Hardwiring ARB fridge plug
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kleach18, Apr 16, 2019.
  1. Apr 17, 2019 at 6:33 PM
    #41
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Oops... easy mistake to make. Get one in there soon!
  2. Apr 17, 2019 at 6:39 PM
    #42
    OnHartung'sRoad
    There’s a 750 amp Blue Seas ANL fuse that I put on my truck for my winch cables- it looks like this:
    https://www.amazon.com/gp/aw/d/B000XBB9VK?psc=1&ref=ppx_pop_mob_b_asin_title
    And the cover for it:
    https://www.amazon.com/Blue-Sea-Sys...7Y5EZY96M9H&psc=1&refRID=V7517XR9F7Y5EZY96M9H
    If not using it or a winch, your Bussman circuit breaker is perfect for most applications.
    YF_Ryan likes this.
  3. Apr 17, 2019 at 6:44 PM
    #43
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Prolly need closer to 250 if I want to safely self jump start, but yeah, ill be looking into that for sure. Thanks, man! And sorry for the thread jack, OP. But hopefully we all learned a little.
  4. Apr 17, 2019 at 7:07 PM
    #44
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
  5. Apr 17, 2019 at 8:42 PM
    #45
    Kleach18
    Kleach18 [OP] Well-Known Member
    2016 TRD Offroad
    Yeah, I'm still learning so I appreciate all the info.
    I went to Walmart and bought a 680 Watt 8-Gauge amp kit and used the 16.8 ft power and 2 ft ground wire. The 8 gauge wire fit perfectly through the water drain holes that were in the bottom of the bed cubby so I didn't even have to drill. The hardest part was trying to find a place to attach the ground. I found a bolt that the preattached ground eyelet would fit on but I'm not sure if it will have a good grounding surface. I'm supposed to get the rest of the parts tomorrow so I'll hook up the wires I ran today and see if it works out.
    Will a 8 gauge power wire be sufficient? There is a fuse just off the battery and one built into the plug/USB panel I ordered. Figured it might be overkill but better safe than sorry.
  6. Apr 18, 2019 at 7:25 AM
    #46
    YF_Ryan
    Kent, WA
    If you Google 12v Wire Amp Chart you can find things like the below images. You're prolly fine up to around 25 or 30 amps. Fridge, cell phones, your LED lights, won't be a problem for it.
  7. Apr 18, 2019 at 8:00 AM
    #47
    Kleach18
    2016 TRD Offroad
    Thanks, I actually found that in a different thread after I posted in this one.
    YF_Ryan[QUOTED] likes this.
