Hardrock off-road April trip
Discussion in 'Florida' started by allenfab, Apr 1, 2017.
  1. May 1, 2017 at 1:28 PM
    #301
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Well, after pulling the actuator apart, cleaning up and tracing all the leads to make sure they have proper continuity, I put it back together today and it seems to work perfectly. The question now is do I chance it to Georgia which leaving is 2 days away?
    I didn't really do anything to it. My best guess is that having it split apart dried the inside out and maybe now it's not shorting out? Does that seem far fetched?
    Taco No Baka[QUOTED] likes this.
  2. May 1, 2017 at 2:57 PM
    #302
    allenfab
    allenfab [OP] I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    few videos Josh got of me
  3. May 1, 2017 at 3:12 PM
    #303
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Ouch that was cringe worthy for the driveshaft part. I smashed that rock with your slider on roller roaster (second clip) when i went up
    Edit: not sure if that was roller coaster though lol
    allenfab[QUOTED][OP] likes this.
  4. May 1, 2017 at 3:14 PM
    #304
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Found the video Jacob got
    allenfab[OP] likes this.
  5. May 1, 2017 at 3:17 PM
    #305
    allenfab
    Todd
    Lakeland, FL
    yea, the second clip is rollercoaster and the last is slickrock. We had to sit there for 20 minutes waiting for a flock of Jeeps to make it up rollercoaster lol
  6. May 1, 2017 at 3:23 PM
    #306
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Lol bunch of scrubs
  7. May 1, 2017 at 3:30 PM
    #307
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    And then I wasn't even able to give it an honest effort when I finally got to try it. :pout:
    I didn't even make it as far as the heeps. Looked like a chump, haha.
  8. May 1, 2017 at 4:24 PM
    #308
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Brian would have made fun of you for being in 4wd instead of 2wd
    Trident904 and allenfab[OP] like this.
  9. May 1, 2017 at 4:25 PM
    #309
    MartyMcfly
    MartyMcfly Time Traveler
    Rob
    Pahrump Nevada
    15' 4runner Limited 4wd
    see Build page for details.
    It was great meeting everyone yesterday.
    Where was "roller coaster?"
    I also have a bunch of dashcam stuff I might get around to posting sometime. Looking forward to next time. There's still a lot there we didn't even get to before it was time to go.
    https://youtu.be/aD8qsLdY1B0
    wade9986, NABeast and Taco No Baka like this.
  10. May 1, 2017 at 4:42 PM
    #310
    Taco No Baka
    Lee
    Tampa, FL
    The Roller Coaster is back somewhere between Hammer Hill and Slick Rock. It's really hard to describe where stuff is back there because the trails are a little confusing. That was my 4th time there (over a span of 4 years) and I only have a general idea of where everything is.
    MartyMcfly[QUOTED] likes this.
  11. May 1, 2017 at 4:50 PM
    #311
    Taco No Baka
    Lee
    Tampa, FL
    I'm actually a little surprised that I was having so much trouble even with only 3 wheel drive. Should have been doing at least as good as an open-diff Heep, but she just didn't wanna go. I aborted the attempt because I figured if I had that much trouble on the way up, I didn't have much of a chance with that ledge at the top.
  12. May 1, 2017 at 5:08 PM
    #312
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    That rock at the top of roller coaster gives a solid pucker Factor. The entire Hill is a pretty good pucker factor on a manual transmission because of that rock
  13. May 1, 2017 at 5:14 PM
    #313
    Taco No Baka
    Lee
    Tampa, FL
    It was clearly worse than when I was there last in December of '15, but I crawled up it that time easily; didn't even spin a tire. I think that was after the trip you guys took where Wes and everyone was having so much trouble with it. I think this time, it might have given me some trouble due to my lack of ground clearance. My wheelbase might have help me though. Never know now...stupid busted axle...:(
  14. May 1, 2017 at 8:40 PM
    #314
    Taco No Baka
    Lee
    Tampa, FL
    Update on the damage...
    So far I'm looking at having to replace my whole wheel hub (possibly including the wheel bearing if the hub can't be pressed out without destroying the bearing), probably the lockout, unless I can find a gear kit for it, and the CV axle. This is really gonna kill my regear fund. :pout:
  15. May 19, 2017 at 9:00 PM
    #315
    Madunc
    Madunc Member
    2012 Taco
    6in Lift, 35/12.5, Fuzzy Dice Upgrade
    Sorry fella's, late getting this out. A bit rushed, did it in about an hour tonight...didn't want to keep kicking the can forever.
    https://youtu.be/BGCEYC0any8
  16. May 20, 2017 at 3:34 AM
    #316
    Taco No Baka
    Lee
    Tampa, FL
    Thanks, Matt! Now I have something to remember the fun I had when I start getting bummed about the damage I still haven't fixed, haha. Guess I need to nut up and get serious about finding that damn wheel hub. :frusty:
