Harder to decide on Tonneau than Truck
Discussion in 'Tonneau Covers, Caps and Shells' started by aucat77, May 2, 2013.
  1. May 2, 2013 at 9:18 AM
    aucat77
    aucat77 [OP] Member
    Brian
    Colorado
    2013 DCSB TRD Sport
    I have a 2013 DCSB. Trying to decide on a tonneau. Way too many choices. I think I have narrowed it down to either a G4 Elite, an Extang Solid Fold or an Advantage Hard Hat. Why? Two main reasons. Most importantly they allow me to use the tie down cleats when the cover is closed. Plus they are more secure and stronger than a soft roll-up. Any thoughts or advice on which to go with?
  2. May 2, 2013 at 9:40 AM
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    Can't help you on those choices, but I have an Undercover one and my tie down cleats fit just fine...
  3. May 2, 2013 at 9:43 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2015 Jeep Wrangler Sahara
    Not to throw more on your plate but I have the Access and I can still use my tie downs also
  4. May 2, 2013 at 9:46 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    Access Limited here. Very sturdy for a soft roll up and still able to use the cleats.
  5. May 2, 2013 at 9:48 AM
    JdevTac
    JdevTac Negative Ghostrider
    Josh
    GA
    2013 DC TRD-OR 4x4 Pyrite Mica
    When it comes to buying a Tonneau the G4-Elite will be #1 on my list. Why? IT gets good reviews, the rail seals were redesigned and don't just use 3m tape to stay secure, and it folds up in a couple configurations. Also looks the sleakest. Some people did mention to possibly buy one from the manufacturer, since some retailers may have old, version 1 stock that uses 3m tape for rail seals.
    It isn't the most watertight tonneau out there but from the reviews I read on here it seemed to only let minimal water in if any, but of course I am sure some of that comes in from the tailgate gaps also.
  6. May 2, 2013 at 9:54 AM
    SpacemanSpiff
    James
    08 TRD Off-road
    It gets better reviews than the Undercover ones? Interesting, but am happy with mine all the way around and very minimal leaks...
  7. May 2, 2013 at 11:00 AM
    aucat77
    aucat77 [OP] Member
    Brian
    Colorado
    2013 DCSB TRD Sport
    Had not thought about the Access covers. A worthy addition to my growing list of alternatives.
  8. May 2, 2013 at 11:08 AM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    In case you change your mind and consider roll up covers, Access gets my vote. I have the Access Literider for $280 and you can use bed cleats.
  9. May 2, 2013 at 12:14 PM
    littleblue81
    littleblue81 Well-Known Member
    I went with the Access Literider too. I don't like how the fold-ups block the rear window when fully open (I need to see to back up boat).
    The other styles that roll into themselves take up bed space that I don't want to lose (short bed) and/or lose ability to use rail system.
    Access is not as secure because you can cut through it, but "out of sight, out of mind".
  10. May 2, 2013 at 3:42 PM
    Tiedie
    Tiedie TieDie
    Yonder
    09 4X4 SR5 V6
    Debadged, extra D-rings,Cal-Trend seat covers, Husky liners, 4x4 illuminated switch, Redlinegoods console cover,aftermarket outside thermometer.foglight on anytime mod. Double USB charger in dash installed, Ballistic Jesters 16x8.
    Call truck alterations talk to Luke.Just ordered the G4. And got a great deal I feel. Will let you know after installed.
  11. May 2, 2013 at 3:44 PM
    tacomalimited
    tacomalimited Well-Known Member
    Northern NJ
    2013 tacoma limited double cab long bed 4x4.
    I have the G4 Elite, and i love it! No need to install lock on tailgate, cover locks itself to the tailgate, big plus, in my opinion.
  12. May 2, 2013 at 4:32 PM
    Jonah
    Jonah Well-Known Member
    Joe
    Charleston, SC
    2007 TRD O/R 4x4
    5100s F&R, TSB leaf springs, N-Fab steps, bed lights
    Another happy G4 Elite owner here. Very minimal leakage, only during really heavy downpours, and even then just one or 2 small drips. It doesn't block the rear window because the back 3 sections fold flat on the front section. For me, this is plenty of bed access 99% of the time. When I need the whole bed, it takes less than 5 minutes to remove 4 bolts and lift the cover. I can easily remove and reinstall the cover by myself.
    It may be pricey but you definitely get what you pay for.
  13. May 3, 2013 at 6:40 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    Talk with Scott and he will get you the right cover for your needs, and they give us member's a discount as well, and are great to wirk with... :D
    Scott Nauman
    TRUCKADDONS.COM
    1.800.388.8637 xt 1167
    scott@truckaddons.com
    Mon-Fri 1-9pm EST
    1098 East New Circle Rd.
    Lexington, KY 40505
  14. May 3, 2013 at 7:49 AM
    KingKoda
    KingKoda Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    I have the truxedo lo pro qt roll up and really like it. You can use the factory bed rail cleats still but their use on the sides does become limited but doable.
  15. May 3, 2013 at 8:07 AM
    2004TacomaSR5
    2004TacomaSR5 Sentinel Prime
    Jon
    Montana
    2004 Tacoma DCSB & '79 Toyota Pickup 4WD
    My tonneau is a soft folding model that allows me to use the tiedown cleats. I just like it better because it is so easy to take off and put back on.
  16. May 3, 2013 at 8:55 AM
    aucat77
    aucat77 [OP] Member
    Brian
    Colorado
    2013 DCSB TRD Sport
    Kinda surprised myself. Decided to go with lo pro qt. Checked it out at a local store and read a ton of reviews. I think I got a killer price.... $346 delivered at Truckaddons.com. They have a price match with a 5% beat which they honored. Also picked up the new premium black colored pop lock (PL5304) for $54. Most places were at $52 for the older PL5300 and wanted more for the 5304. Thanks for all the input.... very helpful & much appreciated.
  17. May 3, 2013 at 9:47 AM
    kryten
    Canada
    I've had the LoPro QT for three years and hated the fit and the clamp mounting design, so finally got fed up with it and replaced it with the Access LiteRider. 100% better in every way.
    However, I may have had an older version, and newer ones fit a lot nicer. :notsure: Hope that is the case for you. If you care, post some pics after install, I'd be curious to see. Good choice on the lock. Yes, the toneau can be cut through, but as someone mentioned before here, out of sight, out of mind.
  18. May 3, 2013 at 10:35 AM
    aucat77
    aucat77 [OP] Member
    Brian
    Colorado
    2013 DCSB TRD Sport
    Cover should arrive next week. Will try to take pics of the install & post.
  19. May 3, 2013 at 11:29 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    What Undercover do you have?
  20. May 3, 2013 at 11:40 AM
    Fms
    Fms Member
    I have an undercover flex and love it but cannot use the cleats
