Hardrock off-road April trip
Discussion in 'Florida' started by allenfab, Apr 1, 2017.
  1. Apr 24, 2017 at 6:30 PM
    #161
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    I'm just messing with you. I hope it's nothing to serious and goes away. :thumbsup:
  2. Apr 24, 2017 at 6:32 PM
    #162
    Taco No Baka
    Taco No Baka Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    I would say go ahead and come. You can park in the parking lot and ride with someone. I'd offer my shotgun seat, but I don't think it's a good idea for anyone to be stuck in a truck with me if I'm still not up to par.
    NABeast likes this.
  3. Apr 24, 2017 at 6:35 PM
    #163
    Taco No Baka
    Lee
    Tampa, FL
    Thanks. It's probably nothing too serious. :fingerscrossed:
    NABeast[QUOTED] likes this.
  4. Apr 24, 2017 at 6:37 PM
    #164
    Smashingtaco
    Smashingtaco Member
    Never been to hard rock before heard it was fun but idk if 2wds would make it without being locked in the rear
  5. Apr 24, 2017 at 6:43 PM
    #165
    Taco No Baka
    Lee
    Tampa, FL
    It's not terribly 2wd friendly even if you are locked, to be honest.
  6. Apr 24, 2017 at 7:13 PM
    #166
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Hard Rock looking really iffy for me. Got the rear gears done but doing the front in time will be tough
  7. Apr 24, 2017 at 7:21 PM
    #167
    Taco No Baka
    Lee
    Tampa, FL
    o_O Come on now, we all can't bail. Sounds like you need some medicine made by the same people as the stuff Paul was prescribing for me--Stopbeingawussandgetitdin. :D
    NABeast likes this.
  8. Apr 24, 2017 at 8:08 PM
    #168
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    Haha. The problem is if I finish them in time it will be the day before the meet. The guys at ecgs were very adamant about a 500 mile break period with varying speeds and breaks in between to allow the Diff to cool. I don't wanna drive up there and break something by being rough on the trails
    And I assure you this sucks because I love hard Rock. Wanted to go back since the last meet there.
  9. Apr 24, 2017 at 8:18 PM
    #169
    Taco No Baka
    Lee
    Tampa, FL
    Yeah, that's one thing I'm probably not going to be able to manage when I regear. I only put about 1k a year on the OGT and half of that is off-road. I wouldn't be able to wheel it for like a year if I waited until I completed a 500 mile break in. o_O
    Nobody says you have to be rough with it though. Just stay away from the rock gardens. The hill climbs aren't all that hard on your diffs. Plus, unless you're gonna drive around on the street in 4WD (which would be harder on the diffs than wheeling--unless it's a 3rd Gen Taco or 3+ Gen T4R with a center diff type t-case) then you need to wheel it to break in the front diff.
  10. Apr 24, 2017 at 8:27 PM
    #170
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    I don't see why they need to broken anyways. They get heat treated when they are cast (or are gears forged?). Biggest thing is probably to change the fluid after 500 miles get the shavings out.
    You're right on the front Diff I didn't consider that
    Taco No Baka likes this.
  11. Apr 25, 2017 at 5:10 AM
    #171
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Tires will be here Thursday!
    allenfab[OP] and Taco No Baka like this.
  12. Apr 25, 2017 at 5:13 AM
    #172
    Taco No Baka
    Lee
    Tampa, FL
    What size did you end up getting? :sawzall:
    Rattletrap66[QUOTED] likes this.
  13. Apr 25, 2017 at 5:26 AM
    #173
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    35x12.5R17
    Taco No Baka[QUOTED] likes this.
  14. Apr 25, 2017 at 5:31 AM
    #174
    Taco No Baka
    Lee
    Tampa, FL
    Cool. You gonna have them on for Hardrock? ...only because I would imagine there's gonna be a lot of sheetmetal trimming to be done.
  15. Apr 25, 2017 at 5:48 AM
    #175
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    yes sir! I'll be cutting this week
  16. Apr 25, 2017 at 6:26 AM
    #176
    allenfab
    allenfab [OP] I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    Honestly, I wouldn't worry too much about the break in. I didn't follow it whatsoever on mine. I wheeled within probably 300 miles of initial install and didn't change fluid until after 4K miles or so. The fluids where clean front and rear, with very very little metal debris on the magnet. (The magnet only had that really fine sludge built up on it from the microscopic pieces of metal, which is usually normal with a fluid swap at any mileage).
  17. Apr 25, 2017 at 11:31 PM
    #177
    mosquitoTaco
    mosquitoTaco Has an attractive member
    Anthony
    SouthTennessee
    14' DCSB offroadsport-sold =2005 T4R V8
    Bilstien 5100@ 0, OME 885(+10 mm drivers side spacer for taco lean, 5mm passenger), b110 rears w/ allpro standard leaf pack, wheelers ubolt flip, superbump bump stops, extended brake lines steal braided(front and rear), Dick Cepek extreme country 305/65/17 tires on FN six shooters=17x8, street tires are 285/75/16 duratrac w/FN countersteer type X= 16x8, a healthy cab mount chop, SPC LR UCA's, TC cam tab gussets, Wet okole seat covers, husky x-act fit floor liners, SOS aluminum front skid, SOS mid skid, SOS sliders (bolt on), ECGS bushing for needle bearing, uniden PRO520XL cb. BAMF tailgate antenna mount, 4' firestick, A.R.E. Z series camper top, Factory roof rack, Pioneer avh-5800x head unit. Front and rear anytime cameras, Rear diff. Breather relocate. 42" highlift. Tow straps/All-PRO snatch strap, tow hitch w/D-ring, traction pads, Tacoma bed mat, Rago Fab ditch light brackets with jap special light pods
    Sorry Todd, apparently I haven't been on TW lately, I'm probably not going to make this one although I'm going to try. With it being the week of Georgia trip plus all the other crap I have going on, I don't think i can swing it by the old lady. She isn't going with me to Georgia so it's "her weekend" . :help:
    allenfab[QUOTED][OP] likes this.
  18. Apr 26, 2017 at 9:05 AM
    #178
    wade9986
    wade9986 Well-Known Member
    Ross
    Stuart, Florida
    2020 TRD Sport 4x4 Supercharged
    Magnuson Supercharger OTT Tune TRD Pro Front End Conversion Old Man Emu Lift 285/70/17 Nitto Trail Grapplers 17x8.5 Black Rhino Duggers Fab Fours Front Bumper Smittybilt X20 Winch Rigid Industries Lightbar
    Should I even bother coming with my prerunner? I have the mechanical LSD but I don't want to get stuck every few feet. It's about a 3 hour drive for me. @Taco No Baka
  19. Apr 26, 2017 at 9:09 AM
    #179
    Rattletrap66
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    ╭∩╮(ಠ۝ಠ)╭∩╮
    you won't have as much fun as 4wd but you can keep up on the trails
  20. Apr 26, 2017 at 9:12 AM
    #180
    wade9986
    Ross
    Stuart, Florida
    Ok, thanks for the reply. I got through all the trials when I went with you guys to the citrus meet in 2016. Although those are relatively easy. Maybe I'll bring my camera and take some pics of you all going through the stuff I won't be able to.
