Harmonic Balancer Bolt
Discussion in '1st Gen. Tacomas (1995-2004)' started by Funkychateau, Jun 3, 2024.
  1. Jun 17, 2024 at 1:01 PM
    #41
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Yeah You can get it out with the oil pump cover attached still. I tapped mine in with a rubber mallet but I'm sure most things work. I didn't have luck with the harbor freight puller but it was probably user error.
  2. Jun 17, 2024 at 2:08 PM
    #42
    Funkychateau
    Funkychateau [OP] Well-Known Member
    Martin
    1999 Tacoma 2WD Extended Cab
    None
    Unfortunately, that’s not the Harbor Freight tool he’s using. His appears to have an adjustable head, which allowed him to use it with the handle swung over to one side.
    No biggie, I ordered the Amazon tool and oil seal, both are supposed to arrive by tomorrow night.
    Of course there are things I may not like about this one also, such as the fact that the “post” that you prop against the motor is not adjustable for length. But it’s less than $20 with tax, so I decided I’d give it a try.
    There’s a reason Jeff Bezos is the richest man on the planet ... at least before his divorce
  3. Jun 17, 2024 at 2:13 PM
    #43
    Funkychateau
    Martin
    None
    Probably not user error - I studied that Harbor Freight tool also, and it appears that it’s design requires you to have good clearance for 10 or 12 inches in front of the seal in order to maneuver it around. All of their examples show it being used on stuff that has lots of clearance.
  4. Jun 17, 2024 at 2:43 PM
    #44
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    pm sent Funky
  5. Jun 18, 2024 at 12:11 PM
    #45
    Funkychateau
    Martin
    None
    77A253E7-D81A-4295-BD6E-6619333E8643.jpg A8054E93-FE7B-47BD-A907-E2D19856B700.jpg I received my replacement seal this morning. There’s no markings to indicate inside and outside, and it doesn’t look much like my old part. I assume this may be because the old one has almost 400,000 miles on it and the design may have been different 25 years ago.
    The old one is still inserted because the removal tool won’t arrive until about 10 pm.
    The replacement is as follows:
    Side 1 has a thin “lip” which extends straight out for about half again the pressed-in thickness. I’m thinking this side faces out, and the lip rides against the inside of the HB to keep dirt away from the actual seal. My original part does not have an outer lip, but maybe it rotted off over the years.
    Side 2 has no protrusions, but has a channel which holds a coil-spring “ring” that I assume helps to keep the seal snug against the shaft. It makes sense to me that this side faces inside, otherwise the coiled spring would rust.
    Am I correct?
  6. Jun 18, 2024 at 12:15 PM
    #46
    Funkychateau
    Martin
    None
    Original seal, no “lip”. No “channel” either. It doesn’t look like side 1 or side 2 of the replacement part.
  7. Jun 18, 2024 at 1:44 PM
    #47
    ControlCar
    Steven
    Sugar Land TX
    yep
    spring side is the inside
    make sure you use some assembly lube(some clean petroleum product) on inner and outer of seal
    i use a large socket or a end cap for PVC piping to gently tap seal into place
    mine so used i can see the width....think 2inch........would take the seal to homo dept to be 100% suret1.png
    Robnik and Funkychateau[OP] like this.
  8. Jun 19, 2024 at 8:54 AM
    #48
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Again go watch the vid at the 2:55 mark.....you can see the seal with spring in/ protrusion out
    How to Replace Crankshaft Seal on Your Car (youtube.com)
  9. Jun 19, 2024 at 11:07 AM
    #49
    Funkychateau
    Martin
    None
    Amazon Prime is slipping lately. The seal-puller tool didn’t even ship until late yesterday, when it was originally promised to be delivered.
  10. Jun 19, 2024 at 11:46 AM
    #50
    Funkychateau
    Martin
    None
    Begged a ride down to Home Depot, and you were correct, a 2” PVC pipe cap is a perfect fit. I was about to start making a seal driver on my lathe ...
    Robnik and ControlCar[QUOTED] like this.
  11. Jun 19, 2024 at 4:47 PM
    #51
    THatt
    THatt Well-Known Member
    Upstate SC
    1996 Tacoma 2.7L MT 4X4
    I just tapped mine in with a piece of wood and a hammer. Round and round tapping till seated. Nervous as hell but it’s really no different than a wheel bearing seal. And have used that screw removal trick the other fella offered on wheel bearings. It works.
