are collecting sand and creating little patches of sandpaper on the mat.
    B35D4DE1-F4FD-4E7F-9EFA-82E4CC7A26EF.jpg 7C8CF9B9-EAE8-460C-B73D-33C05BCE1545.jpg
  4. Aug 1, 2021 at 5:44 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    A drill brush is simply a brush attachment that goes on a drill. Car detailers use them quite a bit.
    Hook78[OP] likes this.
  5. Aug 1, 2021 at 5:47 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Drill brushes look like this:
    Gasoline acts like a solvent right? I wonder if mineral spirits would do the trick, though I’m not above pouring a little lawnmower gas on there.
  6. Aug 1, 2021 at 5:47 AM
    ROAD DOG
    FEW
    i dont doubt or contradict what U say
    car detailers use it where ?????
    sounds like it would do more damage than good
    every New Thang is not always a Good Thang !
    what ever happened to elbow grease
  7. Aug 1, 2021 at 5:54 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Detailers commonly use them on floor mats and auto carpets, they’re extremely effective. They’ve been around for a long time.
    But that’s besides the point, which is that I’m trying to remove some hardened gear oil, so any advice along those lines would be more useful than a discussion of the merits of drill brushes…
    NMTrailRider and RedWings44 like this.
  8. Aug 1, 2021 at 5:55 AM
    ROAD DOG
    FEW
    thanks for the pix
    tho i cant think of a single place on ANY of my vehicles i would use 1
    learned long ago even the wipe on / wipe of over time will leave swirls
    Iv seen body shops use buffing wheels with various compounds
    long term not so good
    O C D guy with just a cloth/rag can actually dull a finish in the quest to polish & shine
    if i were cleaning / cutting down to bare metal to prep...................................maybe
  9. Aug 1, 2021 at 5:56 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    What about a degreaser cleaner like Simple Green?
  10. Aug 1, 2021 at 5:57 AM
    ROAD DOG
    FEW
    already mentioned 2
    U could avail yourself of
    varsol
    acetone
  11. Aug 1, 2021 at 6:00 AM
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    Brake clean
  12. Aug 1, 2021 at 6:14 AM
    RedWings44
    Michigan
    *Sigh*
    They make more than just those particular brushes on vehicles and they don't typically use them on the exterior aside from the wheels. You don't use the same type of brush on the wheels that you would on the carpet. On the carpet/cloth seats in particular, they are fantastic for agitating the cleaning products or loosening up embedded dirt. They're also great on floor mats. Check out the Detail Geek on YouTube to see some drill brushes in action.
  13. Aug 1, 2021 at 6:16 AM
    ROAD DOG
    FEW
    no need to sigh
    iv already taken Ur word on it
    yet i will take a pass
    didnt know what or how to start with ............................no loss
  14. Aug 1, 2021 at 6:16 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Good grief y'all go straight to the nuclear option of solvents. Mineral spirits first, gasoline second, and if that fails, a dab of xylene or toluene. Never clean with a chlorinated solvent (brake cleaner), unless it's on brakes.
    Juisebocks likes this.
  15. Aug 1, 2021 at 6:18 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    My kid and I love Detail Geek!
    RedWings44[QUOTED] likes this.
  16. Aug 1, 2021 at 6:19 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Would you just soak the affected areas in mineral spirits and then scrub by hand?
  17. Aug 1, 2021 at 6:22 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Soak a rag and apply vigorous elbow grease would be my first approach.
  18. Aug 1, 2021 at 6:22 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    I’ll hit it up with some SG just for the hell of it, but because it’s hardened I figured I’d need something more powerful.
  19. Aug 1, 2021 at 6:23 AM
    ROAD DOG
    FEW
    if U get to home depot
    ZEP is stronger than SG
  20. Aug 1, 2021 at 6:29 AM
    Foghorn
    Foghorn Senior rooster, instructing in the art of roostery
    North Cackalacky
    2014 DCSB Off Road
    Spray some WD-40 on it, let it set for about 30 seconds, and wipe it up with a shop rag. Make sure the mat is cool and not in the sun. Then wash it off with soap and water. I use WD to remove grease and oil from my hands and my clothes.
    uurx likes this.
