Harmonic Balancer Snapped
Discussion in '1st Gen. Tacomas (1995-2004)' started by hwakaflocka, Jul 7, 2018.
  1. Mar 26, 2025 at 1:37 PM
    PavementPrincess04
    PavementPrincess04 Member
    Wyatt
    Portland, Oregon
    ‘95 2.7 4x4 5-Speed
    -Under the Oil Pump Cover…..
    As I said, I’m no mechanic and am very unfamiliar with the woodruff key……..
    so any geared-down guidance for a JV would be great. Ha!
    Black97v6MT likes this.
  2. Mar 28, 2025 at 8:49 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    need to make sure that key is good and tight...solid square in the slot
    otherwise it'll just twist and destroy the new HB
    cant tell from your pic.....but might be a little twisted
  3. Mar 30, 2025 at 2:14 PM
    PavementPrincess04
    Wyatt
    Portland, Oregon
    ‘95 2.7 4x4 5-Speed
    Gotcha, thanks! About to go dive back into that right now.
  4. Apr 30, 2025 at 4:35 PM
    PavementPrincess04
    Wyatt
    Portland, Oregon
    ‘95 2.7 4x4 5-Speed
    Didn’t mean to go silent for this long. Had a bunch of things unexpectedly come up this last month………….
    Was just able to get the timing cover off……..I’m screwed, aren’t I?…………
  5. Apr 30, 2025 at 5:13 PM
    O'Silver_Taco
    MD
    Yep....I had similar 6 yrs ago
    it was an easy fix......well except for the $5000 hole in my pocket it left...
    If that key can lean....you will eventually spin the next HB...
    on mine the A/C kicked on.....and put it over the edge
    Its really import to seat the new HB carefully\\
    with being such a tight fit....its a recipe for disaster
    polish and lube the snout.....and file the edges of the new HB's keyway...
    so it doesn't stick the landing
    its moved so much on yours.....its busted that timing gear
    its thinnest part is on that key slot
    your picture is not very clear......need better one
  6. Apr 30, 2025 at 5:38 PM
    O'Silver_Taco
    MD
    Key has to fit snug.....
    TartanEagle likes this.
  7. Apr 30, 2025 at 6:15 PM
    PavementPrincess04
    Wyatt
    Portland, Oregon
    ‘95 2.7 4x4 5-Speed
    I figured………….was just hoping I was wrong…………Here’s some more pics of it.
    Didn’t realize I took such poor pictures ha……….I’ll snap a better one when I get home.
  8. Apr 30, 2025 at 6:20 PM
    O'Silver_Taco
    MD
    The $5K question is......did that gear get broke from key kicked up and caught by the HB when it was mounted....
    or did it break from key rocking
    in earlier pic it looked twisted
    IF you tap that key back in......does it fit snug/tight
    Also you need to check the back of the timing cover and look for hairline cracks on the back side of the oil pump gear area..........a wobbling of HB is really bad inside that
  9. Apr 30, 2025 at 8:27 PM
    Glamisman
    Glamisman Well-Known Member
    This is where an overall truck evaluation is required. 2.4's are pretty rare to get used and having said that I bet 3 will pop up in google searches, anyway, if the truck is in good shape it might be worth the effort otherwise sell her and let someone else do the project. With the proper tools you could start this on a friday afternoon and be driving her sunday afternoon.
  10. May 1, 2025 at 11:33 AM
    O'Silver_Taco
    MD
    Down here in south we have tons of 2rz/3rz down here....
    its just that most of you here slight 'eye the 2.4's rwd....like they are tweens or beyond spectrum kids.....
    the 2.4's will be decent and usually just under 200K
    where as all the 4x4's are extreme high miles...want way too much....and mostly wore out, in need of major funds
    unfortunate truth is about half of those 2rz/3rz needs HG.....or at least on its way out
    so running to another one may not be what you think
  11. May 1, 2025 at 2:19 PM
    PavementPrincess04
    Wyatt
    Portland, Oregon
    ‘95 2.7 4x4 5-Speed
    I pulled the woodruff key out…….obviously pretty thrashed……..damn it.
  12. May 1, 2025 at 3:50 PM
    PavementPrincess04
    Wyatt
    Portland, Oregon
    ‘95 2.7 4x4 5-Speed
    Also, back of TC.