  12. Jun 19, 2024 at 6:51 PM
    #52
    Funkychateau
    Martin
    None
    That was my first thought - I’ve done similar “fitting” of parts with a hammer and wood.
  13. Jun 19, 2024 at 10:48 PM
    #53
    Funkychateau
    Martin
    None
    The Amazon seal puller tool arrived tonight (a day late) and I just spent almost an hour on my back in the rain trying to make it work.
    It’s just way too flimsy for this application. The metal finger flexes and slips out long before you can apply enough pressure to budge the seal. I’m returning it.
    I even tried trimming all the rubber from the inside of the seal, hoping that would allow the tool to get a firmer bite, but still it keeps slipping out.
    Tomorrow I’ll visit some parts stores and see whether I can find one similar to that used in the video.
  14. Jun 20, 2024 at 1:30 PM
    #54
    ControlCar
    Steven
    Sugar Land TX
    i was chasing an oil leak on my RSTi with new short block
    these were the only the 1st batch
    just think of doing a T belt job 4 times....and replacing all 4 seals(camshafts) hunting this oil leak
    turned out no Fugi Bond placed on camshaft carriers by engine assembler.....not the seals
    THatt and Robnik like this.
  15. Jun 20, 2024 at 1:38 PM
    #55
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Been there, done that :rofl::thumbsup:
  16. Jun 20, 2024 at 1:39 PM
    #56
    ControlCar
    Steven
    Sugar Land TX
    funky......
    here is my method (as apposed to the techs method)
    tech pried out the bottom left seals
    the ones with the black rtv and basically destroyed......the A-hole gouged my cam seal surfaces so i needs 4 new cams as well
    my method
    you can see the small holes in 5 of the above seals
    -drill small hole in side of seal
    gently....let drill bit do the work....dont push drill like your making a fence or drilling metal plate
    -hand turn a screw in your hole
    use a screw that doesnt have a razor sharp point....like a blunt point
    -use a pry tool.....hammer claw or clip puller or similiar
    seal will pop right out without any dmg
    Robnik, Funkychateau[OP] and THatt like this.
  17. Jun 20, 2024 at 1:42 PM
    #57
    ControlCar
    Steven
    Sugar Land TX
    Rob
    UGH.
    that was a dark time in my life
    good news
    -car running awesome
    -if not counting draining/burping coolant......i can do a T belt on EJ25 in 3.5hrs!!
    Robnik[QUOTED] likes this.
  18. Jun 20, 2024 at 10:38 PM
    #58
    Funkychateau
    Martin
    None
    I couldn’t find the adjustable-head puller tool anywhere locally, and was about to try the wood screws several have recommended. Then I had an idea to modify the Harbor Freight tool for close-quarters use. It wound up working perfectly, and I had the old seal out in seconds.
    Not bad for a $7.99 tool ($5.99 with 25% discount coupon).
    I returned the Amazon POS this morning.
    Robnik likes this.
  19. Jun 21, 2024 at 9:40 AM
    #59
    Funkychateau
    Martin
    None
    How much oversized should the new seal be? This new one is 0.044” larger that the old, which was a snug fit.
    B92C4CBB-A304-4B76-90BE-C8A2FE2641F3.jpg F8E3D471-D258-440D-8102-4C4E0F10BC93.jpg
  20. Jun 21, 2024 at 11:51 AM
    #60
    Funkychateau
    Martin
    None
    OK, the answer is that 0.044” oversized is definitely way too large. No way to make it fit. I even tried sanding a bevel on the leading edge to get it started. Think Ron Jeremy vs Lil’ Kim. These are going back to Amazon.
    I bummed a ride to a parts store that had the seal in stock. Measured it at the counter and it was only 0.010” oversized, plus it was brown like the original and missing the extended lip (also like the original). Bought that one.
    Sad thing is, in an attempt to get the Amazon part to fit, I removed my oil pump cover so I could really swing the hammer. Now I need a new gasket to reinstall that, and even the dealerships around here have to order it.
    Jeff Bezos owes me reparations.
