Harmonic Balancer Snapped
Discussion in '1st Gen. Tacomas (1995-2004)' started by hwakaflocka, Jul 7, 2018.
  1. Jul 7, 2018 at 2:10 PM
    hwakaflocka
    hwakaflocka [OP] Member
    1999 toyota tacoma 2rz 106,000 and counting
    4 component speakers with 1000 watt amp. Installed a Nexus 7 in dash for radio with equalizer. 15 inch treo sub with 1200 watt amp. Looking to work on other things now.
    I have a 1999 Toyota Tacoma 2.4L XTRA cab 2wd has about 130k on it. The harmonic balancer snapped and completely stopped working. After a few attempts by someone else to drive it once no oil was pumping and the engine overheating. It came back to me.
    Any suggestions on what damage may have been done or what I should do. The mechanic who took it apart said the oil pan needed to be replaced because metal from the balancer breaking went into the oil pan.
    Long story short I am not paying the mechanic to replace this stuff and was wondering if anyone has had any similar problems or had to do anything similar. Any suggestions would be appreciated.
  2. Jul 7, 2018 at 4:23 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    No oil pressure will ruin the crank and rod bearings. The motor needs to be rebuilt or replaced.
    Black97v6MT and Crodell6 like this.
  3. Jul 7, 2018 at 6:52 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    How does a balancer snap. I have seen them crack or shear woodruff keys. Could he put a new key and pulley on then check compression ect?
  4. Jul 7, 2018 at 8:00 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Mechanic sounds like an idiot. How would any part of the harmonic balancer get into the oil pan?
    I've heard of the outer pulley separating from the inner part because they are attached by rubber, then the outer part stops spinning and the water pump stops spinning. Or like Adude said, the key can break, and if the bolt is too loose the harmonic balancer will not spin.
    You need to take things apart and assess the damage for yourself. Posting some pictures of the damage here would help and be interesting to see.
    If the engine overheated badly then you could be looking at a warped head and blown headgasket.
    If somehow the oil pump got damaged (behind the harmonic balancer) and oil wasn't pumping, then this engine is toast (as Peter Venkman might say).
    Black97v6MT and Adude like this.
  5. Jul 8, 2018 at 10:08 AM
    hwakaflocka
    Maybe he meant the oil pump looks like he took that off and didn’t give me the part back that’s what he said when I called and asked. He’s a idiot.
    How do you tell if the engine needs to be rebuilt? I’ve heard these engines are pretty tough. Not saying that driving while no oil is pumping is a good idea but just wanting to see if that parts necessary before dropping a bunch of money.
    Black97v6MT likes this.
  6. Jul 8, 2018 at 10:26 AM
    TacoHank1998
    TacoHank1998 Well-Known Member
    Will
    Panama City, FL
    1998 Green Tacoma Base
  7. Jul 8, 2018 at 10:39 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    If it were me, I would pull the valve cover and remove the camshaft. This would tell me if the engine starved for oil. A better tell would the the crank bearings, but that is more work to remove the crankshaft.
    If the vehicle were driven any distance, the engine would have likely seized with no oil distribution to the engine.
    EDIT: that is a very strange way for the balancer to fail. Was somebody working on the motor?
  8. Jul 8, 2018 at 10:49 AM
    hwakaflocka
    The timing chain was done a long while ago other then that no work on the motor.
    It was driven for a while after it failed apparently. Not quite sure how it happened.
  9. Jul 8, 2018 at 12:24 PM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    Wow! I'm not sure how that could happen. I almost want to say that someone broke it trying to remove it with a crowbar or something, like if it were stuck from gummed up oil. Maybe they didn't realize it extended that far back on the crankshaft and they hammered a crowbar behind it.
    Try to get the oil pump cover back to see if there's any damage on that.
    If it did crack apart like that when installed it would have chewed up the oil seal on the oil pump cover. The harmonic balancer surface slides on the oil seal. This would have caused a significant oil leak, so it's possible the oil went low. The oil pump gears look intact though.
