Hardrock off-road April trip
Discussion in 'Florida' started by allenfab, Apr 1, 2017.
  1. Apr 23, 2017 at 9:25 AM
    #121
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    Ready as I'm gonna get. :cool: Pre-reminder: don't forget to throw that brake stuff in the truck for me. :hattip: I'll hit you again Friday or Saturday. :D
    allenfab[QUOTED][OP] likes this.
  2. Apr 23, 2017 at 10:54 AM
    #122
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Well, doing rear gears Monday and Tuesday. Driving up to see time for a cab mount chop on Wednesday, then front gears and axles on Thursday Friday. Work Saturday.
    Hope I can get it all done!
  3. Apr 23, 2017 at 11:08 AM
    #123
    allenfab
    allenfab [OP] I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    That's a hell of a week. Are you setting up the gears yourself or are you installing already built third members?
    Taco No Baka likes this.
  4. Apr 23, 2017 at 11:11 AM
    #124
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    3rd member and front Diff are already assembled. Rear should be easy.
    Disconnect drive shaft, drain Diff, unbolt and pull axles out 5-6 inches, pull old 3rd out, then reverse.
    Front is a little more involved
    Taco No Baka and allenfab[OP] like this.
  5. Apr 23, 2017 at 11:26 AM
    #125
    allenfab
    Todd
    Lakeland, FL
    Good stuff. @Taco No Baka and I did the exact same thing last year sometime on a second gen. The rear is easy as pie but the front is definitely more involved. We were able to get it all done in a day though. It's a straightforward process, just very time consuming
  6. Apr 23, 2017 at 1:38 PM
    #126
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Did you have to replace axle seals? I should be ok if I'm careful right?
  7. Apr 23, 2017 at 2:55 PM
    #127
    allenfab
    Todd
    Lakeland, FL
    No, not on either axle but I think one of the front axle seals started leaking shortly after the swap. I think it was just a fluke though
  8. Apr 23, 2017 at 3:27 PM
    #128
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    OK cool. Gonna start on it in the morning.
    allenfab[OP] likes this.
  9. Apr 23, 2017 at 3:48 PM
    #129
    Madunc
    Madunc Member
    2012 Taco
    6in Lift, 35/12.5, Fuzzy Dice Upgrade
    See you there!
  10. Apr 23, 2017 at 10:25 PM
    #130
    Taco No Baka
    Lee
    Tampa, FL
    Haha, yeah, there were three of us so that sort of took a lot of the PITA out of it. The front was definitely the worst. We ended up having to pull the CVs out of the diff without removing them from the hubs. It was @Sholden223 's truck we were working on and he has a DB lift so I don't know if it was easier or harder than a factory config, although the long spindles probably gave us a little more play to get the axles out than the shorter factory ones. I'll also add that Todd was being really manly that day. :D He laid on the creeper and I set the front diff assembly on his chest and he rolled under the truck and bench pressed it up in there while Spencer and I secured it. He also did the same thing with the rear 3rd member. :muscleflexing:
    :benchpress::militarypress:
    Todd needs to fab up an axle press for you 2nd & 3rd Gen guys that bolts to the wheel studs and has a big ol' bolt in the middle to press the stupid stub axle out of the hub.
    The rear axle was kinda interesting too. Again it was a lot easier with three of us. Spencer and I had to pull the axles out and hold them (the brake lines wanted to pull them back in far enough that they were still just barely engeged in the 3rd) while Todd was removing the old 3rd and the process was repeated when putting the new third in. I could definitely see that doing it by yourself, while not impossible by any means, would be a lot more frustrating. :frusty:
  11. Apr 24, 2017 at 4:39 AM
    #131
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    A cool trick with the rear someone showed me is to put a deep socket between the brake drum and axle tube on the rear to keep it from pulling back in
    Taco No Baka[QUOTED] likes this.
  12. Apr 24, 2017 at 4:48 AM
    #132
    Taco No Baka
    Lee
    Tampa, FL
    That would have been similar to my plan. I would have wedged it with a wedge of wood. :thumbsup:
  13. Apr 24, 2017 at 9:19 AM
    #133
    Taco No Baka
    Lee
    Tampa, FL
    I am utterly unsurprised...seems my cousin is a nogo. His Chevy did what Chevys do and took a shit on him so he won't be going. :rofl:
    BTW, @allenfab , what size wheels are those dirty-5s mounted on and how much do you want for them?
  14. Apr 24, 2017 at 9:33 AM
    #134
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Tires/Wheels
    35x12.50R15 Mickey Thompson MTZ's
    15x8 3.75" backspace Summit Racing D-window black steel wheels
    took me one click :D
  15. Apr 24, 2017 at 9:42 AM
    #135
    Taco No Baka
    Lee
    Tampa, FL
    However, it didn't tell you how much he wants to sell them for. :luvya: Thanks though.
    Rattletrap66[QUOTED] likes this.
  16. Apr 24, 2017 at 9:46 AM
    #136
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    :rofl: tis true
  17. Apr 24, 2017 at 12:22 PM
    #137
    allenfab
    Todd
    Lakeland, FL
    $400 for the four best ones. I am keeping the fifth one as a spare still. I will have to get tread depths in a few
  18. Apr 24, 2017 at 12:28 PM
    #138
    Taco No Baka
    Lee
    Tampa, FL
    Cool. I'll pass it on followed by the tread depth when you get it. Thanks. :hattip:
  19. Apr 24, 2017 at 12:56 PM
    #139
    allenfab
    Todd
    Lakeland, FL
    Here you go. Tread depths and pics of the best and worst ones
  20. Apr 24, 2017 at 1:05 PM
    #140
    Taco No Baka
    Lee
    Tampa, FL
    Awesome. Thanks, Todd. I'll let ya know what he wants to do. :hattip:
