harmonic balancer removal
Discussion in '1st Gen. Tacomas (1995-2004)' started by tlh178, Feb 3, 2012.
  1. Feb 3, 2012 at 4:14 AM
    tlh178
    tlh178 [OP] Well-Known Member
    terry
    lake huron/sag bay
    2012 4WD reg cab/ 02 SR5 Prerunner/07 FJC 4WD
    trying to get this pulley off. i was able to remove the bolt easily. there are 3 holes on the pulley. i was able to bolt one of the M8x125 bolts into the pulley. the hole straight up from that , the M8x125 just goes straight thur there. not sure if the factory forgot to thread that hole or what. the 3rd hole is much bigger and is offset and would not line up with my puller. this is a 02 taco with 275k, i expect this to be a bugger to get off. i'm replacing water pump,timing belt,tensonier,pulley and thermostat. this are all oem parts. alittle overdue on this. but hey its a toyota, built to last! thanks for any tips guys!
  2. Apr 7, 2014 at 3:49 PM
    Leaky
    Leaky Active Member
    How did you make out?
  3. Apr 8, 2014 at 7:41 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    look at youtube.
    you may not find something '02 Tacoma specific, but you may learn how to trouble shoot your problem.
  4. Apr 9, 2014 at 6:55 AM
    Leaky
    Leaky Active Member
    Thanks