    Taking the exhaust cam off to inspect the cam bearings is a lot easier than taking the intake cam off. The intake cam has the chain on it. If you take the exhaust cam off follow the procedure in the repair manual and be sure to install the service bolt in the gear.
    Or you could put the oil pump cover back on and a new harmonic balancer and try to fire it up.
  10. Jul 8, 2018 at 12:37 PM
    hwakaflocka
    Guy said that’s how it was when he took it off he’s a piece of shit though. He casually offered to take it off my hands if I didn’t want to pay 2200 to repair it. Fucker
  11. Jul 8, 2018 at 12:45 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Silverado Crew Cab Z71, 5.3 made from real Tornado's!
    A few additions to make me feel cool.
    Would be cheapest to replace with a remanned motor.
  12. Jul 8, 2018 at 12:46 PM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    It's unusual for sure. I think if someone pryed it the damage would have been closer to the pulley, so maybe my theory is wrong.
    My next theory is that the bolt was loose and the harmonic balancer was wobbling slightly, so eventually it got a stress fracture and that piece broke off.
    What's the story, you own it but someone else had been driving it?
  13. Jul 8, 2018 at 2:22 PM
    hwakaflocka
    Correct someone was borrowing it when it broke.
  14. Mar 21, 2025 at 2:07 PM
    PavementPrincess04
    PavementPrincess04 Member
    Wyatt
    Portland, Oregon
    ‘95 2.7 4x4 5-Speed
    Know this is an old thread…………but I just discovered that the exact same thing happened to the HB on my 3rz……….
    Aside from popping the pump cover (as I’m replacing the entire pump assembly anyway) to assess damage, does anyone have any input on where to go from there?
  15. Mar 21, 2025 at 6:38 PM
    Black97v6MT
    Black97v6MT 364k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    27+ years of livin' Gen1 TacoLife...
  16. Mar 22, 2025 at 1:21 PM
    PavementPrincess04
    Wyatt
    Portland, Oregon
    ‘95 2.7 4x4 5-Speed
    Guessing the bolt wasn’t torqued down enough and wobbled out over time………….
    Not that I shouldn’t have noticed this occurring myself, and am also not a mechanic by any means……..but this truck was purchased from individuals with blind overconfidence in their mechanical knowledge/abilities, who also certainly lacked an attention to detail, based off of numerous other, unrelated, findings…….
  17. Mar 22, 2025 at 1:49 PM
    Black97v6MT
    iMA0
    tacoLand USA
    Oh my!
    Moonrman likes this.
  18. Mar 22, 2025 at 6:01 PM
    Glamisman
    Glamisman Well-Known Member
    Give us a picture of the woodruff key in the crankshaft. I sure looks like the balancer break started at the keyway in the pulley.
    Dump the engine oil and see if it is glittery, if it is the motor is toast. If the oil isnt glittery take the oil filter off and drain it in a clean container and check for glitter there. Cut the oil filter open and pull the pleates apart and look for glitter in the filter media.
  19. Mar 22, 2025 at 8:25 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    Its like those dreaded lower ball joints....if you're driving around on an original HB
    you're on borrowed time
    If its been replaced with some cheap aftermarket one......you're on borrowed time
    its worth checking for that wobble while under the hood with it running....
    or the alternator belt starting to slip/whining
    when they wobble too much....it causes that bolt to back off
    all hell breaks loose after that.....damage to time cover on inside where the oil pump gear rides....oil pump....worst yet sheer woodruff key/and or wallow the key seat
    Not sure about 5vz.....but on 2rz/3rz they can cause a lot of damage if not caught early
    my 400lb paper weight
  20. Mar 24, 2025 at 3:20 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    also
    take valve cover off
    inspect cams for oil starvation.....look for 'rainbowing' from heat on lobs
    top of engine will take a dump b4 the lower end does just bc oil will not be moving up to the head
    ugh sorry
