Hardware for the towing package
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tines_with_trav, Apr 8, 2021.
  1. Apr 8, 2021 at 6:10 PM
    Tines_with_trav
    Tines_with_trav [OP] Member
    2017 Tacoma TRD Offroad
    Hi all, so I have a 2017 tacoma that used to have a tow package on it but was taken off before I bought it. I recently acquired an oem hitch for that year but it didn't come with any of the hardware. I called the "stealership" and to get me all of the bolts and supposedly 2 brackets i "might" need is $188 . I'm hoping for a cheaper alternative. Does anyone know the different bolt sizes and how many are needed, and if the brackets are necessary?
  2. Apr 8, 2021 at 6:41 PM
    Georgia Native
    Georgia Native Well-Known Member
    4x4 DCLB 2017 SR5, 2019 4runner Offroad, 2021 SR Access Cab
    You might check area junkyards and get the parts needed from there.
  3. Apr 8, 2021 at 6:53 PM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    It sounds more like your truck did not come with the tow package. U-haul might tell you what you need and could install the wiring or give you a free estimate.
    Chew likes this.
  4. Apr 8, 2021 at 10:10 PM
    MauiBrian
    MauiBrian Kapalua fun
    Brian
    Maui
    2018 SR lightly modded
    As others have said, verify that your truck in fact originally had a tow package. Do you have a trans cooler? As far as spending $190 on necessary hardware to install a used hitch I would consider buying a new Curt hitch and Tekonsha plug and play wire harness from eTrailer for about the same $$$.
    My truck had no tow package so I purchased and installed the parts from eTrailer. I had a coupon so I paid $160 shipped to my home.
    Have towed without any issues.
    Just wanted to share my solution, good luck with whichever path you choose.
    R4D4G4ST and Jere like this.
  5. Apr 8, 2021 at 10:13 PM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    +1 On buying the hitch and wire harness aftermarket. I did this a couple of years ago when I added a hitch and flat-four harness to my previous 4wd and I saved a lot of money over OEM. Hitch looked and worked fine.
  6. Apr 9, 2021 at 6:47 AM
    huminajumina
    huminajumina Well-Known Member
    Kevin
    2017 Grey Metallic Tacoma TRD OR 4DR
    17" TRD PRO Black Matte Wheels BFG KO2 AT's Black Grille with TRD badge, Yellow Foglights Landcruiser Association Sticker (+45HP)
    I second the Tekonsha plug and play wire harness and P3 bracket to put it in the left side pocket, its nice!
  7. Apr 9, 2021 at 6:58 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Just a FYI in case it’s not known: there is more to the tow package than the hitch. I’m not sure of all the parts but I believe it also includes the anti-sway electronics, bigger alternator, and a transmission cooler (AT only). Without those things the tow capacity is something like 3500 lbs vs 6900 lbs with them.
    I’ve also heard that it is extremely rare for a taco to be built without the tow package and that Toyota stopped including the transmission cooler in new models.
    Taco_mike73 and huminajumina like this.
  8. Apr 9, 2021 at 7:46 AM
    Chaosh1
    Chaosh1 Well-Known Member
    2021 Tacoma TRD Pro
    I just bought the TRD Pro and it has a trans cooler. Also i decided to go with the Redarc Liberty seeing as it does 1 and 2 axle which should be plenty for a tacoma.
    Taco_mike73 likes this.
  9. Apr 11, 2021 at 9:41 AM
    Chaosh1
    2021 Tacoma TRD Pro
    I spent a little time under the truck this morning. Confirmed no trans cooler. Tow package is now anti sway, 130 amp Alt, power steering and oil cooler.
  10. Apr 11, 2021 at 12:53 PM
    FLA_Hoosier
    FLA_Hoosier Well-Known Member
    Rick
    Space Coast
    2017 White TRD Sport AC
    Go to the owners page on toyota.com and enter your VIN. It will tell you exactly how your truck was originally configured.
  11. Apr 11, 2021 at 5:53 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Try etrailer.com
